[S905] Device trees
  • Hi, do you know if these device trees were added to the 7.0.2.007 Almost there build? as a generic device tree? or can these be renamed and used with the build?
  • edit4ever Can you test this device tree: gxbb_p200_2G_m8s+_k3_pro.dtb
    It can be used with 7.0.2.007 or any of the dev builds. What I changed are power_on_pin and interrput_pin bumped by 4 according to your suggestion in the other thread.
    OK - Strangely that worked! I tried doing the same thing on my end but it didn't work. I'll have to compare files to see what I was doing wrong on my test version. I'm still learning!
    Thank you!
    P.S. If you add that to your device trees - I'm not sure what the right name for it is. k2pro_gig_update.dtb ??
  • kszaq - Thank you again for providing the updated dtb for my KII Pro...
    I have a question I'm hoping someone can answer. When I dumped my rom and extracted the boot.img and then the dtb file...it seemed like it was the same as the original M8S+4k file (wrong wifi info) which of course didn't work for me. What I realized during testing was the "misc" part of the nand was impacting the boot and changing dtb info.
    So the question is - is there a way to convert the info in the misc block to see what device tree settings it is adjusting? I have dumped the data to a misc.img file...but I'm not sure how to extract the data from it. With the boot.img file I was able to extract the device tree using splitbootimg.pl -- is there something similar for the misc block of data??
    Thanks for any info - I'm hoping to dig down to get my ATSC tuners working in LE and want to understand what is happening in the android boot/device tree.
  • Hello Kszaq,
    First off all many thanks for the great work off You! :)
    Here are dtb.img for Q-Box amlogic s905, version 2GB/8GB and version 2GB/16GB, I do think there must be some difference between the two off them.
    regards, Jefken.
  • Hello all,
    I buy Beelink MiniMX III. It will arrive next week. Before broke something, need I backup something?
    Or installing by SD could be safe?
    Thanks and regards.
  • Working SD Card LE first. If that works you can SSH execute installtointernal command to install to Nand.
    I think kszaq might do away with .zip to install to nand and we will all use above method.
    Thanks!
    I install to internal and it works really well.
    Best regards.
  • Hi guys,
    Can you tell me, which device tree is the correct one for a
    Otterbox Nexbox MXQ Pro 4K?
    Thanks, mates.
  • Hello,
    I got this device: Transpeed S905 2G/8G - p201
    I have load the corresponding dtb file from kszaq repository but RAM size is not correctly recognized (815MB instead of 2GB), LAN is @100Mbps instead of 1Gbps.
    The dtb file from the OTA zip file provided by the dealer make the device freeze on boot.
    Is there a way to extract the dtb file directly from the device of from the IMG firmware file?
    Thanks!
  • I got this device (Transpeed S905 2G/8G - p201):
    Remove the link to the seller. No links to sellers.
  • hey guys :)
    New to LibreElec - usually use KodiBuntu.
    Anyway, I have a x96 (S905x) TV box. (link removed)
    I have 2gb ram and 16gb storage.
    I tried this device tree:gxl_p212_2g.dtb
    However, I am having trouble booting.
    I don't have a reset button (or a pinhole) or any actual buttons on the box itself; only the remote, so I'm yet to figure out how to boot properly.
    I used the LE tool to extract the image onto a USB drive.
    I have tried both USB ports on the tv box.
    I might be able to try recovery method (varient 2), as I do have an update app on the box, but when I openned that, nothing was found on the usb drive?
    If I were to just install LE to the box itself internal memory, how is the best way to take a backup of the current system (android 6.0)?
    Out of interest, do most people install LE on the internal drive, or do you run it from a USB drive or memory card?
    Thanks for your help!
    Edited once, last by cptchezza ().
  • Insert thick paperclip or small tool in AV jack and see if you can feel reset button at the bottom.
  • Anyway, I have a x96 (S905x) TV box fleabay.com.au/itm/262711771966?...EBIDX%3AIT
    Remove that link to Pirate Kodi Seller or any seller. Forum rules.
    You should not use a conductive tool to insert into electrical products.
    A toothpick is the easiest and safest.
  • Remove that link to Pirate Kodi Seller or any seller. Forum rules.
    Removed; sorry about that. Hadn't read the rules *slaps wrist*
    Okay, i'll give a toothpick a go.
