  • Confluence works fine. You could also add this code to autostart.sh:
    echo 5 > /sys/class/mpgpu/cur_freq
    echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    But this can overheat your box and damage it. So check the temp if you do. I have mounted a small pc fan on mine, so I have no problem with overheating.
    -2re
    LG BP50NB40 USB Blu-ray
  • I am using his build, but I have verified that me the power led does not work. Apart sometimes when I turn off the box, it turns on alone.
    I think, what can be the dtb. Since when I put this command "fw_printenv" it says that it is not yours the dtb.
    Here I leave the original dtb, in case it can help: MEGA
    My box is h96 pro+ (rev. Wisdom)
  • Same problem here with my Beelink GT1 Ultimate. LED is working ,if I boot into Android.
  • I am running this build on my Tronsmart Vega S95 Telos Amlogic S905.
    Up to now everything is running smooth and ok, I am streaming content from my Synology DS214 NAS to my Philips 58PFL9955H/12 TV with an aspect ratio of 21:9
    My receiver is a Yamaha RX-V671
    Thank you for all you work into this build!
  • Hi all,
    turned my Mecool KI Pro on this afternoon and got these errors. Booting is stopped and I cannot ssh into the box. Box is running off SD card. Anything I can do to fix that without wiping everything?
    Thanks for your time.
  • I have a box that I figured out last year how to install I think version 8.0.2, I installed it to device but now I cant seem to install a newer version. Its a Tonbux QBox 2GB device and I tried lots of different versions and tree DTB files but it just does not get past the Tonbux logo with the USB/SD connected and booting with the toothpick... what am i doing wrong?
  • Via ssh command fw_setenv hdmimode 1080p60hz
    Hello, thanks for you advice but it did not work for me :(
    edit1: Taking back :) got it working. used these commands:
    fw_setenv outputmode 1080p60hz
    and then rebbot
    Edited once, last by FairJohnyX ().
  • Hallo,
    I would like to use my NETFLIX account with my box, but I can not.
    I installed a LibreELEC 8.90.2 ver. on the clean box and run it (from SD). Then I used this instruction for the Netflix install.
    With PuTTY I made the 2 extra command line, and the result is:
    Using username "root".
    [email protected]'s password:
    # LibreELEC #
    # LibreELEC – Just enough OS for KODI #
    LibreELEC (community): 8.90.2 (S905.arm)
    LibreELEC:~ # wget getwidevine.sh
    Connecting to nmacleod.com (212.23.8.80:80)
    wget: can't open 'getwidevine.sh': File exists
    LibreELEC:~ # sh getwidevine.sh
    Detected ARCH: arm
    Successfully installed libwidevinecdm.so!
    LibreELEC:~ #
    After the restart I started the Netflix using and always this 2 messages appears:
    unable to complete the request at this time
    login failed. check your credentials
    What to do to run the Netflix?
    thanks for the suggestions
    MiniMX (S905.arm)
    LibreELEC-S905.arm-8.90.2.img.gz
    gxbb_p200_2G_1Gbit.dtb
    Mini MX-G 2/16 S905.arm LibreELEC
  • Do not enable "sync playback to display" !!! This is already done as part of amcodec and will cause issues. Please try the test build by afl1
    There is already a script in the build that does this automatically so you have probably broken it, run the following commands,
    LibreELEC:~ # rm -rf /storage/.kodi/cdm
    LibreELEC:~ # getlibwidevine.sh
  • Hi all,
    You need to replace SYSTEM on your sdcard with the file from the tar download, looks like it is corrupt.
  • Reboot and german language most certainly do work.
    Which WLAN chipset do you have?
    I played around with the 8.90.2 a lot, even did a factory reset ("hard reset"), the problems didn't go away.
    After downgrade (without factory reset again) i could as well change language into german as reboot normally.
    Even WLAN performance was normal again.
    i checked a realtek rtl8192cu and the internal (i don't know, MAC address says: Smartchip Integrated Inc.)
    I'm not insane. I know what i have measured.
    And other guys also confirmed the wireless problem.
    thx
    I made it and the result is:
    [email protected]8.0.3's password:
    # LibreELEC #
    LibreELEC:~ #
    and the Netflix not working :cry:
    do you have any idea?
    here is the crash log
    thank you
  • Thanks for your report, the driver was updated for Realtek devices recently, can you check the very last release by kszaq 8.2.2.3 as I think this had the same driver as well. 8.2.2.2 had the older one.
  • GDPR-2
    I just tested your latest build on my T95M just to see whether the LCD will work or not.
    It showed no signs of life. Is there anything I can do to get it to work? From either testing or developers perspective?
  • GDPR-2
    It's only for the Tanix TX3 mini at present, there is code available for the T95M and another box but I have not prepared this yet, it's on my to do list :) send me a message please so I remember to contact you to be a tester for it when I add it.
