That "snow" looks like a bad HDMI cable. If for whatever reason the new build uses a higher bandwidth video setting (like RGB or higher chroma) than the previous.
You're right.
I have three identical cables and one of them is having problems.
You're right.
New DTB is for new release not old release! It's in the README!!!
In fact i Know it just tried to see what it happens, at least it boots - so far only remote failed .. but i tried just for fun.
Btw, just like what erbas posted before, if i'm running on internal nand on kii for example, how did i know if i'm on the right dtb ?
find out the /dev/dtb - but is not code i can read, lot of code mixed with chars and some texts ...
The same for /sys/class/dtb/emmcdtb
... and find out a lot ( almost every dtb on usr/share/bootloader/ ) how do i know i'm on the right version, to replace or play with ?
isn't it supposed to be on something like /flash/ ??
according to the log, there's a broken url called during the autoupdate check:
17:36:09.131 T:3999265680 ERROR: ## LibreELEC Addon ## oe::load_url(http://kodi.adamg.co.uk/libreelec/releases/releases.json) ## ERROR: (HTTPError())
17:36:09.132 T:3999265680 ERROR: Traceback (most recent call last):
File "/home/adamg/LibreELEC/build.LibreELEC-S905.arm-8.90.4/LibreELEC-settings-d658777/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/oe.py", line 271, in load_url
File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
File "/usr/lib/python2.7/urllib2.py", line 435, in open
File "/usr/lib/python2.7/urllib2.py", line 548, in http_response
File "/usr/lib/python2.7/urllib2.py", line 467, in error
File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
File "/usr/lib/python2.7/urllib2.py", line 654, in http_error_302
File "/usr/lib/python2.7/urllib2.py", line 473, in error
File "/usr/lib/python2.7/urllib2.py", line 556, in http_error_default
HTTPError: HTTP Error 404: Not Found
Display More
maybe this is a leftover from my 8.2 inplace upgrade? defined in /usr/share/kodi/addons/service.libreelec.settings/defaults.py
Code Display More17:36:09.131 T:3999265680 ERROR: ## LibreELEC Addon ## oe::load_url(http://kodi.adamg.co.uk/libreelec/releases/releases.json) ## ERROR: (HTTPError()) 17:36:09.132 T:3999265680 ERROR: Traceback (most recent call last): File "/home/adamg/LibreELEC/build.LibreELEC-S905.arm-8.90.4/LibreELEC-settings-d658777/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/oe.py", line 271, in load_url File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen File "/usr/lib/python2.7/urllib2.py", line 435, in open File "/usr/lib/python2.7/urllib2.py", line 548, in http_response File "/usr/lib/python2.7/urllib2.py", line 467, in error File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain File "/usr/lib/python2.7/urllib2.py", line 654, in http_error_302 File "/usr/lib/python2.7/urllib2.py", line 435, in open File "/usr/lib/python2.7/urllib2.py", line 548, in http_response File "/usr/lib/python2.7/urllib2.py", line 467, in error File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain File "/usr/lib/python2.7/urllib2.py", line 654, in http_error_302 File "/usr/lib/python2.7/urllib2.py", line 435, in open File "/usr/lib/python2.7/urllib2.py", line 548, in http_response File "/usr/lib/python2.7/urllib2.py", line 473, in error File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain File "/usr/lib/python2.7/urllib2.py", line 556, in http_error_default HTTPError: HTTP Error 404: Not Found
maybe this is a leftover from my 8.2 inplace upgrade?defined in /usr/share/kodi/addons/service.libreelec.settings/defaults.py
That's nothing to worry about it's for update channel, auto update still works.
Netflix is not working anymore since I did a fresh install. Not sure what happened.
Libwidevine is no longer provided automatically and you have to install it manually
In this thread there was a newer version but it's not available for download anymore. Where can I find/download the latest relevant version?
Noted that the Developer is no longer on distribution, yet FYI working great on my MXQ Pro Quickplay 1\8 !
I would appreciate some feedback from anybody with a S905W box with issues with interlaced content, I have added an option to disable aml deinterlacing to Kodi under Settings>System>Display, just enable the option at the bottom and reboot and then test the content.
Removed autostart sh
Enabled in settings
Worked on TX3 Mini
Enabled in settings
Worked on TX3 Mini
Thanks, I appreciate the feedback.
I used this to install libwidevine.
wget http://nmacleod.com/public/libreelec/getwidevine.sh
sh getwidevine.sh
Despite that, Netflix addon didn't start...
@knarzi
install repository.netflix-1.0.1, then install netflix.plugin from it
Now new version of Tvheadend in latest build ?
@knarzi
Okay. You really thought, that I didn't install it? I installed it for sure. As I wrote: the addon won't start, nothing happens, only an error message.
(Just before: I have a Netflix access, and it works on another devices.)
sh getwidevine.sh
This is old version of libwidevine and does not work for Amazon VOD.
tvheadend44-9.0.1.120 is fixed version for TVH 4.3.
Non-Functional
some cas are not connecting
CAPMT (DVBAPI network linux) do not work
Loss of connection
The channels disappear and come back
LINUX DVBCAM CLIENT connects but I have not established a connection!
Tvheadend Unavailable server
Box KI Pro
And how/where can I get the new version?
