remote.conf repository
  • In addition to my Tanix TX5 Pro post with dedicated codec.info button made for LE7 (based on Jarvis)
    Here's some more improvments to this tiny-handy remote to meet LE 8-9 (Krypton) demands
    Basic layout stays the same, but some buttons have several functions now via keyboard.xml:
    1) Pause/Play=Power (always available with PVR and Video playback)
    2) Stop=Mute (always available with PVR and Video playback)
    3) OSDAudio Settings=UP (available in fullscreen PVR and Video only)
    4) OSDVideo Settings=DOWN (available in fullscreen PVR and Video only)
    5) PVRGuideInfo=LEFT (shows current programm description, available in fullscreen PVR only)
    6) PVROSDGuide=RIGHT (shows curent channel EPG Guide list, available in fullscreen PVR only)
    7) Current Playlist=MENU (available in fullscreen Video only)
    8- PlayerProcessInfo=MOUSE (available in fullscreen PVR and Video only)
    9) PlayerDebugInfo=MOUSE-Longpressed (available in fullscreen PVR and Video only)
    To use all these features, download and unzip the attachment
    Place remote.conf in /Configfiles/
    Place keyboard.xml in /Userdata/keymaps/
    Restart Kodi
    remote.zip
  • hi,
    have a small remote (IR odroid c1 remote from pollin) worked great on my odroid c2(android) now i am on libreelec (kzaq-latest build) and only the start button works(anyone a file)?????
  • I have the "same" remote. try this, you will need to change the name to remote.conf & put it into \storage\config
    reboot the box.
    Note, I have modified a couple of buttons.
    If it doesn't work, look for the thread, creating a remote from scratch
    I appriciate your help but I dont know - non of the config are working.
    Iam logging into the box with ftp root. the file goes into .config right? This is the only folder where I found the old remote.conf
    rebooting the box, but nothing happens. I also switchted the batteries of the remote.
    What iam doing wrong?
    This remote works with S912 Box Vorke z6 - maybe vorke is a clone from Tanix
  • Quick tip I got from one of the forums long ago that should be added to remote config file creation tutorial.
    Rebooting the box every time you want to test the remote gets real old real fast. Type this into your SSH terminal window every time you saved and are ready to test:
    remotecfg /storage/.config/nameofyourremotefile.conf
    In my case it was called test remote so I typed in remotecfg /storage/.config/testremote.conf
  • Here is mine. remote.zip
  • COOWELL V2 Android Smart TV Box
    key_begin
    0x00 31 #S (Power) -> Shutdown menu
    0x0c 113 #MUTE (MUTE)
    # 0x01 398 #RED (Media)
    # 0x05 399 #GREEN (TV)
    # 0x09 400 #YELLOW (WEB)
    # 0x0d 401 #BLUE (APP)
    0x01 24 #O (Media) -> Codec info
    0x05 35 #H (TV) -> Live TV channels window
    0x09 18 #E (WEB) -> Live TV EPG/TV guide
    0x0d 364 #FAVORITES(APP) -> Favorites
    0x06 168 #REWIND (|<<)
    0x02 114 #VOLUMEDOWN (VOL-)
    0x0a 208 #FASTFORWARD (>>|)
    0x0e 115 #VOLUMEUP (VOL+)
    0x03 102 #HOME (HOME)
    0x0f 1 #ESC (RETURN)
    0x10 105 #LEFT (<)
    0x12 106 #RIGHT (>)
    0x07 103 #UP (CH+)
    0x44 108 #DOWN (CH-)
    0x11 28 #ENTER (OK)
    0x40 46 #C (MENU)
    0x4c 23 #I(NFO) (MOUSE) -> Info
    0x49 11 #No.0
    0x41 2 #No.1
    0x45 3 #No.2
    0x4d 4 #No.3
    0x42 5 #No.4
    0x46 6 #No.5
    0x4e 7 #No.6
    0x43 8 #No.7
    0x47 9 #No.8
    0x4f 10 #No.9
    0x48 38 #L (1/A/a) -> Subtitle
    0x4a 128 #STOP (BACKSPACE) -> Stop
