How to install it on the actual box? It seems to have installed on the SD, since it booted to android when I popped out the SD.
![](https://forum.libreelec.tv/core/images/avatars/51/556-5134db117346aa261bd58c1b1c2fdde132c20922.webp)
Demetris -
December 7, 2016 at 10:38 PM -
Thread is Resolved
On linux in terminal:
ssh [email protected] (x.x.x.x is ip address of your box)
password is libreelec
Now type command:
installtointernal
and answer yes on all
On Windows use Putty, login to box and type command installtointernal
On a dream world i would compile you a patched MXIII-PLUS board file with 10/100 so you get ethernet working.
That dream world would be nice, but I guess that's why it's called a dream world - it isn't reality
Just tried LibreELEC-S8X2.arm-8.2.3-M8.img
Failed again.
Armada Mach 8 s802
LAN Ethernet:10/100M
2gb / 8gb
Previous attempts link.
Kostaman, can you confirm - you used the "Enable SD card dual boot" in post #1048 to enable an SD boot and then tried to boot one of Demetris's 8.0 builds? I have a friends M8 and am trying to determine how to boot one of Demetris's 8.0 builds via SD.
Please someone help. After the update the libreelec logo appears in the left top corner of my screen but after that the screen is black. I use the LibreELEC-S8X2.arm-8.2.3-MXIII-PLUS.tar (I have the MXIII-G)
Yes i did. #1,04
I've gone to stock Android on this box but the stock firmware still wont load LE with latest 8.2.3-m8
I just installed the 8.2.3 update (TAR) on my MXIII 1G. It works without any problems.
Just one question: I have an 200Mbps internet connection, when i run speedtest it only comes too 65Mbps.
Any reason why? Al cables and switches are 1000Mbps.
Thank you! Thank you!
I downloaded LibreELEC-S8X2.arm-8.2.3-MXIII-1G.tar.
Works like a charm!
I'm really happy!
That sounds like the same problem that I have on the x8h-plus.
Hi Demetri,
i have burned your LibreELEC-S8X2.arm-8.2.3-S82.img on my Micro SD Card with the LibreELEC.USB-SD.Creator.Win32 Tool.
I take the Card in the Slot of my Orbsmart S82. I go to the Bootloader via the RESET Button in the AV Link and Power ON on same time.
Then i try apply update from EXT and there from sdcard.
With this error:
failed to mount
is there a other Methode to flash this Box with your image???
Guys i installed (sd) last build mxiii-1g on my mxiii-g 2gb of ram and all works. But shall I use a different build due to the amount of ram? Thank you and thanks dev for your work!
I have a bricked M8S running S812. Can anyone help me get LibreElec on it?
Willing to compensate you for your time.
Thanks.
Latest build running well on M8 S802, Thank you.
Yes I get this too. I have a Tronsmart MXiii 2gb and I imaged LibreELEC-S8X2.arm-8.2.3-MXIII-PLUS.tar
First time I've run into this issue.
Yeap because you have the MXIII and not the MXIII-G/PLUS
You should use the S82 image
Hmm good to know, I guess I got lucky flashing the MXIII-Plus before then. I will use the other one from now on.
Demetri, I have the X8H-Plus and used the LibreELEC-S8X2.arm-8.2.3-X8H-PLUS.tar image, but have the same problem.
LE logo on boot and then black screen.
you no logs, me no magic balls around=you are on your own
