You can ignore the false warning (because os.libreelec.tv is installed) and continue or wait until the next Alpha release is out where we've added a temporary patch to prevent the warning - pending Team Kodi doing something to properly fix the issue.
Thoradia Add-ons
- thoradia
- Thread is Unresolved
Hey guys,
So, I installed Thoradia repo on LibreELEC (alpha).
Some addons installed just fine, like Medusa and qBittorrent.
Others, like Jackett, need os.libreelec.tv and tool.mono, which somehow aren't available....In other words: Can't install Thoradia Mono Tools for some reason.
Here's the log file:
Cheers,
Morguito.
Just click OK when you get a message about missing dependencies
where is the rtorrent.rc config file? Where can I move it to for it to apply? The default says, the root folder, as found here: rtorrent/rtorrent.rc at master · rakshasa/rtorrent · GitHub
# This is an example resource file for rTorrent. Copy to
# ~/.rtorrent.rc and enable/modify the options as needed. Remember to
# uncomment the options you wish to enable.
But the setup is different for libreelec, so I'm trying to understand.
rtorrent.rc is in /storage/.kodi/userdata/addon_data/service.rtorrrent/
Still can't install Jackett because tool.mono can't be installed somehow. Tried to install Mono Tools manually, without success.
See at CoreELEC if there is an issue with Mono
New install today on an older machine. Discovered Thoradia to install SABnzbd, CP, and SR. Initially SR was fine, where I began to add some shows in secession in my current library, Since then, it simply won't serve up. The only thing that comes up doing a system check on it is a timezone error:
Code● service.sickrage.service - SickRage Loaded: loaded (/storage/.kodi/addons/service.sickrage/system.d/service.sickrage.service; enabled; vendor preset: disabled) Active: active (running) since Sat 2018-11-17 16:45:26 EST; 2min 33s ago Docs: https://sickrage.github.io/ Main PID: 751 (sh) CGroup: /system.slice/service.sickrage.service ├─751 /bin/sh /storage/.kodi/addons/service.sickrage/bin/sickrage.start └─793 python /storage/.kodi/addons/service.sickrage/SickRage/SickBeard.py --datadir=/storage/.kodi/usNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 INFO::Thread-15 :: Request failed: 404 Client Error: Not Found for url: https://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 WARNING::Thread-15 :: Updating network timezones failed, this can happen from time to time. URL: http://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 INFO::Thread-14 :: Request failed: 404 Client Error: Not Found for url: https://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 WARNING::Thread-14 :: Updating network timezones failed, this can happen from time to time. URL: http://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 INFO::Thread-15 :: Request failed: 404 Client Error: Not Found for url: https://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 WARNING::Thread-15 :: Updating network timezones failed, this can happen from time to time. URL: http://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 INFO::Thread-14 :: Request failed: 404 Client Error: Not Found for url: https://sickrage.github.io/sb_network_timezones/network_timezones.txtNov 17 16:47:59 LibreELEC sh[751]: 16:47:59 WARNING::Thread-14 :: Updating network timezones failed, this can happen from time to time. URL: http://sickrage.github.io/sb_network_timezones/network_timezones.txtI've tried a number of uninstalls and reinstalls. When I uninstall the contents under .kodi/addons/service.sickrage go with it, so not sure if there is another location or cache I can find to purge and hopefully get a new install working.
It looks like this is the error in Radarr's own log file:
Codeat System.Data.SQLite.SQLite3.Prepare (System.Data.SQLite.SQLiteConnection cnn, System.String strSql, System.Data.SQLite.SQLiteStatement previous, System.UInt32 timeoutMS, System.String& strRemain) [0x0033c] in <61a20cde294d4a3eb43b9d9f6284613b>:0at System.Data.SQLite.SQLiteCommand.BuildNextCommand () [0x000f6] in <61a20cde294d4a3eb43b9d9f6284613b>:0at System.Data.SQLite.SQLiteCommand.GetStatement (System.Int32 index) [0x00008] in <61a20cde294d4a3eb43b9d9f6284613b>:0at System.Data.SQLite.SQLiteDataReader.NextResult () [0x0011e] in <61a20cde294d4a3eb43b9d9f6284613b>:0at System.Data.SQLite.SQLiteDataReader..ctor (System.Data.SQLite.SQLiteCommand cmd, System.Data.CommandBehavior behave) [0x00090] in <61a20cde294d4a3eb43b9d9f6284613b>:0at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteDataReader..ctor(System.Data.SQLite.SQLiteCommand,System.Data.CommandBehavior)at System.Data.SQLite.SQLiteCommand.ExecuteReader (System.Data.CommandBehavior behavior) [0x0000c] in <61a20cde294d4a3eb43b9d9f6284613b>:0at System.Data.SQLite.SQLiteCommand.ExecuteDbDataReader (System.Data.CommandBehavior behavior) [0x00000] in <61a20cde294d4a3eb43b9d9f6284613b>:0at Marr.Data.DataMapper.Query[T] (System.String sql, System.Collections.Generic.ICollection`1[T] entityList, System.Boolean useAltName) [0x00071] in <0858619ae33842c3a98f8405ba7d36b2>:0at Marr.Data.DataMapper.Query[T] (System.String sql, System.Collections.Generic.ICollection`1[T] entityList) [0x00000] in <0858619ae33842c3a98f8405ba7d36b2>:0at Marr.Data.DataMapper.Query[T] (System.String sql) [0x00007] in <0858619ae33842c3a98f8405ba7d36b2>:0at NzbDrone.Core.SeriesStats.SeriesStatisticsRepository.SeriesStatistics () [0x00052] in <9ad4852ba2664806bd2189b6172b8818>:0at NzbDrone.Core.SeriesStats.SeriesStatisticsService.SeriesStatistics () [0x00000] in <9ad4852ba2664806bd2189b6172b8818>:0at NzbDrone.Api.REST.RestModule`1[TResource].<set_GetResourceAll>b__32_0 (System.Object options) [0x00006] in <11d46a28e5ae49bfaef15362839ca42a>:0 -
Have you tried: SiCKRAGE Forums
Since I can't seem to find any docs for the CouchpPotato addon I assumed all I had to do was install it then access it via 192.168.1.xxx:5050 on a remote machine. That does not work.
Are there any tuts or docs. I am happy to help myself.
RPi 3, LE 9
The reason I am trying this is Couchpotato suddenly refuses to start as a service on Ubuntu 18.04 LTS. It was starting fine until this week. Was starting fine as systemd service, tried as init.d (nope). Starts fine from command line. Could this be related?
Medusa Addon won't connect on port 18081 either.
What have I missed?
RPi 3, LE 9
What have I missed?
Maybe it is port 8081?
The default in the Medusa addon settings page is 18081.
Regardless, it is CouchPotato that is my focus. Port 5050 is the default, as far as I know.
I got couchpotato working on the Ubuntu machine; somehow permissions got changed.
Interested in looking at the addons though. Can't make any of them work by just installing.
RPi 3, LE 9
What have I missed?
The ports you use are correct.
Check the IP address.
Hi,
I updated my LibreElec system from 8.2.5 to 9.0a9 and therefore I updated the Medusa addon from 8.2.2 to 9.0.2
But the 9.0.2 package contains an older version of Medusa (0.1.20 from dec 2017) so my medusa database is now messed up. It suffered from a forced downgrade of Medusa.
Today, I can't update Medusa in the web UI, so I ask : how can I update ? manually ?
Could you upgrade the thoradia package with a recent version of medusa ?
Done
Hi Guys !
Ccan I please you help me solved problem with add private tracker to indexer in Jacket on Libreelec ?
I found file xxx.yml, where to paste in libre this file ? I make folder "Definitions" and paste this file to this folder and after restart and login to jacket I don't see this tracker on list indexer.
