Early mainline images for RK3288, RK3328 and RK3399
  • Does not work on mainline linux
    It's for Amlogic devices running Android Kodi or CoreELEC so won't work on Rockchip devices.
    I already tested it on an Amlogic device and it worked, shows a lot of useful video and display info.
    But I hope someone will be able to modify the addon to get Rockchip video parameters so it can be displayed when you press 'o', would be very interesting.
  • Tested on z28 (rk3328) nightly-20190814-3cfe86e-box-z28
    I don't know English well yet, so I use a translator, so please forgive me for the inaccuracies.
    Almost everything works, the problem is with only one HEVC 10b file (green screen), the rest hevc10b plays well. No wifi yet, just a wired connection.
    Very long time see LE strange, when I watch TV sometimes interrupt broadcast (unstable broadcasting), resulting in the appearance of the download icon (it's normal), but then when the broadcast continues, the picture sometimes freezes, the sound continues to work fine. It only helps to stop playback and resume watching TV channel again. (a similar problem has long been observed on Android devices, on the PC this problem is not observed)
    I hope all clearly described :)
  • Very long time see LE strange, when I watch TV sometimes interrupt broadcast (unstable broadcasting), resulting in the appearance of the download icon (it's normal), but then when the broadcast continues, the picture sometimes freezes, the sound continues to work fine. It only helps to stop playback and resume watching TV channel again. (a similar problem has long been observed on Android devices, on the PC this problem is not observed)
    We also have this Caching issue using ROCKPro64 build with DTB from Recalbox's ROCKPro64 on NanoPC-T4 (RK3399). This issue is very annoying for sure.
    A fix for this problem will be much appreciated from anyone.
  • We also have this Caching issue using ROCKPro64 build with DTB from Recalbox's ROCKPro64 on NanoPC-T4 (RK3399). This issue is very annoying for sure.
    I can only connect to zet_lab and Aciel .
    My problems also occur in the same configuration as Aciel  :-(
