Thanks Kostaman...greatly appreciated.
Just as an update, I have had a mare. I have spent about 4 hours trying to load LE both via SD and also onto nand on my new Beelink Mini MXiii and it looks as though this is the second box I have bricked. It would not load at all on SD attempts despite several goes at it and then when i tried to flash the latest LE vesrion on the Nand it tells you it has been successful but then just sticks on beelink splash screen. I then tried to go back and flash version 006 and again it says it was a successful install but when the writing comes down the screen as if it is performing the boot up it stopped and crashed and said'bad errors in section 2,3,4'. Tried to reinstall the original firmware via toothpick/recovery but then it would begin the process but just stop half way through saying installation aborted.
I really enjoyed the previous versions of LE, but versions 006 and oo7 have ended up with me just bricking the boxes......gutted.
Thanks to those for the help over the last few days, but I think i will just step back for now.
Cheers
