GDPR-2 -
October 20, 2017 at 4:01 PM -
Closed -
Hi ,
pls. be so kind, and let me know, which dbt.img is recommended for build 8.90.3 for virgin installation on VORKE Z6 , 3GB
THX
I used this
I used this
Make sure to install fd628 service for extra icons
I did
Hello, I have the same troubles as here described (KIII Pro - some LiveTV channels) - its S912:
[8.90.3] LibreELEC 9.0 Alpha for S905/S912 devices
I found the same problem on S905:
Tanix TX3 MINI - Amlogic S905W (New SoC) - Android 7.1.1 - FreakTab.com
- Appears during video playback in some players
And here is temporary solution on Android on S905:
- Yes I've noticed the same problem. I solved it by turning off "resolution deep color" in settings but every time you reboot box it's activated again so you need to turn it off again. Also "color space and deep color settings" best works with 444, 8bit
Is it hellpfull for fix in LE with S912?
Thanks. Marduk
GDPR-2, just for info, while my display is partially works. On my X92 S912 device this add-on cause skip frames every 1 second. If it disabled, all looks ok. Looks like actions from service cause something wrong. May be because I have different icons, but is strange action of this service
Thanks and Regards
I did
Hi,
many thanks for fast response about .img file.
One Q. which command over SSH is for installing fd628 service?
THX
No ssh.
It´s an addon from repository -> libreelec add-ons
GDPR-2 kszaq are these good news for us? Mainline Linux on Amlogic S905/S905X/S912 SoCs – 2018 Status Update
Nothing changed yet.
"He also talked about Arm Mali-450MP integration, and they currently have out of tree support for GXBB (S905) and GXL (S905X), but more work is needed for GXM (S912) using an Arm Mali-820MP GPU. The user-space library is closed source, must be updated by Amlogic, and they have support for the three versions: fb (framebuffer), X11, and Wayland. LIMA has also be resurrected by another developer (mesa-lima), there’s basic support for Arm Mali-450 GPU, and it has successfully been tested by Baylibre."
"Going forward, there’s still lots of work on the video display driver including cursor plane, overlay planes, OSD scaling, overlay scaling, and MIPI DSI output.Vide hardware acceleration will also be challenging as Amlogic is currently using a custom software implementation, and it will have to be supported through V4L2 in mainline, so it will take some time. "
There is still no mali driver for S192. Nothing changed yet.
Don't care about S912, the question is about if they are making remarkable progress in ml kernel development and if it's valuable for us, as aml device users for multimedia.
Does the LCD work correctly for you? Does it display time and icons? Is the time right side up?
I'm making a list of device trees, but before I submit them I want to make sure that they work correctly. The only ones I'm positive about working correctly are for T95M, which I attached now, and you have the TX3 one. I'm not sure about this DTS being the final version either, the new 'display-type' property may require some more work.
I'm still working with someone to get the LCD to work correctly on his S912 X92 box, I think I got it, but waiting for his confirmation.
Hi!
In Vorke Z6, the LCD works perfectly with the DTB you gave us here.
I ran the tests given in you test_lcd post and all the icons showed up perfectly.
Moreover, I ran the following steps given in led_control.txt and all the icons showed up when they were commanded:
Display Morealarm led echo alarm > /sys/class/leds/fd628_dev/led_on echo alarm > /sys/class/leds/fd628_dev/led_off wifi led echo wifi > /sys/class/leds/fd628_dev/led_on echo wifi > /sys/class/leds/fd628_dev/led_off ethnet led echo eth > /sys/class/leds/fd628_dev/led_on echo eth > /sys/class/leds/fd628_dev/led_off usb led echo usb > /sys/class/leds/fd628_dev/led_on echo usb > /sys/class/leds/fd628_dev/led_off pause led echo pause > /sys/class/leds/fd628_dev/led_on echo pause > /sys/class/leds/fd628_dev/led_off play led echo play > /sys/class/leds/fd628_dev/led_on echo play > /sys/class/leds/fd628_dev/led_offWell, in order to test the ethnet led I had to unplug the ethernet cable, since when it was plugged, the ethernet icon was always on, regardless the command given with the echo.
Good job
I only disabled wired network in KODI settings - ethernet icon changed to wifi icon
I didn´t unplug the network cable
Thanks for confirming that the DTB configuration is correct. I'll upload the source today after work.
No ssh.
THX for great support
I'll work on it today evening, so I wanted to be ready for all possibilities.
Tested new build on all S905/X/W boxes, I have issue with Tanix TX3 Mini, regular S905X dtb with 2GB RAM works on Tanix, display shows only "boot" but no issue with LPCM 7.1, changed dtb to this: gxl_p212_2g_tx3mini.dtb, display shows the clock, after installing icon package from repository and rebooting, the display icons appeared strangely, all icons visible, last number was blinking and the LPCM 7.1 was wrong. I prefer Audio output set to 7.1 and passtrough for all audio formats. I"ve tried the other dtb from here: releases/dtb/9.0/ without luck, boot screen stays on TX3 mini. Which is the best dtb for TX3 mini?
On Neo U1 and M8S Pro+ everything was fine what I tested.
Inglese, per favore, non posso leggere una parola di spagnolo o qualunque lingua sia
I'm sorry is the automatic translator that translate in italian evry time
... however im asking about my dtb.img if there is any news about. Just for remember the m8s pro 4k . Some post ago i send you the dtb.imgAnd if you want i give you access on this box via ssh . really thanks for the time and patience
