  • As a sidethought, it would be great if the ProjectM visualization for this version of LibreElec could be included in the next build, if at all possible. Thanks for considering!
    T6 (2GB/16GB, S905x, Android 7.1.1, CoreElec - living on the bleeding edge)
  • Shadertoy 1.1.8.2 with Estuary Mod v2 2.9.6. I've just tested again. Shadertoy doesn't seem to retain the preset I select.
    Strange, Shadertoy 1.1.8.2 from the LE Repo tells me there is NO configuration settings.
    I haven't tried with Estuary Mod so I'll check that now. At least it'll show if this issue is skin dependant
    No freezing, though.
    The box doesn't actually freeze but continues to play the selected track, without visualisation, and no longer responds to input from remote / keyboard / mouse until box is reset. SSH still works. There surely must be some dependency that is missing.
    I've just tried with Estuary Mod v2 installed. Controls no longer freeze (with any skin) but no visualisation shown (and no settings available)
    Edited 3 times, last by Poida ().
  • With dvbviewer client live tv is unuseable atm. Librespot has problem also
    randomly channels can´t be opened.
    same livetv backend configuration is fine in spmc and libreelec 8 last offical Version
    part of kodi.log :
    19:43:29.848 T:3144676224 ERROR: Open - error probing input format, pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_76.pvr
    19:43:29.898 T:3144676224 ERROR: Previous line repeats 9 times.
    19:43:29.898 T:3144676224 ERROR: OpenDemuxStream - Error creating demuxer
    19:43:29.899 T:3144676224 NOTICE: CVideoPlayer::OnExit()
    19:43:31.130 T:3185525632 ERROR: PVR - Deliver - invalid channel (0)! Unable to do the epg update!
    19:43:32.269 T:4093385296 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_76.pvr
    19:43:32.319 T:3900654464 ERROR: EXCEPTION: XBMC is not playing any file
    19:43:32.320 T:3900654464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
    Error Type: <type 'exceptions.RuntimeError'>
    Error Contents: XBMC is not playing any file
    Traceback (most recent call last):
    File "/storage/.kodi/addons/service.librespot/default.py", line 95, in onPlayBackStarted
    if self.getPlayingFile() != self.ITEM:
    RuntimeError: XBMC is not playing any file
    -->End of Python script error report<--
    19:43:32.377 T:3034575744 NOTICE: Creating InputStream
    19:43:33.590 T:3034575744 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
    19:43:33.591 T:3034575744 NOTICE: Creating Demuxer
    19:43:33.597 T:3034575744 ERROR: Open - error probing input format, pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_76.pvr
    19:43:33.644 T:3034575744 ERROR: Previous line repeats 9 times.
    19:43:33.644 T:3034575744 ERROR: OpenDemuxStream - Error creating demuxer
    19:43:33.645 T:3034575744 NOTICE: CVideoPlayer::OnExit()
    19:43:35.793 T:4093385296 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_76.pvr
    19:43:35.816 T:3136283520 NOTICE: Creating InputStream
    19:43:37.203 T:3136283520 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
    19:43:37.203 T:3136283520 NOTICE: Creating Demuxer
    19:43:37.207 T:3136283520 ERROR: Open - error probing input format, pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_76.pvr
    19:43:37.257 T:3136283520 ERROR: Previous line repeats 9 times.
    19:43:37.258 T:3136283520 ERROR: OpenDemuxStream - Error creating demuxer
    19:43:37.258 T:3136283520 NOTICE: CVideoPlayer::OnExit()
    19:43:39.917 T:4093385296 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_77.pvr
    19:43:39.978 T:3127890816 NOTICE: Creating InputStream
    19:43:40.148 T:3185525632 ERROR: PVR - Deliver - invalid channel (0)! Unable to do the epg update!
    19:43:41.242 T:3127890816 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
    19:43:41.244 T:3127890816 NOTICE: Creating Demuxer
    19:43:41.251 T:3127890816 ERROR: Open - error probing input format, pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_77.pvr
    19:43:41.312 T:3127890816 ERROR: Previous line repeats 9 times.
    19:43:41.312 T:3127890816 ERROR: OpenDemuxStream - Error creating demuxer
    19:43:41.312 T:3127890816 NOTICE: CVideoPlayer::OnExit()
    19:43:43.482 T:4093385296 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_77.pvr
    19:43:43.498 T:3900654464 ERROR: EXCEPTION: XBMC is not playing any file
    19:43:43.499 T:3900654464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
    19:43:43.534 T:3168740224 NOTICE: Creating InputStream
    19:43:44.748 T:3168740224 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
    19:43:44.749 T:3168740224 NOTICE: Creating Demuxer
    19:43:44.756 T:3168740224 ERROR: Open - error probing input format, pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_77.pvr
    19:43:44.818 T:3168740224 ERROR: Previous line repeats 9 times.
    19:43:44.818 T:3168740224 ERROR: OpenDemuxStream - Error creating demuxer
    19:43:44.818 T:3168740224 NOTICE: CVideoPlayer::OnExit()
    19:43:49.151 T:3185525632 ERROR: PVR - Deliver - invalid channel (0)! Unable to do the epg update!
    19:43:50.404 T:4093385296 NOTICE: VideoPlayer::OpenFile: pvr://channels/tv/Alle Kanäle/pvr.dvbviewer_83.pvr
    19:43:50.425 T:3900654464 ERROR: EXCEPTION: XBMC is not playing any file
    19:43:50.426 T:3900654464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
  • Great Work .. Thanks !!!!!
    Libreelec 8.90.5 with Tvheadend and Oscam
    PVU Channel Open More Fast and Stable
    Thanks again !!!!
    Can it also work for Wetek play2, because, some issues for few days back
  • I just solved this issue when the same behaviour occurred trying to plug my hard drive into my rock64 running raybuntu's rock64.arm-rb-leia24.
    Again the hard drive would not show up with the same notification issue above.
    I then plugged the drive into windows but it showed up as RAW and needed formatting.
    I then tried plugging it into my MAC and it was showing not recognised.
    I then plugged the hard drive into the TX7 and it mounted.
    I used file manager to see the files and that's when i saw some files i hadn't noticed before.
    ANDROID Folder. Most likely when plugged into the TX3 Mini when i booted Android.
    Spotlight Folder and trashes etc. A mac filing system helper for spotlight searches which was more than likely initialised when i plugged the drive into a Mac.
    I deleted all these files and only left my movie/tv files on the drive using file manager on TX7.
    BINGO the hard drive mounted first time on the Rock64 and the TX3 Mini.
    Hope this helps others if that happens. I was lucky the TX7 could mount and read the hard drive.
  • I just install 8.9.50 on sd for my Wetek play2, it boot properly, after installing Tvheadend 4.2 or even 4.3 , HTSP client show error as network not connected, how to resolve it ?
  • Bonjour, avec cette version la connexion Ethernet ne fonctionne plus. En Wifi OK. Est-ce normal?
    Hello, with this version the Ethernet connection no longer works. In Wifi OK. Is this normal?
    (GT1Beelink - Amlogic S912)
  • J'en profite pour signaler quelque chose d'étrange, que je constate sur toutes les versions de Kodi. Je trouve que la qualité des pochettes est basse. Si je compare au rendu des pochettes directement sur le site TMBD depuis mon PC, certaines sont magnifiques. Mais sur Kodi, elles sont dégradées. Définition/aliasing et colorimétrie. Pourtant, l'affichage sous Kodi est bien 3.840 x 2.160. J'ai aussi essayé de modifier la gamme colorimétrique 10 bits 4:4:4 , 8 bits, etc. Mais jamais le rendu est fidèle aux pochettes originales. Kodi applique t-il un downgrade pour plus de fluidité ?
    À contrario, sur PS4, les pochettes sont magnifiques, autant dans l'OS PS4, que Netflix par exemple. (Même réglages TV que Kodi)
    (TV OLED UHD 2017)
    I take this opportunity to point out something strange, which I see on all versions of Kodi. I think the quality of the pockets is low. If I compare the rendering of wallets directly on the TMBD site from my PC, some are beautiful. But on Kodi, they are degraded. Definition / aliasing and colorimetry. However, the display under Kodi is 3.840 x 2.160. I also tried to change the 4-bit, 4-bit, 4-bit, 10-bit color gamut. But never is the rendering faithful to the original covers. Does Kodi apply a downgrade for more fluidity?
    In contrast, on PS4, the pockets are beautiful, as in the OS PS4, as Netflix for example. (Same TV settings as Kodi)
    Edited once, last by bindou ().
    Have you set your IP address as fixed. Its possible that your box has moved IP address after a reboot and your client is no longer pointing at the right TVH server address.
    Shoog
  • Have you set your IP address as fixed. Its possible that your box has moved IP address after a reboot and your client is no longer pointing at the right TVH server address.
    Shoog
    its after fresh install
  • Hey GDPR-2 . I'm having a conversation with users having subtitles stutter issue. Issue that has been moved on this forum couple of times: Dropped frames caused by subtitle rendering
    The problem was supposedly to be solved in Leia but it isn't. Do you you have any information regarding this issue? This is definitely some sort of bug linked with Amlogic devices because it occurs only there. There are no stutters on PC and Android version.
    I know it's problematic because logs doesn't show anything. I have partially solved it with settings but some users still have it.
    User MichelLoyen has this problem in all videos. He writes about it here.
    Maybe you could look at this issue once again, when it suites you of course and reproduce it?
    TX5 PRO S905X
