- kszaq
- Thread is Unresolved
My suggestion would be to go to the coreelec download page, select new installation, then select your device from the list. The device tree that is written should be correct, if not, you will see the device trees folder.
If it doesn't boot, select a device tree based on your LAN & RAM
Worked with tree for gxl_p281_2g if someone will have similar problem.
Thanks for hint.
I had previously installed to internal and don’t have “original android” image files. Is it possible to undo back to SD card or update to latest generic S905x Libre/Core?
I had previously installed to internal and don’t have “original android” image files. Is it possible to undo back to SD card or update to latest generic S905x Libre/Core?y
Try freaktab for an original or custom rom, then look for how to install the rom using sd card maker or usb cable thingy
Hi
I have LibreElec 8.0.2 with Kodi 17.3 installed on my Venz V10 S905, to be used in my car. The car does not have HDMI so I need to use the AV out on the Venz, however, I am not getting any output on the AV out connector. HDMI works fine when I test it with a normal TV, but not AV out.
Is it possible to get video on the AV out? How do I set it up?
Thanks, ThomasX -
I have just bought this to use my wetek play2 on a CRT TV;
HDMI à RCA AV/CVBS Adaptateur 1080p mini HDMI2AV Video Converter~PL | eBay
Works well
hey guys,
I got to work latest build LibreELEC-S905.arm-8.2-8.2.3.1.img.gz on two of my s905 boxes (using gxbb_p200_1G_1Gbit.dtb device tree):
- Beelink Mini MX 1g/8g S905 with bluetooth and wifi
- a noname box I have which is called MXV, which is closed to a S905 MXQ pro but not exactly (board S905-BOX_Ver_C 2016.03.28 // firmware p201-userdebug 5.1.1 LMY47V)
on this last one remote was not working, I found on some topic some remote.conf that I tested and got it to work, only volumes buttons are not correctly mapped.
so I tried to follow this Infrared Remotes [LibreELEC.wiki] but without succeed, as ir-keytable -t command to test the code of my volume buttons returns :
/sys/class/rc/: No such file or directory
any idea how I can do to map these correctly ? Thanks
Edit: another problem on the mini mx box: it shutdowns (light switch from red when it's on to blue, but that's ok) but I can't power it on again. On stock it works. any way I can fix this ? thanks
Edit2: solved the shutdown problem, doing this, still trying to find a way to fix my remote volume +/-
wow cool, switching from
LibreELEC 8.2.3.1
to
CoreELEC 9.2.4.2
Download links for LibreELEC 8.2.3.1 are dead.
Is it still avaible for download?
http://libreelec.dtech.hu/_TEST_/kszaq-archive/LibreELEC-S905.arm-8.2-8.2.3.1.img.gz
Are you looking for this image?
The dtbs are available here:
However, kszaq's LE repo is no longer available.
http://libreelec.dtech.hu/_TES…05.arm-8.2-8.2.3.1.img.gz
http://libreelec.dtech.hu/device_trees/
1.Yes, when i press on it,nothing happend.
2.Does open trees.
Because it's a direct link, so try this: Right click -> Save as...
