  • I am currently working on improving Amlogic support in LibreELEC and Kodi master.
    kszaq, do you have a current build for my Acer Revo AR3700-U3002 with ION integrated graphics? Is there any way to get this box to play HEVC and 4K content? What do you suggest for me?
    Thanks michael
  • kszaq, do you have a current build for my Acer Revo AR3700-U3002 with ION integrated graphics? Is there any way to get this box to play HEVC and 4K content? What do you suggest for me?
    My area of "expertise" is only Amlogic, can't advise on HTPCs, sorry.
    Thanks michael
    The short answer is No.
    The GPU is too old, it doesn't support hardware decoding for HEVC. And the CPU is too weak.
    I don't even think it supports 4k resolution.
    Also, Linux on x86 doesn't support HDR yet, so no HDR in LibreELEC for PCs for now.
  • Nexbox A95X S905 1G/8G. Running latest/last version of LE 8.2 from SD card. Everything seems to be working fine. Only problem is that the remote won't power on the box after it's been powered off.
    I have tried the specific A95X remote.conf from the remote.conf repository - copied this file on the SD card to overwrite the default remote.conf. Didn't seem to fix the power on issue.
    Is there a fix or workaround for this?
    Thanks.
  • Is there a fix or workaround for this?
    Don't turn off your box.
    pel.hu
    Knock yourself out. [HowTo] solve power on u-boot bug in NEXBOX MXQ PRO (s905)
    Here's a tip that may or may not work.
    Get yourself a usb a to usb a cable and plug one end into the usb HDD input of your TV.
    Plug the other into the usb of your box.
    Turn on TV and the box should power on.
    This will turn your box on everytime you power on TV.
  • tried a lot of Android builds but this LibreELEC os is the best on s905x box. Thank you devs for all the free time you put in this project kszaq
    WeTeK HUB, T95X, X96, RPi2, MiniX NEO X7, MiniX NEO X8-H and a HTPC
  • Has anyone has issues with PCM through a receiver on the S905X?
    I get load white-noise randomly when trying to play videos. It happens with all audio codecs as long as I am not using passthrough (I don't use passthrough because I need to be able to change the volume from my tablet).
    I think the issue is the same one linked a year ago here:
    [S905X] - Noise when playing files with AAC 5.1 audio
    I am pretty confident it is an issue with the PCM output not conforming to what the receiver expects. The white noise occurs randomly when starting to play a video, but also occurs randomly if I switch the receiver on/off or switch inputs while a video is playing. This happens both with TOSLINK and HDMI audio.
    As I said it never happens with passthrough, but that isn't helpful to me.
    I am unsure if this is an issue with my specific S905X box or an issue that would show up with any S905X box and my receiver, or possibly something that could be fixed via the dtb. I have tried many different versions of LibreElec as well as building it from source. All versions from the past 6months or so that I've tried have had this issue.
    The receiver I have is a couple years old Denon AVR-S500BT
  • Well PCM is sent as 7.1, So who knows what the AVR will do with it.... :( ;)
    -2re
    LG BP50NB40 USB Blu-ray
  • The short answer is No.
    Thank you for the information. I'd hoped I could make more use of this box than just x264/1080p and below that I get now. Even my RPi 2 now plays HEVC x265 clips once I upgraded it to current. I'd hoped I could do more with the Acer Revo.
    Looks like I'll need to find a new box, but the pickings are slim. I love the Nvidia Shield but it only plays Android and that denies delete permission to my external USB media drive which is crucial for my use. I've tried the Droidbox s905 T8-Mini and s905x T8-SE, but they just don't seem to be the ultimate solution, even when running the LibreElec boot option. I just am not experienced enough to wade through all the various comments and suggestions that seem to point at more like the Droidbox setups.
  • I've tried the Droidbox s905 T8-Mini and s905x T8-SE, but they just don't seem to be the ultimate solution, even when running the LibreElec boot option. I just am not experienced enough to wade through all the various comments and suggestions that seem to point at more like the Droidbox setups.
    Whats wrong with the Tanix TX7 S905X box. Cheap and highly specced and supports UHD and gives HDR too though I only have a FHD TV with an excelletn picture quality right now as unable to afford to change TVs. I used the Beelink MXIII II S905X box before and that was even better but no longer available.
    Cheers
    RayW
    Tanix TX9 Pro 3/32GB S912
    Tanix TX7 2/32GB S905X
    Beelink MINI MXIII II 2/16GB S905X
    MXQ M12CX 1/8GB S905X
    MXQ M12 1/8GB S805
    Denon X500 AVR System
    LG 55SJ850T Super UHD TV
  • Auto Update Worked on My TX7 (2018-01-22) 8.2.3.1
