  • Mecool m8s pro S912 3/16gb 8.2.2.4oc installed to internal
  • Since the update my systems always crash in few minutes..
    Please another update to fix it. I think that Im not the only one with the crash Problem.
    2xBeelink GT1 Ultimate with LibreELEC in the internal.
    1x Abox A3 with LibreELEC in the internal.
  • Adam86 :
    Instead of buying an expensive HDR capable AVR you can buy a much cheaper HDR HDMI splitter and you can enjoy HD audio and 4k together,
    pel.hu
  • Adam86 :
    You know I would consider something like that, it is certainly something I'd be happy using, its just educating others in the house to remember to switch the TV & AVR inputs at the same time.
  • Which S912 is not supported?
    pel.hu
  • Most people have been buying the MECOOL M8S Pro L for dual boot LibreELEC / Android TV ROM with 1080p Android TV Netflix capabilities.
    The Pro L has guaranteed Widevine L1 and HDCP 1.x - needed for Android TV Netflix - the regular M8S Pro does not, unless you get a mislabeled box.
    Both device do not have Gigabit (1000M) LAN but 100M(bit) only.
  • Adam86 :
    Instead of buying an expensive HDR capable AVR you can buy a much cheaper HDR HDMI splitter and you can enjoy HD audio and 4k together,CC
    Can you confirm this one works? I had a 4K splitter and it did split the signal simultaneously, but it capped at the lowest setting, which is my 1080p Onkyo 717. My TV was automatically limited to 1080p as well. If I force Kodi to 4K, my amp loses the signal, thus no audio. I think I'm gonna need a new amp.
    If it ain't broken: break it, fix it, repeat
  • No I cannot confirm, it is on the way. But in other thread another splitter mentioned which works fine. It has an EDID switch, so you can force it to use the tv's capability. I ordered this because it is declared as HDR capable.
    pel.hu
  • Have anyone an idea how I can set the energysave (I dont know thats right im german -Energiesparen-) settings in Settings->Energysave and activate the suspend mode? I cant set this because its grey.
    If I force my splitter to 4K, my amp loses audio. Doubtful any switch will work. I already have two switches, neither of them works (to be fair, one of them is a switch, not a splitter). At first I thought it was working fine, because Kodi osd media info said it was playing a file at 4K. Sure, it was playing a 4K file, but my TV was outputting 1080p.
    Try
    [8.2.1.2] LibreELEC 8.2 for S912
    But it is considered unreliable, with different results on different devices. Some not properly waking up anymore. Hence it being disabled by default. If you break your system you get to keep both halves.
  • If I force my splitter to 4K, my amp loses audio. Doubtful any switch will work. I already have two switches, neither of them works (to be fair, one of them is a switch, not a splitter). At first I thought it was working fine, because Kodi osd media info said it was playing a file at 4K. Sure, it was playing a 4K file, but my TV was outputting 1080p.
    My AVR has HDMI 2.0 and it works fine with 4k video. The only problem is it cannot passthrough 4k HDR video (out is 4k SDR).
    So I hope this HDR splitter will work with my system.
    pel.hu
  • My AVR has HDMI 2.0 and it works fine with 4k video. The only problem is it cannot passthrough 4k HDR video (out is 4k SDR).
    That will work then, I think. My amp doesn't do 4K passthrough, only 4K upscaling. Think I'm gonna go for an Onkyo 656.
