using 8.2.5 i can't find a sleep.conf.sample in any folder of my x86 version. is there another way to enable hibernate mode?
edit: oh looks like the wrong thread for this question
is this really the solution to power down the device right from LE?
Is this bringing the device in the same wakeup modus as when you boot to internal (Android) first and then shut off with the red button on the original remote?
This is the way I power down now and I am looking so long for a proper solution to power off right from LE.
I am using Wrxtasy's 8.2.4-subtitles-ff and have a H96 Pro+
Update
Ik tried workaround from Kszaq above.
But it does not have any effect on powering off from LE.
If you power off you can't boot anymore with the remote and need to off/on powersupply.
When I Winscp to the sleep.conf.d folder again after reboot even a new sleep.conf.sample file has been created together with the modified sleep.conf file![]()
How do I get this standby modus without needing to boot to Android and power off from there
