Hm... Even than don't know how.
Would be a good idea to post this like question, idea, some kind of request ?
Probably best to search kodi forum for kodi related things like subs.
It would be a good idea to read the Kodi Wiki that already has all this sort of info you are requesting.
Such as Video Calibration:
Settings/System/Display - Official Kodi Wiki
There is no such thing a LE subtitles. It's pretty much standard Linux Kodi Krypton that LE AML devices are running modified for AML audio and video playback. Kodi and different Skins handle subtitles.
Hmmm, okay.
I don't have it as an available option.
You hardly know which build your are using?
Latest Kszaq stable Build, 8.2.2.3
Guys ive just noticed my U9-H isnt doing any DTS HD MA passthrough, only time it works is when i turn support for it off in kodi, ive read around and it seems to work for everyone else? its connected directly to a LG 55 B7 OLED, ive messed around with every option with no luck? does it support it? ive downloaded the DTS test file too and no luck with that either
bonjour commentaire extraire dtb à partir d'un firmware .img s'il vous plait
KM8P-NMF26Q-20170711.173522.V0321.img
Mine works just fine but it connected to/through the receiver. I have OLED55C7 but never checked if it supports DTS-HD MA.
BTW, looks like your sound output through the TV speaker? How do you know it's not doing DTS MA? Where do you see the audio track info when directly connected to the TV?
I just want to thanks to all. Thank for product - simple setup, works very very good - it is wonderful product!
Also I would like to thanks to all for helping and keep supporting the project !
hi mate, well i used the hd ma dts demo file
DTS Demo Trailers (DTS:X, DTS-HD MA, DTS 7.1, DTS 5.1)
and also my UHD rips that are HDMA dont work when i tick "my device supports DTS HD", i get no sound, but the moment i untick it the sound comes back
I'm on 8.2.2.3, are there any newer builds out yet? S912. My HDR isn't working as intended on this version
EDIT: Found this post for LE 8.2.4. will give it a go tonight ![]()
U9-H and Libreelec | Page 7 | MINIX Forum - Official
I`m using wrxtasy 8.2.4 for three days and its OK but GPU OC is not working for me, still only 666Mhz on Beelink GT1 2GB 16GB (no problem with OC 792MHz with new kernel on prevoius versions)
ERROR: AML: no rw on /sys/class/ppmgr/ppmgr_3d_mode
Kodi goes into reboot loop with this error.
LibreELEC-S912.arm-8.2.4-Chroma.444.img.gz
Using SDCard
This new S912 Krypton version in the following folder should fix the ppmgr_3d_mode error.
There are also new kszaq S912 compatible device trees that are needed for GPU Overclocking.
S912-Krypton-v8.2.4-AML folder
That is as far as my support for personal releases goes.
Thanks wrxtasy, what does this mean?
Which builds do you support for the U9?
Hey bro im using LibreELEC-S912.arm-8.2.4-Chroma.444.img.gz, shall i go ahead and replace it all with the new version you posted? is that an update for it?
I just installed the new version and its running much better.
LibreELEC-S912.arm-8.2.4-Oclock-GPU.img.gz
Just rename the dtb. Its intended for the U9+gigabit eth
Hi. Can I make a backup LE (from settings menu) in the s905x-box and restore it to the s912-box?
The S912 build in the folder I just posted. It's for all S912 boxes.
As usual just pick the correct .dtb for your particular S912 box and rename to dtb.img for 792MHz GPU Overclocking usage.
