  • Looking forward to trying this on my Wetek Hub when it arrives. Thanks for sharing your hard work.
    Wetek Hub S905 1Gb/8Gb | Sandisk Ultra 16 Gb class 10/UHS-1 A1 | v8.2.3.1 | Pioneer VSX-923-K | LG 55LM760S
    Wetek Hub S905 1Gb/8Gb | Sandisk Ultra 16 Gb class 10/UHS-1 | v8.2.3.1 | LG 42SL8000
  • I'm using sd card version and I do not know if it's right, but when I playing full HD video using quasar (8gb average) the device is moving very slowly. Each click responds only after half a minute.
    My sd card: SanDisk class 10 16gb.
    Did you set the quasar video caching directory in the add-ons settings to a non Fat32 partition, has to be an EXT formated partition. You can use the video directory of your home folder of your SD Card that way quasar can cache Whatever video you're watching because if you don't it's going to Cache that video onto your Memory..
    SentFromMyLinuxMintPhone
  • Did you set the quasar video caching directory in the add-ons settings to a non Fat32 partition, has to be an EXT formated partition. You can use the video directory of your home folder of your SD Card that way quasar can cache Whatever video you're watching because if you don't it's going to Cache that video onto your Memory..
    Be carefull with that advice.
    It will throw error over 4.1gb files. He's playing 8gb files with no errors.
    It is Lack of available RAM . Try to get to system info( it wont be easy) whilst playing.
    You will see available ram will be down to around 100mb even less.
    You will get a lockup as well.
    Been there done that.
  • Did u not read correctly what I wrote, I said non FAT32... Formatting to FAT32 will give you errors on files larger than 4gb. That's why I suggest ext4....
    What I've done was format a 32gb. USB stick to EXT4 and set the Quasar caching directory to the USB stick connected to my Android box.. like so:
    Its been working great on my K1 plus 1/8th of Ram device so far no error's on my end. But thats just me..
    Good Luck on you End.... [THUMBS UP SIGN]
    Edited once, last by Nemsis72 ().
  • My sd card has 3 partition :
    1. 1gb fat32.
    2. 13gb ext4.
    3. 1gb Linux swap.
    set the downloads folder to 13gb ext4.
  • I installed LE on a Beelink M18 (S905/2GB/16GB) and it's running good and very stable.
    I only want to notice 2 problems I have:
    1. As other users, I also have problems with HDMI negotiation. My device is conected to a TV through a receiver. The TV is a little old Panasonic plasma and it's not FULL HD, but it accepts 1080p signals. So I usually configure KODI to 1920x1080/50 and it works ok with other devices (e.g. a S805/MXQ clone with LE). But if I do that with the M18/LE, I always have problems when I disconnect and connect the device from the TV. Each time I swicth off/on, the resolution changes and the image gets distorted. The only resolution that doesn't change is 1280x720/60.
    2. I use MySQL for my music/video libraries. The server is a Win10 machine and it's always on, with some KODI clients accesing the database. After installing LE on the M18 I have to reboot the device many times (sometimes only 2 times, sometimes even 8 times) to get connected to the database. Most of the times, in the log there are messages like this: "ERROR: Unable to open database: MyMusic56 [2003](Can't connect to MySQL server on '192.168.2.101' (101))". I tried enabling the LE option "wait for network before start", but nothing changes. I've raised the wait time from 10 to 25 seconds, but it does nothing. The device is connected by cable (no WiFi) like the other devices (all the others work perfect).
    I hope it can help to improve these fantastic builds. Thanks.
    Edited once, last by felixob ().
    I use a mini m8s, everything work fine with 003.
    It's installed on sdcard, so I can 3asily back to android.
    WiFi, Network, h264 and h265 video, remote and an old mce IR Receiver (for Logitech Harmony) ... No problem.
  • About question 2
    Go to LE configuration/network/wait for network before Kodi starts, and set it to 10"
    Had the same problem
    Edit:just saw that you already tried that..Have no clue now..
    Sent from my iPad using Tapatalk
    Edited once, last by Gasoliner ().
  • Hey all... so far this is a great universal build for le on S905 devices.
    Tested so far....
    Minimx 1gb/8gb ---- runs perfect on sd method (img.gz file) and flashed to nand via extracting .zip files to sd and using toothpick method.
                                  This is not working properly.. i just noticed on video playback same issue as with the Spot i7
    Spot i7 1gb/8gb ---- sd method will not work as the Spot i7 has no reset button for toothpick method.
    ---- flashed .zip files on sd via update program within andoid/myapps... works perfect not quite see image below...
    This happens on playback from any addon, any video, and i have disables hw accel.. still same thing..
    Any advice?
    Also to note.
    *when i try to changes resolution to 1080p it reverts back to 720p
    ** LG television 29MN33D
    Edited once, last by Deezel ().
  • I can get my boxes to boot via SD - Mini MX 1G and 2G no problem. However, I have an MXQ Pro for a friend and cannot for the life of me get it to work. I've used toothpick and ADB but it wont take. Has anyone had this problem with this box?
  • 7.0.2.004 Work-in-progress build 004
    7.0.2.004
    Commits from 7.0.2.003 to 7.0.2.004: Comparing 7.0.2.003...7.0.2.004 · kszaq/LibreELEC.tv · GitHub
    Kernel commits from 7.0.2.003 to 7.0.2.004: Comparing 9ed7c5b...012fbcb · kszaq/linux · GitHub
    Changelog:
    • Mali driver updated to r6p1
    • added amvideocap kernel fix
    • fixed CPU temperature reading on some devices
    • added patches to solve some resolution switch issues
    • updated remote.conf remapping script with a few new mappings
    • added 2 missing firmwares to Bluetooth firmware loader
    • added 2 missing 3D support patches from Koying (SPMC)
    • added HPD check fix patch to Kodi
    • enabled ZRAM for a little bit less memory issues
    • tweaked default CEC parameters (applies to new installs)
    Unfortunately reboot/poweroff issues have not been fixed yet and memory management issues may be still present. List of unknown issues remains the same.
    Important announcement: I will be on holidays for the next 2 weeks (until 3 August). That means no support and updates from me. Development will resume and I hope to bring you more updates and fixes.
    I would like to remind my request for bug reporting: I wrote guidelines to make bug reports easier to categorize for both users and developer(s). Sadly hardly anyone followed the guide. Please make use of it: LibreELEC
  • - mouse button is working in Android and Openelec, it's weird that in LE did not work (and only for me, as I can see).
    I tried that other file, enabled mouse button, it worked properly, but after disabling mouse, did not work long push for other buttons.
    - mounting internal memory: Thanks, that worked.
    - about video output: Too bad, I am more familiar with X, EGP is totally unknown to me.
    In android I managed to get some results with "wm size", but wasnt satisfactory.
    I have this box and was unable to get it to boot from SD. I had no trouble flashing it to the box, but I lost H.265 support.
    Scratch that.... H.265 is now working again. Not sure what happened. Did a hard reset and a reinstall.
    Edited once, last by tommymsw ().
  • Enjoy the holidays, i will create a new bug thread for the below issue which still occures on 004.
  • kszaq
    7.0.2.004 I just noticed gone back to the default CPU governor set to hotplug. ?
    Not sure of the reason.
  • seems 7.0.2.004 made my MiniMX-G 2/16 p200_2G internal bluetooth work ... coincidence ? anyway : thanks & enjoy holiday
    player : Mini MX-G p200_2G & Inphic Spot i7 PRO p212 & Khadas VIM2 q200
    monitor : iiyama ProLite E2283HS
    speaker : UE Boom 2
    dvb-t : PCTV microStick (79e)
    firmware : android | LE 64bit | balbes 3in1 | gentoo
    Edited once, last by Nofan Tasi ().
  • I had the same issue with nand version on my minimx 1-8, as you can see here: LibreELEC
    For now I've solved using the SD versione that seems not affected by the problem.
    I'll try with the last build.
    PS. I've LG tv too
