After installing the .010 version when I turn off my Beelink Mini MX III, restarting it stays in the Beelink logo and will not boot. If I remove the Ethernet cable, sometimes it starts, but often not. I have reinstalled the 009 and everything returns to normal. What can I do to make the 010 work well?
Thank you
I have exact the same box and everything is working fine. Upgraded by update folder from 9 to 10
I think it can be because i made earlier the fresh install of 09 build. to which i had some troubles upgrading by update.
I would recommend fresh install of android build back to the box and after that install cleanly the version 10 of libreelec. Thats worked for me earlier when upgrade to 09 didn't worked.
