On the latest odroid C2 build there is no hdmi audio or am i missing something?
balbes150 -
April 24, 2018 at 1:26 PM -
Closed -
I have the hardware X96 max with the S905x² in 4GB/32GB variant, LAN wired. Which file is running and which dtb?
Thank you very much!
CT
Another test with s905x2 this time with a Tanix T5 Max
I leave images of the motherboard: MEGA
Wifi: RTL8822DTB: meson-g12a-x96-max.dtb
Wifi KO
Wired OK manual but don´t work
Sound OK
Remote KO
DTB: meson-g12a-x96-max-rmii.dtb
Wifi KO
Wired KO
Sound OK
Remote KO
DTB: meson-g12b-odroid-n2.dtb
Wifi KO
Wired KO
Sound KO
Remote KO
DTB: meson-g12a-u200.dtb don´t boot
Wifi
Wired
Sound
Remote
DTB: meson-g12a-sei510.dtb
Wifi KO
Wired KO
Sound KO
Remote KO
I wish posters would include information that would be useful to others such as
image used
dtb used
ram/rom
NIC speed
In that way some comparison might be possible for others such as myself trying to figure out what might or might not work on my hardware.
Thanks.
CT
Have you tried an image from here?
https://yadi.sk/d/dhepyyrcterlf/leia-18/kernel_5.x/20190521/amlg12_s905x2
and specify the dtb in the .ini file.
Wifi KO
Sound OK
Remote KO
Wifi KO
Wired KO
Sound OK
Remote KO
Wifi KO
Wired KO
Sound KO
Remote KO
Wifi
Wired
Sound
Remote
Wifi KO
Wired KO
Sound KO
Remote KO
Works in tanix tx6?
REVIEW: Tanix TX6 with Allwinner H6 SoC and 4GB of RAM | AndroidPCtv
Works in tanix tx6?
No, this image is for amlogic (no for allwinner)
- Official Post
Works in tanix tx6?
Talk about Tanix TX6 is here: Nightly images for A64, H3 and H6 boards
У меня х96макс 4/32. Последняя сборка от 05.24 не началась. Запущен с заменой dtb от 05.12. Звук есть, но только 2.0. AV-ресивер DTS 5.1 долго не может определить, но после определения звук очень плохой. Если дорога до DD 5.1 отправляется транзитом через ресивер к телевизору - есть звук. На ресивере - звука DD 5.1 нет. Во всех этих случаях звук прерывается на короткое время, доли секунды, с интервалом 5-10 секунд. Видео имеет проблемы с перемоткой. А также кодек h265 убивает систему. Vp9 на 1080p работает хорошо, но 4k замедляется. Перезагрузка не работает, только обесточивания устройства делает перезагрузку.
Can anyone confirm this?
Звук пока работает только в 2.0. Транзит по идее работать не должен вообще. Видео в H.265 часто 10-битное, и это тоже не поддерживается. Сборки в этой теме только для тестов, для ежедневного использования они не подходят. В следующий раз, пожалуйста, пишите на английском. Можно переводить с помощью deepl.com.
The mainline kernel is support for outputting correct MaxFALL/MaxCLL HDR metadata and HDR10+?
No. Intel is still working on kernel HDR support More HDR Display Bits On The Way For The Linux 5.3 Kernel - Phoronix Everyone else is waiting to follow their steps.
No. Intel is still working on kernel HDR support ....
Intel is also working on S9xxx SoC?
Core functionality for HDR Static Metadata should land in v5.3, and was made by Intel. dw-hdmi HDR metadata support for Allwinner, Amlogic and Rockchip has already been posted to mailing list: DRI devel - Patchwork
Yes, I used the version "LibreELEC-AMLGX.aarch64-9.1-devel-20190526155114-a41fdf1-box.img.gz" with the dtb "meson-g12a-x96-max.dtb", which I entered in the *.ini file. Is all this correct?
image used
dtb used
ram/rom
NIC speed
Thanks.
Registered just because i could relate...
Hoping to contribute to a more extensive overview, here are my test results:
- Vontar X96 Max
- S905X2/u211 SOC
- G12A chipset
- 10/100mbit NIC
- No bluetooth module
- 2gb/16gb version
- 2,4ghz wifi b/g
(aka: the dirt cheap version)
Image: LibreELEC-AMLG12.arm-9.1-devel-20190521095752-a41fdf1-box.img.gz
DTB: meson-g12a-x96-max-rmii.dtb (the more recent one posted by balbes150 which now resides at the root of the "kernel_5.x" folder of the yandex disk)
Results:
Boots just fine
Ethernet working, gets IP through DHCP just fine
Audio only shows bluetooth pulse, no audio over HDMI
No WiFi
No remote
Hello,
I didn't expect these builds to be prime time and nobody said they are. This is true, however they run really smooth and most things are working actually at least somehow. So kudos for these builds, looks really promising.
Setup:
- Odroid C2
- currently C2-build from May 26th for arm (kernel: 5.1.0)
- copied .kodi and .config from 3.14-stable build (however I also tested most things without this, IR being the exception)
- from SD card
Observations:
- no hdmi output when cold booted; turning the TV off and on fixes this problem
- HDMI audio works
- CEC often doesn't work (currently doesn't at all)
- IR produces double presses or often also queued (second) presses, meaning they are executed once a new button is pressed leading to unexpected behavior
- aspect ratio for 720x576(16:9) PVR content is wrong (pixel ratio wrong)
- software decoding for MPEG-2 and Xvid doesn't work (AVC does)
