Hi. I updated my WetekPlay2 key config: LE9.0 remote configs ir-keytable Amlogic devices
Now works much better
Could someone please tell me the relation between remote.conf file and actions in kodi?
I'm using a harmony one plus remote, configured as "minix u9" and a matching remote.conf (I guess).
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
factory_code = 0xfe010001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 50
release_delay = 100
debug_enable = 1
left_key_scancode = 0x47
right_key_scancode = 0x15
up_key_scancode = 0x46
down_key_scancode = 0x16
ok_key_scancode = 0x55
key_begin
0x47 105 #DPAD_LEFT
0x15 106 #DPAD_RIGHT
0x46 103 #DPAD_UP
0x16 108 #DPAD_DOWN
0x55 97 #ENTER
0x40 1 #BACK
0x04 125 #MENU
0x14 115 #VOLUME_UP
0x10 114 #VOLUME_DOWN
0x0d 102 #HOME
0x18 116 #POWER WAKE
0x12 243 #SETTING_MENU
0x20 131 #ZOOM_OUT
0x21 130 #ZOOM_IN
0x22 217 #SEARCH
0x23 113 #VOLUME_MUTE
0x24 208 #MEDIA_FAST_FORWARD
0x25 168 #MEDIA_REWIND
0x26 164 #MEDIA_PLAY_PAUSE
0x27 128 #MEDIA_STOP
0x28 163 #MEDIA_NEXT
0x29 165 #MEDIA_PREVIOUS
0x30 2 #1
0x31 3 #2
0x32 4 #3
0x33 5 #4
0x34 6 #5
0x35 7 #6
0x36 8 #7
0x37 9 #8
0x38 10 #9
0x39 11 #0
0x41 14 #DEL
0x3a 52 #dot
0x3b 28 #ENTER
0x3c 359 #RECORD
0x3d 94 #prog1
0x3e 95 #prog2
0x3f 514 #prog3
0x41 515 #prog4
0x42 177 #pageup
0x43 178 #pagedown
0x44 23 #info
0x45 24 #guide
0x48 402 #CH+
0x49 403 #CH-
key_end
I'm using kszaq's latest stable build - 8.2.2.3
Some buttons bring up some actions within Kodi, but not always the actions they are supposed to.
How or where can I reassign the buttons?
Some hints on where to start would be appreciated.
Do you know how to bring back the context menu (long press of the "ok" button) in LE9?
Hey guys, i recently tried the 8.90.5 build. I did a fresh install over the previous 8.2 build. What i instantly noticed is that the IR remote is very sluggish and double/triple repeats sometimes. I did not have this issue in the 8.2 stable build, where my IR remote was working flawless and responsive.
Device: Tanix TX3 Mini
I did, and it says in that post that the remote config for my device has already been baked into the image. So im not sure what else to do
Also please read LE9.0 remote configs ir-keytable Amlogic devices
Further tweeks
Read the opening page 1.
I already tried "ir-keytable -D 375 -P 100" and "ir-ctl -t 50000" if that's what you mean. It made no difference, except now it repeats even more on every key input, and still very sluggish and unresponsive.
EDIT: The sluggish and delayed key inputs seem to affect only the up/down/left/right keys. The ok/home/back/menu buttons are still snappy and responsive.
Another knob you can turn to improve remote response is the idle timeout. By default it's set to 200ms on Amlogic / meson-ir, which is quite long - other IR receiver drivers use 125ms.
So I upgraded to 8.90.6 alpha on my Mecool m8s pro+ box (used LibreELEC-S905.arm-8.90.6.img.gz file) onto external microSD card. And the remote does not work. Updated the dtb.img tree to the latest from the update directory (gxl_p212_2g.dtb). Also renamed that file to dtb.img. But the remote still does not work. So maybe it is not baked in as per previous version. I then tried to create the keymap and rc_map.cfg file.
SSH into Libreelec and stopped kodi and LIRC in SSH successfully.
Ran "ir-keytable -t" command and got the following message -
"/sys/class/rc/: No such file or directory
No devices found"
Checked using Winscp and true enough there is no /sys/class/rc directory. Obviously I also cannot create that directory manually. Any help or suggestions?
Display MoreSo I upgraded to 8.90.6 alpha on my Mecool m8s pro+ box (used LibreELEC-S905.arm-8.90.6.img.gz file) onto external microSD card. And the remote does not work. Updated the dtb.img tree to the latest from the update directory (gxl_p212_2g.dtb). Also renamed that file to dtb.img. But the remote still does not work. So maybe it is not baked in as per previous version. I then tried to create the keymap and rc_map.cfg file.
No devices found"
The mecool remote configuration is still integrated into the image
No devices found means you are not using the correct DTB
I'm guessing you have LE installed on internal?
Adamg - thanks for your builds and keep up the good work
Sorry - I edited the post later to say that I have it installed on microSD card. I dont know which other DTB to use. The Mecool m8S Pro+ that I have is definitely S905X chip and it is also definitely 2GB RAM - I checked in previous versions of your alpha build. The other DTBs are for kvim, lepotato, nand, slowemmc - none of which describes my player.
Any suggestions. Does the error message also suggest incorrect DTB? Also of note is that the CEC still works, so I can still control using the TV remote
Thanks.
An update
Yes I downloaded the DTB from that directory. I also downloaded all the 2GB DTB and the generic 1GB and 3GB DTB and unsuccessfully tried them all. On some of the DTB, it would not even boot up pass the Mecool screen, so I can assume that the DTB is being overridden
So I finally re-wrote the 8.90.6 image to a new microSD card and the remote worked straight away. Looks like the update process from 8.90.5 to 8.90.6 (via placing the newest in the update directory) must have messed something up. I re-did the update 3 times, each time unsuccessfully.
One message that I got during the update process - "Dirty bit is set. Fs was not properly unmounted and some data may be corrupt. Automatically removing dirty bit". Maybe that affected the update process.
TL:DR - If having a problem (whether remote or TVheadend) after updating to latest, best to start from scratch
Possibly, I have seen that error message myself before.
I'm happy to hear you got it sorted anyway.
As much as I would like upgrading to work seamlessly, it is not always possible, especially with the Alpha releases there has been too many changes recently.
it needs the timing adjusting otherwise you get double clicks,this is achieved with
# ir-ctl -t 50000
the post below lists how to make it survive restarts
autostart.sh should work, but it' be better to create a udev rule for that. Copy /usr/lib/udev/rules.d/70-input-repeat.rules to /storage/.config/udev.rules.d, and then add this line at the end (all in a single line, after the LABEL="end" line):
CodeACTION=="add|change", KERNEL=="lirc*[0-9]", DRIVERS=="meson-ir", RUN+="/usr/bin/ir-ctl -d $devnode -t 50000"
