  • Sorry, in this thread is no support for vdr. We use only LE 9.0 updates from LibreELEC sources. For support use PVR & DVB Support or Bug Reports.
    Tvheadend is preffered server by me.
  • belaid38  afl1 I think I will mark vdr as broken so it is no longer built and remove it from the repository until it gets updated.
    I know CvH has or had an update for VDR pending to be merged with LE however I'm unsure if this addresses the issue mentioned so I think moving forward it is best to remove it and encourage uptake of tbh.
  • i guess I broke something and don't now how :(
    my screen just keeps black after the libreelec-screen,
    last log entry seems to be the problem:
    ERROR: Couldn't load font name:__splash__ file:/usr/share/kodi/media/Fonts/arial.ttf
    but:
    ls -al /usr/share/kodi/media/Fonts/
    total 5255
    drwxrwxr-x    2 root     root            74 Dec 31 18:42 .
    drwxrwxr-x    3 root     root           173 Dec 31 18:42 ..
    -rw-rw-r--    1 root     root        633604 Dec 31 18:42 DejaVuSans.ttf
    -rw-r--r--    1 root     root       4641248 Dec 31 18:42 arial.ttf
    -rw-r--r--    1 root     root        105344 Dec 31 18:42 teletext.ttf
    using 8.90.1 on my S905X box.
    any ideas?
    thx!
  • Try and redownload and reflash the image it looks like something may have got corrupted.
    thx for the fast reply!
    did that three times already :(
    but I guess I should rewrite the SD and just copy over my userdata...
  • Try to upgrade to CvH 2.3.8 version: service.multimedia.vdr-addon-9.0.107.zip
  • Thanks to all the developers who give their time for these great builds :saint:
    I have a couple of S905 boxes and started playing with a DVB-T2 stick
    With kszaq's build on a 'X95mini' box the tuner gets automatically recognised, see here....
    LibreELEC (community): 8.2.2.3 (S905.arm)
    LibreELEC:~ # dmesg | grep dvb
    [ [email protected]] usb 1-2: Product: dvbt2
    [ [email protected]] usb 1-2: Manufacturer: astrometadvbt2
    [ [email protected]] usb 1-2: dvb_usb_v2: found a 'Astrometa DVB-T2' in warm state
    [ [email protected]] usb 1-2: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
    [ [email protected]] dvbdev: DVB: registering new adapter (Astrometa DVB-T2)
    [ [email protected]] dvbdev: dvb_create_media_entity: media entity 'dvb-demux' registered.
    [ [email protected]] dvbdev: dvb_create_media_entity: media entity 'Realtek RTL2832 (DVB-T)' registered.
    [ [email protected]] usb 1-2: dvb_usb_v2: schedule remote query interval to 200 msecs
    [ [email protected]] usb 1-2: dvb_usb_v2: 'Astrometa DVB-T2' successfully initialized and connected
    [ [email protected]] usbcore: registered new interface driver dvb_usb_rtl28xxu
    [ [email protected]] rc rc0: lirc_dev: driver ir-lirc-codec (dvb_usb_rtl28xxu) registered at minor = 0
    LibreELEC:~ #
    But with this 8.90.1 build on a Nexbox A95X the stick doesn't get detected. Any ideas?
  • You need to install crazycat for dvb drivers, it says on the first post :)
  • Hi, can I use this one H96 Pro Plus, please? The title includes S912 but there is no device tree for it using the link provided.
    H96 Pro+ CZ-S32-V5 BLUE
  • The title includes S912 but there is no device tree for it using the link provided.
    download.recurser.com
    Top folder dtb.
  • Libreelec repository under services - is there a link, please, since I am not sure I understand what exactly is a LE repository
