GDPR-2 I could delimit the freezes of Amazon (and maybe netflix, I dont use it). The Problem is that the build freezes when Inputstream has to switch in SW mode. Amazon changed some things of DRM and few movies you can still play in HW (like the Hobbit - this works!), but most of the catalog now is only playable in SW mode. The build crashes when kodi has to switch. Maybe its related to inputstream addon, since I can play my local storaged movies in SW.
GDPR-2 -
October 20, 2017 at 4:01 PM -
Closed -
I testet Amazon VOD with a RPI3 with LE9 Milhouse Build and with a S905X Box with the new Build of adamg.
The Raspberry played "Spectre", the S905X freezes.
Anyone tested netflix already with this build?
Netflix videos won't run, too
Display More
Great job, thanks!
Unfortunately, my remote control receiver: Genuine-SMK-Media-Center-USB-RC6-IR-Infrared-Remote-Receiver
does not work with your release.
I use the IR receiver for my Harmony 700 so that all buttons work in Kodi.
In kszaq release it works without problems.
Please, can you do something there?
8.0 differs greatly from 9.0 some USB devices can cause a problem
Can you run the following command on your box and post the results
`cat /proc/bus/input/devices` -
Display More
Hi, new release works fine , very fast boot now, but i have some strange behaviour using iptv.
I have some distortion of audio, and finally closing the stream.
03:10:18.265 T:4096053264 NOTICE: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (26) (w**ht: 0.000)
03:10:18.775 T:4071293840 WARNING: ActiveAE - large audio sync error: -89447.900397
03:10:22.870 T:4071293840 WARNING: ActiveAE - large audio sync error: -89325.506343
In others try i have more large audio sync error.
Any tip? thx!
I pushed fix for a/v syncing live tv issue. This will be fixed in the next release.
Wow amazing!! hope next one is coming, thx!!
`cat /proc/bus/input/devices`In next release will be CrazyCat driver addon corresponding to media_build used in kszaq builds.
Thanks again adamg for your quick action on fixing issues.
I have upgraded from 1.08 to 1.10 on a MiniMXIII (2 gb/16gb gigabit LAN) and got stuck in splash screen and "Migrating Addons " message.
Have rebooted (via SSH) the unit several times after waiting for more than 5-10 minutes, but I cannot get pass this screen.
Some have reported that unplugging and plugging again does fix this (have limited access to my unit). Is a hard reboot issued by SSH same as cold reboot by unplugging?
If so, any hint on how to fix this?
I have not yet tried to download, which I could do as I can access the box via SFTP.
Thank you!
A new version has been compiled and is being uploaded with the changes made by afl1 and a couple of other small fixes.
The binary addons are also being compiled and will be uploaded later. -
The binary addons are also being compiled and will be uploaded later.Can I use this build on KII Pro (which has internal DVB tuner) by changing dtb.img?
It should work fine, new build is up now
addons will be uploaded later tonight, problems with adaptive should be resolved now -
GDPR-2 you said dvb isn't supported, I thought this involved KII Pro as well. Downloading
Where can i find the addons (later)?
Great! The latest build 1.1.1 boots. Looking forward for the pvr.hts addon. Seems the only one missing.
A/v sync for 23.976 and 24 movies in adam’s current build? I m using kszaq latest build which is perfect for a/v sync. I have no need to make advance.xml for a/v sync in kszaq’s build. Any suggestion?
ı could not upload pvr.
`cat /proc/bus/input/devices`Thank you for your answer
Here the result:
Display More############################################## # LibreELEC # # https://libreelec.tv # ############################################## LibreELEC (community): adamg-1.1.1 (S905.arm) LibreELEC:~ # cat /proc/bus/input/devices I: Bus=0010 Vendor=0001 Product=0001 Version=0100 N: Name="aml_keypad" P: Phys=keypad/input0 S: Sysfs=/devices/meson-remote.11/input/input0 U: Uniq= H: Handlers=kbd mouse0 event0 B: PROP=0 B: EV=f B: KEY=7fffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff fffffffe B: REL=103 B: ABS=0 I: Bus=0010 Vendor=0001 Product=0001 Version=0100 N: Name="gpio_keypad" P: Phys=gpio_keypad/input0 S: Sysfs=/devices/gpio_keypad.48/input/input1 U: Uniq= H: Handlers=kbd event1 B: PROP=0 B: EV=100003 B: KEY=100000 0 0 0 I: Bus=0010 Vendor=1b8e Product=0cec Version=0001 N: Name="cec_input" P: Phys= S: Sysfs=/devices/virtual/input/input2 U: Uniq= H: Handlers=kbd event2 B: PROP=0 B: EV=3 B: KEY=20000000 0 0 0 0 0 0 0 0 0 0 fc004 4c00 0 0 1 4 10300 51fa 40000801 1e1680 0 100000 10000ffc I: Bus=0003 Vendor=0609 Product=031d Version=0000 N: Name="Media Center Ed. eHome Infrared Remote Transceiver (0609:031d)"P: Phys=usb-xhci-hcd.0.auto-2 S: Sysfs=/devices/c9000000.dwc3/xhci-hcd.0.auto/usb1/1-2/1-2:1.0/rc/rc0/input3 U: Uniq= H: Handlers=kbd event3 B: PROP=0 B: EV=100013 B: KEY=fff 0 0 200 10afc32e 2b76051 0 0 0 7 158000 4192 6801 9e9680 0 0 10004000 B: MSC=10 I: Bus=0000 Vendor=0000 Product=0000 Version=0000 N: Name="MCE IR Keyboard/Mouse (mceusb)" P: Phys=/input0 S: Sysfs=/devices/virtual/input/input4 U: Uniq= H: Handlers=kbd mouse1 event4 B: PROP=0 B: EV=100017 B: KEY=30000 0 7 ff87207a c14057ff febeffdf ffefffff ffffffff fffffffe B: REL=3 B: MSC=10 LibreELEC:~ # -
