Hi,
I have box X96 S905X 2GB/16GB, working with kszaqs 8.2.3.1.
Should I go to 8.90.5?
Is there any significant improvement?
Hi,
I'm still running one box with Kszaq's Jarvis 7.0.3.12 and it still works great.
My TX7 on 8.2.3.1 is my daily everyday box which works Perfect as well.
8.90 is for testing and for not for everyday use. I run it on a TX3Mini that was given to me but i only test when i get time.
I'm getting a lot of reboots with 8.90.5. Seems to happen most when stopping playback but not exclusively.
Same here on both of my boxes, playing local video from USB disk . It probably has to do with latest Kodi nightlies that have the same problem in Android. Se HERE for more info.
I am back on 8.90.4 wich works OK even on my X96-Mini_S905W box; no green or other lines or artifacts...
Hi,
I think this version has issues. Better try 8.90.4 if you feel brave to try test versions and see for yourself any inprovements.
Same here on my Mecool M8S Pro+.
I don't have any issue with 8.90.5, like on 8.90.4 and 8.90.4 dev. I try to do more tests with videos, but at the moment I don't have any reboot or freeze.
I have, on TX7 internal storage, 8.2.3.1, and 8.90.5 on microSD, and I've using it daily with Leia, no problems so far.
Maybe if you attach kodi logs, devs can try to locate the problem
Alestilohomer: This is KODI issue : Latest nighlies crashing after playback
Is AV Out (Video over Analog Output) in this build possible or only in Krypton builds?
Hi, silly question, but what dtb do I need for Wetek Play 2 for new build?
I cannot seem to find it in new dtb images?
Also, on new build (8.90.5) I cannot get TVH to work...any advice?
thanks
And if you load those addons in your last log , Don't bother posting issues or logs.
Got it! Thanks.
It appears there is an issue with the latest Kodi nightly which 8.90.5 unfortunately uses that causes Kodi to crash when playback is stopped, I am monitoring for when the issue gets fixed and will push an update as soon as it is fixed.
Wetek users will have to wait slightly longer as I still have been unable to make the new module work with kszaqs kernel and it appears the LE kernel for which the module was made for is not suitable to used widely yet.
How to disable updating? I have put in libreelec settings update manual, but every time i reboot my box it starts to update to the newer version
Strange, my boxes sometimes crash when stopping local video but not if stopping streaming content
Is this even relevant in a 8.90.5 thread?
@adamg is the ShaderToy issue a problem with these later builds that you can fix or must we wait until the developer updates the add-on?
