Hi Kszaq: your latest testing build is not responsive and hangs a lot. i need to keep restarting with power cable removed and switchig it on.
you previous build was very responsive.
kszaq Thanks for this great build, seems like really the best so far on my Wetek Hub. would it be possible to make the necessary changes to make a xiaomi bluetooth remote work out of the box? See here: Xiaomi bluetooth remote control
kszaq, I did clean installation , used (renamed) dtb file for play 2 but It won't boot. Always stuck on Libreelec bootlogo
I'm sorry, I have no WP2 to debug it. On WH everything works fine.
Update to internal nand not working
I cannot support updating from some else's builds. But it looks like the file you downloaded is corrupted. Try again.
There was no previous testing build that I published. Everything work fine here with 8.1.0.
What are "the necessary changes"? I was only able find this post: [SOLVED!] MX3 Air Mouse Remote no functioning I don't have Xiaomi remote, please first make changes that work, then ask to add them.
found another bug. My Logitech Harmony is not working with you build. If i disable the custom remote.conf the original remote works.
But the custom remote.conf works fine with the johngalt build. Very Strange.
edit: load the remote.conf with autostart.sh. Now it works.
Update from Johns 8.0.2-testing8 is possible?
worked for me, on x96 and tx3 pro both on nand.
Did a fresh install on a brand new ABOX - S905X, 2g16g with a 16g Lexar 633X SD card. Install via toothpick was flawless - it took about 30 seconds for the boot process into LE to start. The rom so far is running clean with no errors that I have seen. Thanks again kszaq a coffee is on the way.
Hi everyone!
I found a bug connected with displaying windows file share over SMB. On my PC I have a shared folder that has the following internal structure:
_LIB1 <- this is NTFS link
_LIB2 <- this is ordinary directory
.... <- a lot of files
When I'm opening this share via LE 8.2.8.1, it shows me only the _LIB2 and files, without ntfs junction. But when I've opened it by the LE 8.0 (or by other win PC) there are no problems at all. I guess it may be caused by wrong permission handling or something like this.
zbigzbig20 or Marciano are you able provide log from serial console on WP2?
i want to but don't really know how to do it
Greetings,
Dude, the kernel structure is different, can it be?
Best regards...
I suspect that the issue with WP2 is DVB driver: closed source, not compatible with Nougat kernel (yet). It's the only device with the issue.
Greetings,
No, internal DVB Tuner couldn't work.
Best regards...
