  • Hi 8.1.7 works great on my x96 box and mini m8s II. I use 16gb micro sd cards with my own build. I have some faster 32gb cards that I want to use. What is the easiest way to copy the 16gb card to the 32gb card so that I can use the full size of the card? I know I can backup the 16gb card with windiskimager and write it to the 32gb card, but than I can not use the full size of the card (only 16gb).
    Cloneilla
    Synology DS920+ Plex Pass
    Or you can simly do the backup content and settings from kodi, install fresh new card and do the restore.
  • Plays fine on my box, but i don't think thy are DV, Just normal UHD ;)
    Only the S912 chipset supports Dolby Vision. S905X and S905D are limited to HDR and HLG.
    If it ain't broken: break it, fix it, repeat
  • Tried suspend/sleep mode on my Tx5 PRO (S905X, 2gb RAM) and it doesn't seem to work.
    Is this the correct sleep.conf line for suspend/sleep mode ON?
    [Sleep]
    HibernateMode=false
  • Yes. ;)
    I've enabled 444 10bit but with 4k resolution GUI and also 10bit video (non HDR) are very oversaturated (RED is very strong). Why? I hav a 4k hisense tv with 10bit pannel (8bit+frc)
  • DS-1 Yes, this is correct. This makes suspend available in Kodi shutdown menu but not necessarily makes it work.
    Ok, it works. I didn't understand that this makes suspend available in kodi menu. I was trying via remote power button and it shutted down.
    Is there any way to remap remote power button to suspend/sleep?
  • HLG is supported by the s905x and s905d chipset, but it doesn't work on my Memobox t95n m8spro (s905x). I have a demo file which plays fine on a USB stick in the TV, but not in Libreelec.
    This is not a bug report! I know that HDR is also not supported by @kszaq's build, even though that does work. I just wanted to share the info.
  • I've enabled 444 10bit but with 4k resolution GUI and also 10bit video (non HDR) are very oversaturated (RED is very strong). Why? I hav a 4k hisense tv with 10bit pannel (8bit+frc)
    You have to turn down the color saturation on your TV about 10 clicks, when using UHD (4K) ;)
    -2re
    LG BP50NB40 USB Blu-ray
  • By default what is enable?
    8, 10 or 12?
    420, 8bit
    The standard setting is 444, 8bit - not 420.
    YCbCr 4:2:0 is not officially supported by the HDMI standard (except for 2160p50 and 2160p60).
    However, it might still work in some cases.
    Mini M8S II 2G/16G (S905X)
  • You have to turn down the color saturation on your TV about 10 clicks, when using UHD (4K) ;)
    That however is not a rule.
    There is no difference between 1080p and 2160p GUI colors on my TV...
  • Greetings,
    Dear Kszaq; The sound keys work like they used to be, so why did you turn off the autorepeat? :(
    It was very good. :)
    Best regards...
    I see the same behavior on my 10bit Hisense TV when switching to 4K as well - just have to calibrate the TV when in 4K mode.
  • I see the same behavior on my 10bit Hisense TV when switching to 4K as well - just have to calibrate the TV when in 4K mode.
    That's one of the reasons i have the box set to 2160p. Then i don't have to change settings between HD & UHD. ;)
    -2re
  • That however is not a rule.
    Maybe your TV has different profile for HD & UHD, and switches automatic when you change the resolution.
    -2re
