[9.0.0] LibreELEC builds for MX2/G18
  • For those having trouble with the NAND b0rk/120 seconds message, although it's a bit technical I've managed to fix this issue on my box, maybe temporarily but it's working again.
    Amlogic AML8726-MX HD18 v2.22 (G18ref) STB black screen no boot fix
    KOPRajs, really appreciate the backporting of LibreElec. Only issue I've had is I assume my old JVC flatscreen TV doesn't like the video mode the Matricom splash uses, the display won't fire up, but I've manage to work out an order to boot the box with cables unattached until in Kodi.
  • I installed to SDCARD and am running 20190424 without issue.
    Are you running 20190424 from internal NAND? If so, how did you manage to make this version work in NAND?
    I also updated from 20190226 to 20190424 and it broke my box. So I had to reinstall 8.0.2, updated to 20190226 and it's working from NAND at the moment.
    Edited once, last by EBAL ().
  • Boxes are just old so i don't really bother playing with them anymore, but i did update one to Kodi 18.4 on the weekend for a friend and then remembered what i had done to make them still usable...
    If the box is a Maticom box then its their bootloader that is more then likely causing the issue, tho some did have crappy nands that were known to go bad but in most cases i have come across it was Matricom's crappy bootloader that would easily corrupt when messing with it and the video setup in it was for older resolutions which some screens don't pickup till the main firmware comes up (Android)...
    I forgot that i had replaced their bootloader with my own along time ago which is why i was able to keep the system updated to begin with...
  • I have a DigiXstream DX3 - AML8726-MX, for which I am trying to install the recent libreelec builds here but am having problems. When I try the recovery method (fresh install) the installation stalls out at the Kodi screen. Like one of the previous posters (#289) I can successfully load that ancient version of OpenELEC, but when I try to update with the tar file, it begins to update and then runs into an error and kills the box. I have been able to recover by re-installing the ancient version of OpenELEC.
    I have tried both with the storage SD/USB method and also changing the setting for internal Nand storage to have LIBREELEC_DISK.
    On my storage USB, I found two log files of my attempts to install 8.0.2. The longer of the two is pasted below. There seems to be a problem with loading skin settings towards the end. Can anyone help me figure out what is going wrong?
    Many thanks!
    00:00:12.742 T:3036101248 NOTICE: special://profile/ is mapped to: special://masterprofile/
    00:00:12.743 T:3036101248 NOTICE: -----------------------------------------------------------------------
    00:00:12.743 T:3036101248 NOTICE: Starting Kodi (17.3 Git:147cec4). Platform: Linux ARM 32-bit
    00:00:12.743 T:3036101248 NOTICE: Using Release Kodi x32 build
    00:00:12.743 T:3036101248 NOTICE: Kodi compiled May 30 2017 by GCC 6.2.0 for Linux ARM 32-bit version 3.10.99 (199267)
    00:00:12.743 T:3036101248 NOTICE: Running on LibreELEC (community) - Version: 8.0.2, kernel: Linux ARM 32-bit version 3.10.99
    00:00:12.743 T:3036101248 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
    00:00:12.743 T:3036101248 NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 2 cores available
    00:00:12.744 T:3036101248 NOTICE: ARM Features: Neon enabled
    00:00:12.744 T:3036101248 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
    00:00:12.744 T:3036101248 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
    00:00:12.744 T:3036101248 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
    00:00:12.744 T:3036101248 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
    00:00:12.744 T:3036101248 NOTICE: special://envhome/ is mapped to: /storage
    00:00:12.744 T:3036101248 NOTICE: special://home/ is mapped to: /storage/.kodi
    00:00:12.744 T:3036101248 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
    00:00:12.744 T:3036101248 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
    00:00:12.744 T:3036101248 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
    00:00:12.745 T:3036101248 NOTICE: Local hostname: LibreELEC
    00:00:12.745 T:3036101248 NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
    00:00:12.745 T:3036101248 NOTICE: -----------------------------------------------------------------------
    00:00:12.981 T:3036101248 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
    00:00:12.994 T:3036101248 NOTICE: load settings...
    00:00:12.995 T:3036101248 NOTICE: AML device detected
    00:00:13.132 T:3036101248 NOTICE: Found 2 Lists of Devices
    00:00:13.132 T:3036101248 NOTICE: Enumerated ALSA devices:
    00:00:13.132 T:3036101248 NOTICE: Device 1
    00:00:13.133 T:3036101248 NOTICE: m_deviceName : default
    00:00:13.133 T:3036101248 NOTICE: m_displayName : Default (AML-DUMMY-CODEC S/PDIF)
    00:00:13.133 T:3036101248 NOTICE: m_displayNameExtra:
    00:00:13.133 T:3036101248 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
    00:00:13.133 T:3036101248 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
    00:00:13.133 T:3036101248 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
    00:00:13.133 T:3036101248 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S16NE,AE_FMT_S16LE
    00:00:13.133 T:3036101248 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
    00:00:13.133 T:3036101248 NOTICE: Enumerated PULSE devices:
    00:00:13.133 T:3036101248 NOTICE: Device 1
    00:00:13.133 T:3036101248 NOTICE: m_deviceName : Default
    00:00:13.133 T:3036101248 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
    00:00:13.133 T:3036101248 NOTICE: m_deviceType : AE_DEVTYPE_PCM
    00:00:13.133 T:3036101248 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
    00:00:13.133 T:3036101248 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
    00:00:13.133 T:3036101248 NOTICE: m_streamTypes : No passthrough capabilities
    00:00:13.164 T:3036101248 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
    00:00:13.164 T:3036101248 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
    <?xml version="1.0" encoding="UTF-8" ?>
    <advancedsettings>
    <showexitbutton>false</showexitbutton>
    <remotedelay>1</remotedelay>
    <samba>
    <clienttimeout>30</clienttimeout>
    </samba>
    </advancedsettings>
    00:00:13.166 T:3036101248 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
    00:00:13.166 T:3036101248 NOTICE: Default Video Player: VideoPlayer
    00:00:13.166 T:3036101248 NOTICE: Default Audio Player: paplayer
    00:00:13.166 T:3036101248 NOTICE: Disabled debug logging due to GUI setting. Level 0.
    00:00:13.166 T:3036101248 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
    00:00:13.167 T:3036101248 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
    00:00:13.168 T:3036101248 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
    00:00:13.170 T:3036101248 NOTICE: Loaded playercorefactory configuration
    00:00:13.170 T:3036101248 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
    00:00:13.170 T:3036101248 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
    00:00:13.224 T:3036101248 NOTICE: Running database version Addons27
    00:00:14.997 T:3036101248 NOTICE: ADDONS: Using repository repository.kodi.game
    00:00:14.997 T:3036101248 NOTICE: ADDONS: Using repository repository.libreelec.tv
    00:00:14.997 T:3036101248 NOTICE: ADDONS: Using repository repository.xbmc.org
    00:00:15.087 T:3036101248 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic
    00:00:15.152 T:3036101248 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480 @ 60.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 720 x 576 for display 0 with 720 x 576 @ 50.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
    00:00:15.152 T:3036101248 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
    00:00:15.153 T:3036101248 NOTICE: Found ([email protected]) at 18, setting to RES_DESKTOP at 16
    00:00:15.153 T:3036101248 NOTICE: Checking resolution 16
    00:00:15.170 T:3036101248 NOTICE: GL_VENDOR = ARM
    00:00:15.170 T:3036101248 NOTICE: GL_RENDERER = Mali-400 MP
    00:00:15.170 T:3036101248 NOTICE: GL_VERSION = OpenGL ES 2.0
    00:00:15.170 T:3036101248 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
    00:00:15.171 T:3036101248 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
    00:00:16.210 T:2948588448 NOTICE: Running database version Addons27
    00:00:16.216 T:2948588448 NOTICE: Running database version ViewModes6
    00:00:17.417 T:2948588448 NOTICE: Running database version Textures13
    00:00:17.442 T:2948588448 NOTICE: Running database version MyMusic60
    00:00:17.476 T:2948588448 NOTICE: Running database version MyVideos107
    00:00:17.483 T:2948588448 NOTICE: Running database version TV29
    00:00:17.489 T:2948588448 NOTICE: Running database version Epg11
    00:00:17.499 T:3036101248 NOTICE: start dvd mediatype detection
    00:00:17.563 T:3036101248 WARNING: CSkinInfo: failed to load skin settings
    00:00:18.213 T:3036101248 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
    00:00:18.588 T:3036101248 NOTICE: initialize done
    00:00:18.588 T:3036101248 NOTICE: Running the application...
    00:00:18.606 T:3036101248 NOTICE: starting zeroconf publishing
    00:00:18.608 T:3036101248 NOTICE: CWebServer[8080]: Started
    00:00:18.609 T:3036101248 NOTICE: starting upnp client
    00:00:18.627 T:2831147936 NOTICE: ES: Starting UDP Event server on port 9777
    00:00:18.640 T:2831147936 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
    00:00:19.405 T:2898256800 WARNING: CSkinInfo: failed to load skin settings
    00:00:20.167 T:2898256800 ERROR: ## LibreELEC Addon ## oe::load_url(releases.json) ## ERROR: (URLError(gaierror(-3, 'Temporary failure in name resolution'),))
    00:00:20.168 T:2898256800 ERROR: Traceback (most recent call last):
    File "/root/LibreELEC.tv/build.LibreELEC-Amlogic_MX2.arm-8.0.2/LibreELEC-settings-6336f1e/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/oe.py", line 271, in load_url
    File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
    File "/usr/lib/python2.7/urllib2.py", line 429, in open
    File "/usr/lib/python2.7/urllib2.py", line 447, in _open
    File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
    File "/usr/lib/python2.7/urllib2.py", line 1228, in http_open
    File "/usr/lib/python2.7/urllib2.py", line 1198, in do_open
    URLError: <urlopen error [Errno -3] Temporary failure in name resolution>
    00:00:20.423 T:2787111840 ERROR: ## LibreELEC Addon ## oe::load_url(updates.php?i=e5c1259d1881879eac504d8f823c8b81&d=libreelec&pa=amlogic_mx2.arm&v=8.0.2&l=0
    00:00:20.424 T:2787111840 ERROR: Traceback (most recent call last):
    File "/usr/lib/python2.7/urllib2.py", line 1241, in https_open
    00:00:20.429 T:2787111840 ERROR: ## LibreELEC Addon ## system::check_updates_v2 ## ERROR: (TypeError('expected string or buffer',))
    00:00:20.430 T:2787111840 ERROR: Traceback (most recent call last):
    File "/root/LibreELEC.tv/build.LibreELEC-Amlogic_MX2.arm-8.0.2/LibreELEC-settings-6336f1e/.install_pkg/usr/share/kodi/addons/service.libreelec.settings/resources/lib/modules/system.py", line 768, in check_updates_v2
    File "/usr/lib/python2.7/json/__init__.py", line 339, in loads
    File "/usr/lib/python2.7/json/decoder.py", line 364, in decode
    TypeError: expected string or buffer
    00:00:20.452 T:2749887392 WARNING: CSkinInfo: failed to load skin settings
    00:00:20.521 T:3036101248 ERROR: Control 1500 in window 13001 has been asked to focus, but it can't
  • I haven never been able to get audio passthrough option available with kodi18.
    It was always there on every previous build used on my mx2.
    This week I went back to 17, there it was! Upgraded to 18... gone.
    Plenty of threads on google about this, tried all solutions but none work. Have tried both hdmi and optical from box, but mx2 running running libreelec with kodi18 will not show audio passthrough option.
    Anu suggestions?
  • I've managed to get it working (sort of) mx version 1, installed it on sdcard. But having some problem with 8.0, wifi related or something. Lots of waiting when adding apps and most time it doesnt work, it doesn't get installed. The Network options in the libreelec options are emty so i cant even change wifi if i wanted to (and need to because i setup on guest wifi which is separated from my nas). With the first boot i could setup wifi, now not anymore. It was a faulty sdcard, now with usb drive works good.
    I would prefer it on NAND, but now I read if u want on NAND you must do it before upgrading, so now to late or do i misunderstood the line? Can it still be done with every new installation? (Maybe I just dont understand and it is already on NAND? Didn't see activity on usb stick light while booting, but without usb stick it wont boot.)
    I also don't understand if i want to try higher version i have to update or can i just flash/install the rom i want through the toothpick option?
    The instructions link is not working so its kinda hard for new people to step in. ( Support Hub | G-Box Support | G-Box Help | Matricom )
    Edited 2 times, last by TiaMaria ().
  • Hi @KOPRajs, I was wondering if you could look into an issue. I have a Matricom MX2 and with the 20190424 build, the fast forward (right arrow key) always causes the box to freeze. Has anyone also encountered this issue? I switched back to 8.0.2 and everything runs fine. Could you please take a look? Thanks.
    Try disabling the hardware acceleration in settings > player. Some streams seem to crash the hardware decoding, although disabling this can make HD streams struggle.
  • Good news for anyone (like me) having issues getting their remote working with this libreelec build, I've got mine working. This has been really confusing because of the recent adoption of LIRC in libreelec, but it isn't used in this build.
    Based on information from this page; http://www.microdev.it/wp/en/2…ibreelec-on-amlogic-socs/
    My remote.conf file which is based on the /etc/amremote/libreelec.conf present in this libreelec;
    This file belongs as /storage/.config/remote.conf
    after it's been copied there in SSH type;
    remotecfg /storage/.config/remote.conf
    It's early days and I've not completely mapped the keys for my generic Android/NEC remote, any keys not recognised by the system should be logged in the system log (dmesg -c)
    You only need the remote.conf override and not rc_maps.cfg, lircd.conf or whatever to get this working. Did a lot of digging to find this info., but I thought I'd share it.
    Edited once, last by qUE-ARM: update ().
  • @KOPRajs, I'd really like to have a go at building whatever libreelec last supported meson6.
    I get the copy your source over the libreelec mainline, but I can't get it to build.
    I'm using ubuntu, any chance you could list what dependencies are needed, I've got build-essentials so far, but it's not clear what else is needed, the errors don't hint at what else needs to be installed. And I suspect the info on the official wiki doesn't account for the amlogic hardware.
    Do I need gcc-arm-none-eabi?
  • I've had this box running well for a few years now with 9.0.1 & kodi 18.1, but I did a reset/clean this week, it works fine with 7.95.3 & kodi 17, as soon as i update to 9/k18, I lose all ability to instal, cannot even download a new skin, no SMB , just no connections.
    Have a new box and want to keep this for another spare tv.
    Gotta b something simple.
    Any advise?
  • I currently have 9.0.1 & kodi 18.1 running since this was the combination that worked well. I manged to get Samba working finally but this is to do with the SMB setting I played around with.
    I attempted the instruction on the other thread, as this sounds like my issue - zip files work - but not from repositories and no skins installing
    EDIT: I have given up and will just put kodi17 on this box and use for samba, no idea why 18 wont work suddenly after years.
    oh well, pity as box has been good and still works.
    Any advise?
    I've had issues like this when the permissions have been changed on /storage, I'd do the 7.95.3 factory AV "toothpick" install then, do the tune2fs with SSH (this will also break /storage if not done) and upgrade to 9.0.2 (just copy the tar archive into /storage/.upgrade and reboot)
  • I've had issues like this when the permissions have been changed on /storage, I'd do the 7.95.3 factory AV "toothpick" install then, do the tune2fs with SSH (this will also break /storage if not done) and upgrade to 9.0.2 (just copy the tar archive into /storage/.upgrade and reboot)
    Thanks, yes I have tried multiple times, it just will not work with kodi 18 anymore :(
    EDIT: Finally fixed, it was the the same issue as Cannot Install/Update Addons afterall
    Edited 2 times, last by P.Frink ().
