Hello community . Does anyone have a remote.confg for the ZOOMTAK. Thanks in advanced
remote.conf repository
zorrua -
January 27, 2017 at 1:22 PM -
Hi,
I’m new here. Can you help me, please, with a Minix Z64A remote control. It is the most basic control of Minix. After installing LibreElec on a flash drive, everything is fine, except the remote control. I can’t get my remote to work at all. Can you help me with this problem. What is the correct “remote.config” file for this IR Remote, and the correct procedure to make it work?
Thank you!
Rui -
Hi,
Thank you!This has a 2.4ghz dongle? it should just work. There could be interference from your 2.4 wifi band, try turning wifi off
I've tried but nothing.
i'm using the last version of LibreElec 9.2 (Kodi 18.7.1). The place to put the remote.config file is the same on this version?
Does this have a dongle?
If not, you need to try to configure it yourself, as was suggested on the CE forum
No it doesn't have a dongle.
I found a file in android directory of the box (Android KitKat) called minix-remotectl.kl, and it's like this:
key 28 ENTER
key 116 POWER WAKE
key 158 BACK
key 139 MENU
key 217 SEARCH
key 232 DPAD_CENTER
key 108 DPAD_DOWN
key 103 DPAD_UP
key 102 HOME
key 105 DPAD_LEFT
key 106 DPAD_RIGHT
key 115 VOLUME_UP
key 114 VOLUME_DOWN
key 113 VOLUME_MUTE
key 402 MEDIA_PLAY_PAUSE
key 88 MEDIA_NEXT
key 87 MEDIA_PREVIOUS
key 141 SETTINGS
Does it help?
key 28 ENTER
key 116 POWER WAKE
key 158 BACK
key 139 MENU
key 217 SEARCH
key 232 DPAD_CENTER
key 108 DPAD_DOWN
key 103 DPAD_UP
key 102 HOME
key 105 DPAD_LEFT
key 106 DPAD_RIGHT
key 115 VOLUME_UP
key 114 VOLUME_DOWN
key 113 VOLUME_MUTE
key 88 MEDIA_NEXT
key 141 SETTINGS
Does it help?
see my post in the CE forum. I read both forums, but just reply in the CE forum, that is where the guide is, as you know.
Working remote conf file for Minix U1 Remote. i noticed a reboot was necessary after making changes for it to take effect.
Hello,
It is possible to make a remote.conf repository?
It will great to have a folder to all remote configuration.
I am looking for Mini M8S II device. Anyone could share it?
Regards.
Sorry, it took like 3 years but here we are:
Repository for AmRemote & Meson_IR Remote ControllersI will also try to request permission from the moderators to create a sticky post for the repository.
- Official Post
Anything in a Mega share controlled by one person is a "personal archive" not a "public repository" so we should avoid sticky links. Put the content in GitHub or similar and you have version control, the ability for others to contribute changes and new device content, and you can share the ownership and long-term management of the repo with others (less work for you, and others). If you restructure the repo using device-tree names or something similarly programmatic (but still simple for users to follow) instead of the multi-level A-Z format it becomes possible and easy to consume the content within distros which can make it easier for users.
First time poster...spent about a week working on one for the Zoomtak T8 Plus using the LibreELEC-n200-AP6330_2G.arm-9.2.8.3.img.gz software image. First on SD card then to internal storage replacing factory Android 4.x.x.
Just missing Setup, Zoom, AV/V, Audio & 16:9.
I'm curious about the remote code numbers like 116=poweroff(although I'm using 20) and 113=mute. They look like they can go 400+ but the Linux/LibreElec list is only 40. Through pure random entering I found 10 sec/min skip forward/backward and mapped those to the colour buttons. Are they specific to the boxes?
Hello All,
I picked up this remote due to its simple design and tried searching for the config without success. Would anyone happen to have the remote configuration for this remote? The description for this remote is as follows.
Original Replacement Remote Control - Android TV Box Controller for H96 MAX, MX10,MXQ, MXQ Pro,T95M, T95N. T95Q. T9. T95X mx9 H96 pro+ tx3mini tx3max x96mini X96 x96max (H)
Why not create your own? It doesn't take long.
Here are the instructions -
Here are the instructionsTutorial worked great! Thanks!. I do have one more question. The keys all work great, however the remote requires multiple key presses sometimes when operating the remote. Is that related to an adjustment within the configuration and can I make an adjustment to fix the delay?
Some IR remote controls generate two different scan codes for the same key (when you repeat pushing it). Check with ir-keytable -t command if that's your case. Then you need to add both scan codes for the appropriate command to keymap file (so it should contain two lines for each command).
Adding those keys also to the repeat_key section should do the trick. Example:
Once it's working as should, maybe submit the file via github or post it here and I'll add it to the repository so you don't have to do this again and it's available to other users.
Hi I installed libreelec on the T95Z max S912 box but cant get remote to work. Anyone has a working remote.conf file for this? And it has to be placed in the configuration directory, right?
Dont know if it matters, but I have another box with coreelec installed on it and also the remote.conf file for it. While that works on Coreelec, I tried copying it on the LE system but that doesnt work.
