remote.conf repository
  • It´s the Linux path connected to the box
    Your picture shows smb shares
    /storage/.config is mapped to smb \\<ipfrombox\Configfiles
    I recommend ssh connection and edit remote.conf with Linux editor vi or nano
    I thought it was just a matter of downloading someone elses remote file and copying it over.
    Is there a step by step guide anywhere to do that? No interested in editing my own. Thanks
  • Am trying to copy a remote.conf in my system/etc folder on my M8S Pro L box but I get the "System is read only error"
    Is this the correct command to use?
    su
    mount -o rw,remount /dev/root
    Don't wanna screw anything up.
    su
    No ! (/dev/root is no mounted partition)
    Copy the remote.conf file to /storage/.config folder
    Other option:
    Copy remote.conf to /flash - in this case You have to remount first -> mount -n -o remount,rw /flash
  • please help
    which one here the factory my code?
  • there have been users on this forum ( zed85 ) claiming they don't experience the same issue, which is why I believe there has to be a solution that does not include trashing the whole thing
    I'm running 8.2.2.3 from SD card on H96 Pro Plus. Using the remote.conf I posted before. No troubles with powering up or shutting down the device.
  • Can you power on the box with the remotes? I have the same box and remotes, but I can not power on the box.
    I also want the power button of the mx3 remote to do nothing, because sometimes my son press that button by accident and than the box powers off. I have tried everything but maybe it is just not possible...
    Yes powering on and shutting down works. Running 8.2.2.3 from SD card.
  • got someone a "Rii MX3" Remote working on a S905 Box?
    Some Buttons are not recognized and i would map them for EPG or something...
    Edited 2 times, last by Pony (February 2, 2018 at 6:37 AM).
  • hello
    my remote control for amlogic s912 mecool km8p does not work either, I copied the file remote.conf of the official firmware in /storage/.conf but does not work someone has a solution please
  • thanks but i have a message that says "can not open / dev / aremote" when i'm doing 'remotecfg remote.conf' and then i do not have the wrong code message when i do 'dmesg -c'
