7.0.3.011 (2016-12-18)
Changelog:
- fixed LIRC in 32-bit builds (thanks to Raybuntu)
Thanks for fixing the remotes. Now I can use my MCE with the 32bit LE
From memory - When the video is playing, press <m> for menu, go to the video icon, select and then select deinterlacing and set off. At the bottom of the list, click on "set as default for all videos"
Note: this works only with hardware acceleration turned off
