Display More
Hi guys, wanted to share my latest experience with beelink S905 mini mx 1GB RAM/1Gbit eth/AP6212- I've installed to internal nand the stock 7.0.3.11 and proper dtb.img
- latest available u-boot (U-Boot 2015.01-g937dd3a (Apr 20 2016 - 11:39:18))
- i've connected the serial UART and from u-boot reinited the default boot environment:
# defenv_reserv
# setenv upgrade_step 2
# resetnow the box always boots without freezing (tested over 30 times :)).
the side effect is that i cannot get it to completely poweroff:
I've tried shutdown from kodi, poweroff and shutdown -h from ssh without success: "the box always does a reboot".
The only way to completely power it off is by using the power button of the original remotep.s.: "suspend" seems to be working though :o (tested over 10 times)
p.p.s.: after a lot of suspends, tried a shutdown and worked. it seems that f i suspend nd resue at least once , then the shutdown works properly..
that's real "craziness" man!
Is what you did the same as #183 Link. fw_setenv upgrade_step 1
Make all u-boot variables go back to default values and thus disable SD and USB booting ?
I ask because this did not fix the boot freeze executing command over ssh
