Sorry guys, indeed the source was HDR10 (I thought it was Dolby Vision profile 7).
I just tested another remux with Dolby Vison profile 7 and it plays fine.
That's cool. It happens to all of us, sooner or later. Too many formats, files, tests... ![]()
The important thing is it works correctly for you.
What's S24?
Hi,
I'm using your DV-R1.0.0-RC4-Preview-Update2 build on an HP EliteDesk with an AMD Ryzen 5 2400G (Radeon Vega 11).
My setup:
4K playback works correctly.
I'm trying to play a genuine 3D Blu-ray with MVC encoding (not an SBS or OU video file).
Unfortunately, instead of native HDMI 3D frame packing, I only get two images side by side.
I checked the EDID using edid-decode. The projector is detected as "Optoma UHD", and the HDMI Vendor-Specific Data Block explicitly reports "3D present".
The AMD DRM driver also lists 1920x1080 at 24 Hz and 23.98 Hz.
VAAPI hardware acceleration is enabled, DRM PRIME decoding is disabled, and the preferred stereoscopic mode is set to "Same as movie".
Does your build support native HDMI 3D frame packing on the Ryzen 5 2400G / Vega 11, particularly through a DisplayPort-to-HDMI connection?
Is there a specific setting or known limitation for this GPU?
Thanks for your work!
Hello, I am running the RC3 build and having some playback issues. On an Intel Tiger Lake-H laptop, Kodi freezes (black screen, UI unresponsive, process stays alive) in several playback situations that do not use the Dolby Vision renderer. Dolby Vision files, and HDR10 files with "HDR10 playback" set to "Dolby Vision Rendering", play correctly. The main thread is blocked in `drm_syncobj_wait_ioctl` and never returns. This seems related to the "Tiger Lake 10-bit driver issue" listed under known issues, but it also happens with plain SDR content, with no 10-bit surface recreation in the log.
## System
- Build: LibreELEC (community) `DV-R1.0.0-RC3`, build `00615a5a5e-backlog-fba738eba0`, Kodi 22.0-RC1 (21.90.901), kernel 7.2.6, Mesa 26.2.3
- Laptop: ASUS ROG Zephyrus M16 (GU603HM), i7-11800H, Intel UHD Graphics (TigerLake-H GT1, 8086:9a60) + NVIDIA RTX 3060 Mobile (GA106M)
- Display: HDMI port is on the Intel GPU (`card0 HDMI-A-1`); the RTX 3060 has no connected output. Sink is an Onkyo AV receiver (EDID reports standard DV, HDR10, PQ and HLG)
- Boot: installed to NVMe; internal panel disabled with `video=eDP-1:d`
- Settings: Dolby Vision playback mode 4 ("HDR10 Rendering"); HDR10 playback tried with 0 ("Kodi default") and 1 ("Dolby Vision Rendering")
- Content is played over SMB, or through PlexKodiConnect, from another machine
## What works
- Dolby Vision files, including FEL (MP4 FEL test clips and a DV REMUX): stable, 0 drops in steady state
- HDR10 file with HDR10 playback set to "Dolby Vision Rendering": plays
## What hangs (each reproduced more than once)
1. **2160p SDR HEVC WEB-DL (H.265, DD+ 5.1), repeatable on every attempt.** Hangs right after playback starts, before the first picture is presented (`stream=0 picture=0`). Last log lines before the hang:
VideoPlayer: OnLostDisplay received
CB1 shader cache: loaded=40 api=372 stream=0 picture=0 ...
VideoPlayer: OnResetDisplay received
FindVideoPlane(): Adopting gui plane as video plane [3840x2160] id:36, format:AR24, modifier:INTEL_Y_TILED_GEN12_RC_CCS_CC
Display resolution ADJUST : 3840x2160 @ 23.976000 Hz
Then nothing further. `/proc/<kodi pid>/stack` shows `drm_syncobj_array_wait_timeout` / `drm_syncobj_wait_ioctl`.
2. **HDR10 file with HDR10 playback = "Kodi default".** Hangs right after `Output surface recreated at 10-bit` and `Adopting gui plane as video plane [3840x2160] format:AR30, modifier:INTEL_Y_TILED_GEN12_RC_CCS_CC`, with `hdr_value` set and `colorspace_value=9`.
3. **Player process-info dialog (the `O` key) on an HDR10 file already playing through the DV path.** The dialog (`DialogPlayerProcessInfo.xml`) loads, then `Output surface recreated at 10-bit`, DV is deactivated (`requested_dv=0 restoring=true`) and Kodi hangs the same way.
Separately, on a DV FEL file, opening the same dialog causes a one-off hitch of about 1 second (20–32 dropped frames, two `OutputPicture - timeout waiting for buffer` warnings) and then plays cleanly. No hang.
## What I ruled out
- **Storage:** reproduced on both a USB 2 stick and an NVMe SSD
- **GPU clock or CPU power state:** pinned the GPU to 1450 MHz minimum and CPU EPP to performance; no change in the hang or the drops
- **Temperature:** CPU package about 46–50 °C
- **Hardware HEVC decode:** disabled `videoplayer.usevaapihevc`; the SDR file still hangs
- **VT-d for graphics:** added `intel_iommu=igfx_off` (kernel confirms `DMAR: Disable GFX device mapping`); no change
- **Optimized GUI rendering (`dvbridge.optimizedgui`):** no change
- **Kernel GPU state:** `i915_engine_info` showed Reset count 0 and, in one case, a `hungE` request from kodi.bin on rcs0; in other cases no hung request, so it is not always an engine hang that i915 detects. No i915 errors in dmesg.
## Notes
- NVIDIA kernel modules load, but `nvidia-drm` reports "Cannot find any crtc or sizes", so the dGPU does not drive the display.
- Happy to provide full `kodi.log` files, `dmesg`, and `i915_engine_info` captured during a hang.
- Not yet tested on the AMD Cezanne iGPU in a VM with this exact build: *fill in if you have tested it*.
Display MoreThanks for the clarification!
One important detail about my setup:
My HP EliteDesk 705 G4 SFF (Ryzen 2400G / Vega 11) is connected using a 30 cm 4K DisplayPort-to-HDMI cable, followed by an HDMI splitter and my Optoma UHD projector.
The same HDMI splitter works perfectly with my Panasonic UHD Blu-ray player, including native Blu-ray 3D frame packing and 4K playback.
This confirms that the splitter is capable of passing both signals.
HP also offered an optional internal HDMI output module for the EliteDesk 705 G4 SFF.
Would this module provide a truly native HDMI connection to the GPU, or is it internally based on DisplayPort?
And does the native HDMI requirement also apply to MVC 3D frame packing, or only to Dolby Vision Profile 7 FEL?
I'd like to clarify this before purchasing additional hardware.
Thanks again!
From CroqueMr
https://forum.kodi.tv/showthread.php?tid=385600&pid=3315592#pid3315592
QuoteAnd no, unfortunately, DV doesn't work over DP. You need a native HDMI output with no adapters or converters in between. Technically, we could modify the drivers for some DP -> HDMI converters, but that's way too messy.
Also, be careful with desktop PC, even if they have an HDMI port, it isn't always native HDMI. Sometimes it's actually DP behind, which means DV won't work. This is pretty common with 8th and 9th gen Intel systems
and this when I asked dev about that hdmi module
Quoteand
No it's not a native HDMI port, you can even see the DP converter on the board.
A native HDMI port is wired directly to your GPU or iGPU, if you have a module like that, you always have a DP converter to something else
https://forum.kodi.tv/showthread.php?tid=385600&pid=3315646#pid3315646
I gave up on those business machines, it has to be a native HDMI port, no adapter or module. It won't work
DV over DP->HDMI is possible. I have it working on PS5 and Intel iGPU (only tested on Kaby Lake so far).
Yeah it's possible but not on all converter, and if we need to adjust driver for all LSPCON it will be a nightmare to maintain.
Thanks again!
DP should be ok for 3D, can you send me the log? for DP to HDMI as I said, it's too sketchy and complicated to support it properly, and yes the HDMI module is a DP converter you can not have a native HDMI output using your iGPU on this PC unfortunatly.
Try the current RC 4 preview build and, under system, force 8 bit color depth output. I am currently using a i3-1115G4 (Tiger Lake as well) and I discovered that, otherwise, even SDR gets outputted as 10bit. And that messes up everything on our machines.
If the above setting solves things for you, you have my same exact situation.
Thinking about switching from the AM6B+ to a mini pc that can do LE. Specifically one that's 16GB ram and H 255.
Wondering what I'm gaining here. Will Plex 4K Kodi be able to read higher bit rates? Will it has LLDV as good as the UGOOS? Sorry if all of these have been answered but I just want cliff notes.
I don't think it currently does LLDV, not sure about PLEX.
Hi CroqueMr,
Thank you for your reply and for looking into this!
I've attached a sanitized excerpt from my Kodi log, focusing on the 3D Blu-ray playback attempt. Some unrelated entries have been removed for privacy.
The original 3D Blu-ray (Doctor Strange) is played directly from the internal optical drive of my HP EliteDesk 705 G4 SFF (Ryzen 5 PRO 2400G / Vega 11).
My setup is:
DisplayPort → 30 cm 4K DP-to-HDMI cable → HDMI splitter → Optoma UHD projector
The same HDMI splitter works correctly with my Panasonic UHD Blu-ray player, including native Blu-ray 3D and 4K output.
One thing I noticed in the log is:
[WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 23.976, 3D: true
Followed by:
Display resolution ADJUST : 1920x1080 @ 23.976080 Hz 3D sbs (32)
Kodi seems to recognize the 3D content but selects SBS instead of frame packing.
Could this be related to the available DRM display modes or the DP-to-HDMI connection?
I'd appreciate your thoughts.
Thanks again for your help!
I tested something else on Croques last build:
1. Bluray as .iso -> works ✓
2. Gemini Man 60fps HDR->DV + subtitles
a) Hades -> stutters with subtitles or video info open
b) CroqueMR -> works ✓ (GPU 90%)
Hi CroqueMr,
First off, huge appreciation for the build and the R1.0.0-RC4 release! Testing on an Intel Arc GPU with LibreELEC x86 connected to a Denon AVR and Sony A80K OLED, the CB1-HDR10DVR circuit is performing exceptionally well—flawless TV-Led / YCbCr tunnel inside RGB 4:4:4 / 8-bit, solid TrueHD Atmos / DTS:X passthrough, and zero frame drops with real-time AI metadata generation (CB1-L1L3).
Feature Request: Could you consider adding an opt-in SDR -> Dolby Vision conversion circuit (e.g., CB1-SDRDVR / inverse tone-mapping) in a future update?
Currently, standard 8-bit BT.709 SDR streams rightly bypass processing and stay in "SDR / Kodi playback". Having a dedicated CB1 SDR mode that can map Rec.709 gamma into the Dolby Vision tunnel (expanding specular highlights while anchoring SDR 100-nit diffuse white to preserve tones and shadow detail) would be fantastic for SDR Blu-ray remuxes and regional web streams.
Would an inverse tone-mapping circuit like this fit into the roadmap alongside HDR10/HDR10+, or does the engine intentionally strictly restrict to HDR sources?
Thanks again for the incredible work!
I checked your log: Kodi is on connector DP-3 and its mode list has no 3D modes (no 1920x2205 frame-packing line). On AMD the kernel patch behind 3D on these builds offers those modes only on real HDMI connectors, because DP-to-HDMI dongles rejected the 3D timings in link validation.
The "3D sbs (32)" is the same plain 1080p mode (32) as your 2D playback, with Kodi drawing both eyes side by side. No 3D signal reaches the projector, which is why you see two images. So the limit is the DP output, not Vega 11, and SBS or TAB files need the same 3D modes. We have only tested 3D on native HDMI.
Hi cinemaONE and CroqueMr,
Thank you both for your explanations and for taking the time to investigate my log!
I understand that the current AMD 3D kernel patch only exposes frame-packing modes on native HDMI connectors, while my DP-to-HDMI connection fails to provide these modes.
Since CroqueMr mentioned that DP should be OK for 3D, I was wondering whether extending the kernel patch to support DP-to-HDMI connections might be technically feasible.
I'd be very happy to volunteer as a test candidate for an experimental kernel patch or custom LibreELEC build.
I've been working with Linux-based HTPCs since 2004, starting with VDR, followed by OpenELEC, LibreELEC, CoreELEC and other systems.
My hardware is available for testing, and I can provide logs, EDID information and detailed feedback.
The same HDMI splitter and Optoma projector already work correctly with native Blu-ray 3D from my Panasonic player.
Of course, I understand that such a patch might require significant development work and may not be possible.
Thanks again for your excellent work!
I’ve been around since the first days of CE having FEL support and I watched CPM get burnt out by incessant requests while the CE team got so fed up that they banned all discussion of forks. I don’t want to see this replicated here. The code is already an enormous amount of effort that has taken over CroqueMr life over the past month. I’ve seen them delay their work to fix this which is a danger sign. I also want perfect Dolby Vision, but not at the cost of somebodies mind, job or happiness.
DP-to-HDMI conversion adds a whole new layer of complexity to code and support. Sure, it would be nice, but, frankly, not necessary. Let’s let the core work be finished and give all the devs a well-deserved break.
Firstly thanks to everyone for the hard work you have put in, I never thought I would see the day that we would be here, and that my N150 would replace my shield!
Is it possible to to clone the hdmi output so I can connect one directly to the TV and the other to my AVR? I have the handshake issue with my Denon 3800 and it is driving me crazy!
