LE-8.0.1 release is out enjoy!
Just got the 8.0 working yesterday on minix x8h , what are the advantages of 8.0.1 and how to update ? I'm running from sd card. Thanks
Could you please be kind and point me, step by step, how to do this? Which file to download (.zip or else) and how to do an update? Thanks
download LibreELEC-S802.M8.arm-7.0.2-2-devel.zip . Unzip and put the 2 files on SD card and do toothpick install.
After install complete, download LibreELEC-S802.arm-8.0.1a-M8.tar . With M8 turned on and connected to your network, login to box or connect via windows and put tar file in "update" folder. Reboot M8.
Say Thank You to Demetris
Hello all,
glad to see some one working on s802 again two thumbs up!!
everything is working beautifull as far as i have tested except the remote the remote is driving me a bit bat shit crazy the only buttons not working at the moment are volume +/- and I cannot power on the device after power down
I have read every post on here
I am sure I have tried everything sugested but i still cant seem to get it working
I am running S802 M8 matricom gbox q
I have the original remote.config file and copied /reboot with remote.config in all the locations suggested and still no dice
also tried button remapping still no dice
I have tried 8.0 rc 1, 2 and currently on rc4e
and testing 8.0.1a
can anyone shine some light on the situation or having these issues?
**update- 8.0.1a installs nice no remote function at all with or with out remote.config file
wireless keyboard works
Thanks again demetris....work well on MXIII 2G
Will give it a try once I get back from work demetris, as always very much appreciated
Sent from my SM-G930F using Tapatalk
Thank you Demetris
sorry for being rude.
Use your pc to navigate to your minix box using samba share (windows explorer)
Download the s82 img.gz release and put it in the update folder on your box. Reboot the box and it will update automatically for you
That sounds really easy ,I'll give it a try . Thanks.
I got this too! Been asking for a fix for a while.
Maybe use sudo? Or login as root?
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Ok, I've seen that it's a permissions issue, but when I try to make it executable I get another error
Fixed, I copy the file /usr/bin/installtointernalto in the / folder and from there change the permissions
chmod +x installtointernal
, then run it and it is already working
I have the newest version running on my G-Box Q. My Harmony Remote will not work anything but my wireless keyboard will work. I would like to be able to use my Harmony. Any help would be great. I have looked up on how to add remotes but it says to add it to /storage/.config/. Problem is I can't find that folder when looking on LibreElec with my mac.
Fantastic, Thanks a lot Demetris for your work towards keeping Amlogic S802 still relevant
I had been using 7.0.2 S82 build from Drieschel on a MX-III 2GB and everything was working fine including wifi, Bluetooth and IR Remote
I updated the MX-III with LibreELEC-S802.arm-8.0.1a-S82 from your release and have run into issues
Everything but two devices seem to be working fine
The things not working are
1. Bluetooth
2. IR Remote
As both input devices are not working, I can't use the device without plugging in a USB mouse/keyboard.
Here is the dmesg output from 7.0.2 which shows the BT recognized correctly, don't know where IR is recognized but it sure works nicely.
zmK92jW8
And here is the dmesg output from your 8.0.1 build
bFwQptpq
Can you please take a look and advise what I am doing wrong. Thanks
Display More
Fantastic, Thanks a lot Demetris for your work towards keeping Amlogic S802 still relevantI had been using 7.0.2 S82 build from Drieschel on a MX-III 2GB and everything was working fine including wifi, Bluetooth and IR Remote
1. Bluetooth
2. IR Remote
As both input devices are not working, I can't use the device without plugging in a USB mouse/keyboard.Here is the dmesg output from 7.0.2 which shows the BT recognized correctly, don't know where IR is recognized but it sure works nicely.
zmK92jW8And here is the dmesg output from your 8.0.1 build
bFwQptpqCan you please take a look and advise what I am doing wrong. Thanks
i have MXII 2G...put it remote.conf in config folder via filezila client...and reboot
remote.conf - Google Drive
Perfect, the remote.conf file fixed the issue with the infrared remote. Thanks for that
Now if Demetris can take a look at the Bluetooth issue then it will be 100%
Tell me your chip please ![]()
Sent from the Island of Venus
