Greetings,
Thank you very much, my friend, I wish the device worked. ![]()
Best regards...
Greetings,
Best regards...
Hi,
did something change in last builds for SD contents? SD videos suddenly look AWFUL (did not in previous LE 8.x builds) and they are also very very choppy. I did not notice earlier since I don't watch SD often. I tried a couple of them and it seems the same problem with all of them.
Greetings,
How do you know which models these are?
Linux Kernel Driver DataBase: CONFIG_VIDEO_CX231XX: Conexant cx231xx USB video capture support .
Best regards...
Hi,did something change in last builds for SD contents? SD videos suddenly look AWFUL (did not in previous LE 8.x builds) and they are also very very choppy. I did not notice earlier since I don't watch SD often. I tried a couple of them and it seems the same problem with all of them.
I agree, I am watching with my kids old The Cosby Show episodes (all in SD) and they buffer a lot and are choppy on my Beelink MX III II. It doesn't happen on my other Beelink MX III II with LE 7.0.3.012j. Maybe it's just coincidental...
Greetings,How do you know which models these are?
Best regards...
I looked up device and vendor ID in modules alias table.
Hello. Which of the S905x boxes would you recommend? Nexbox A95X / Beelink MINI MXIII II / Mini M8S II / X96 / other? Just LE a couple of plugins a installed to NAND.... Thnx ![]()
Are there any issues with installing an older build over the current one?
kszaq
On 8.0.0d, It seems commit 8ab0f5 on the Kernel broke ALSA audio on S905, its weird because audio works inside Kodi, but if you run other programs (like Retroarch) sound is missing, if I revert this commit (or use commit 84ad67 which is one before) and compile from source sound works again, any idea why this might be ?And also not as important and it might not be relevant to you, but might be worth a mention. At least for me the new peripheral joystick add-on doesn't work anymore (it worked out of the box for 8.0.0c)
I use an Xbox 360 controller (and a Logitech F310) and I can move around with the analog stick, but the buttons don't work at all (A,B,X,Y,L,R,etc) not even if I try to set it up under input settings.
Thanks again for all the awesome work you are doing for these SOCs
Having the same problem inside Kodi. On occasion, I have to restart the content so the audio kicks in.
Hello kszaq
first of all thanx for wonderful work, a95 box runs perfect
having issues with beelik M18 2g/16 when i update to 8.0.0d it updates but boots back with black screen
LibreELEC-S905.aarch64-7.0.2.003 is the only version seems to be working on that can you please into it,, or maybe guide me
thanx
Keep in mind that each box / model has different versions with varying hardware.
I have the Nexbox A95X-B7N in 2GB/16GB configuration and it works great. The wifi is also strong and supports 5Ghz. The version with 1GB ram however doesn't support 5Ghz wifi.
Anyone else having a problem with videos freezing in the last 3 sec of the video. Audio continues to play with frozen video. Its not crashing the box, and not a big deal, just curious if im the only one.
This didnt happen on any of the 7.0.3.012 builds.
Tronsmart S95x box.
This problem described as above - 'picture freezes and audio continues in the last seconds' is still a current issue on the 8.0 builds.
Its only happening with 10-15 seconds short video's.
Changing latency/delay value's in advancedsettings does not have any effect whatsoever.
Is there a fix for this Kzsaq?
kszaq - on my box the current value for /sys/class/mpgpu/cur_freq is 500, not a single digit. Should I still change it to just 5 if I want to try the higher frequency?
For info, the contents of every file in /sys/class/mpgpu/ are
Any information about this post plz? I encounter the same problem.
Where do we have to input "echo 5" to overclock the gpu?
Any information about this post plz? I encounter the same problem.Where do we have to input "echo 5" to overclock the gpu?
Is it that hard to read the quoted post? post-38536.html#pid38536
Its only happening with 10-15 seconds short video's.Changing latency/delay value's in advancedsettings does not have any effect whatsoever.
Nobody has ever posted a log as requested many times = issue is ignored. I would really like to resolve issues but I can't ask for logs every single time. I created single sticky post to be clearly visible. I ask to read it in OP. And yet everyone ignores it.
Hi, I use this serie of builds and now specially the 8.0d one on my Nexbox A95X S905X (2G + 16G) box. Not Nand installed so it runs from SD. I don't no if it's an issue, but the bluetooth interface is always disable with these builds and I cannot find a way to enable it if possible. Can someone helps or clarifies on that.
TIA
Hi, I use this serie of builds and now specially the 8.0d one on my Nexbox A95X S905X (2G + 16G) box. Not Nand installed so it runs from SD. I don't no if it's an issue, but the bluetooth interface is always disable with these builds and I cannot find a way to enable it if possible. Can someone helps or clarifies on that.TIA
Have you tried; Programs/LibreELEC Configuration, Menu >"Services" and at the bottom of the list "Enable Blutooth"?
-2re
kszaq - after my problem with my S905x box not supporting audio rates higher than 96kHz, I have sourced a cheap Tronsmart S95 Pro. This is an S905 box with 1GB RAM, 8GB flash and 1GB ethernet. I've used the appropriate device tree gxbb_p200_1G_1Gbit.dtb and everything is working fine from SD card - wireless, BT, ethernet, remote etc.
However, I have a continuing issue with high-def sound which is in excess of 96kHz sampling rate. I have several stereo flac files ripped at 192kHz from my DVD-Audio disks which are detected by Kodi as 192kHz 2.0 and it seems to initialise the sink correctly but no sound is output to my AV amp. With the s905X box it was downsampled to 96kHz but with this box - no output. I can force the sample rate to 192kHz in the Kodi System/Audio menu and then the sound is output correctly on the L & R channels at 192kHz but the sink is initialised as 8 channels depending on the speaker configuration (7.1). I'm not sure if it's a bug in Kodi or something I can tweak in the settings. Ideally I would set "best match" in the Kodi settings and then let Kodi output to the AV amp at the relevant sample rate and number of channels contained in the source file. I noticed that in the "Fixed" sampling rate settings in Kodi I can use 44.1, 88.2, 96 and 192kHz but not 176.4kHz. Is this an omission as I have several high-bitrate SACD files at 176.4kHz.
snip of the Kodi log showing the setting of fixed bit rate of 192kHz which allows playback of stereo through my AV amp:
10:38:56.348 T:4096639904 INFO: CActiveAE::ApplySettings - Forcing samplerate to 192000
10:38:56.348 T:4118179776 INFO: Previous line repeats 1 times.
10:38:56.348 T:4118179776 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:38:56.547 T:4096639904 INFO: CActiveAE::ApplySettings - Forcing samplerate to 192000
10:38:56.548 T:4086297504 INFO: CActiveAESink::OpenSink - initialize sink
10:38:56.549 T:4086297504 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0
10:38:56.550 T:4086297504 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=AMLM8AUDIO,DEV=0"
10:38:56.564 T:4086297504 INFO: CAESinkALSA::Initialize - Opened device "surround51:CARD=AMLM8AUDIO,DEV=0"
10:38:56.566 T:4086297504 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
10:38:56.566 T:4086297504 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
10:38:56.566 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 16384
10:38:56.592 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 16384
10:38:56.593 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 86 ms
10:38:56.593 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 6 Output Channel Count: 8
10:38:56.593 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR,FC,LFE,SL,SR
10:38:56.593 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR,SL,SR,FC,LFE,BL,BR (ALSA: none)
10:38:56.593 T:4086297504 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
10:38:56.593 T:4086297504 DEBUG: Output Device : AML-M8AUDIO
10:38:56.593 T:4086297504 DEBUG: Sample Rate : 192000
10:38:56.594 T:4086297504 DEBUG: Sample Format : AE_FMT_S32NE
10:38:56.594 T:4086297504 DEBUG: Channel Count : 8
10:38:56.594 T:4086297504 DEBUG: Channel Layout: FL,FR,SL,SR,FC,LFE,BL,BR
10:38:56.594 T:4086297504 DEBUG: Frames : 2048
10:38:56.594 T:4086297504 DEBUG: Frame Size : 32
10:38:56.622 T:4096639904 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
10:38:58.647 T:4118179776 DEBUG: Previous line repeats 1 times.
10:38:58.647 T:4118179776 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:38:58.864 T:4118179776 DEBUG: OnKey: return (0xf00d) pressed, action is Select
Display More
snip of the log showing automatic setting of sample rate to two-channel 192kHz which results in silence through my AV amp:
:35:41.899 T:4086297504 INFO: CActiveAESink::OpenSink - initialize sink
10:35:42.086 T:4086297504 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0
10:35:42.087 T:4086297504 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=AMLM8AUDIO,DEV=0"
10:35:42.116 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_direct.c:939:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
10:35:42.116 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_dmix.c:1053:(snd_pcm_dmix_open) unable to initialize slave
10:35:42.117 T:4086297504 INFO: CAESinkALSA - Unable to open device "sysdefault:CARD=AMLM8AUDIO" for playback
10:35:42.124 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_direct.c:939:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
10:35:42.124 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_dmix.c:1053:(snd_pcm_dmix_open) unable to initialize slave
10:35:42.124 T:4086297504 INFO: CAESinkALSA - Unable to open device "default:CARD=AMLM8AUDIO" for playback
10:35:42.125 T:4086297504 INFO: CAESinkALSA::Initialize - Opened device "front:CARD=AMLM8AUDIO,DEV=0"
10:35:42.126 T:4086297504 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
10:35:42.126 T:4086297504 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
10:35:42.126 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 8192, bufferSize 38400
10:35:42.127 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 512, bufferSize 38400
10:35:42.127 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
10:35:42.128 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
10:35:42.128 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
10:35:42.128 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: none)
10:35:42.128 T:4086297504 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
10:35:42.128 T:4086297504 DEBUG: Output Device : AML-M8AUDIO
10:35:42.128 T:4086297504 DEBUG: Sample Rate : 192000
10:35:42.128 T:4086297504 DEBUG: Sample Format : AE_FMT_S32NE
10:35:42.128 T:4086297504 DEBUG: Channel Count : 2
10:35:42.128 T:4086297504 DEBUG: Channel Layout: FL,FR
10:35:42.128 T:4086297504 DEBUG: Frames : 512
10:35:42.128 T:4086297504 DEBUG: Frame Size : 8
10:35:42.134 T:4096639904 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
10:35:42.181 T:4118179776 DEBUG: Previous line repeats 1 times.
10:35:42.181 T:4118179776 INFO: PAPlayer::PrepareStream - Ready
10:35:42.181 T:4118179776 DEBUG: PlayFile: OpenFile succeed, play state 1
10:35:42.181 T:4030718880 DEBUG: Thread PAPlayer start, auto delete: false
10:35:42.182 T:4118179776 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
10:35:42.182 T:4030718880 DEBUG: PAPlayer::Process - Playback started
10:35:42.182 T:4030718880 DEBUG: OnPlayBackStarted: play state was 1, starting 0
10:35:42.195 T:3923776416 DEBUG: CGUIInfoManager::SetCurrentSong(smb://QUIETBUNTU/FLAC/Carly Simon/No Secrets (DVDA 2.0)/3 - You're So Vain.flac)
10:35:42.212 T:3923776416 DEBUG: Loading additional tag info for file smb://QUIETBUNTU/FLAC/Carly Simon/No Secrets (DVDA 2.0)/3 - You're So Vain.flac
10:35:42.212 T:4118164384 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
10:35:42.212 T:4118164384 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
10:35:42.223 T:3923776416 DEBUG: CSMBFile::Open - opened smb://QUIETBUNTU/FLAC/Carly Simon/No Secrets (DVDA 2.0)/3 - You're So Vain.flac, fd=10001
10:35:42.237 T:3923776416 DEBUG: unrecognized XipComment name: ARTISTSORT
10:35:42.237 T:3923776416 DEBUG: unrecognized XipComment name: ASIN
10:35:42.237 T:3923776416 DEBUG: unrecognized XipComment name: DESCRIPTION
10:35:42.237 T:3923776416 DEBUG: unrecognized XipComment name: DVDA_TITLE
10:35:42.237 T:3923776416 DEBUG: unrecognized XipComment name: DVDA_TITLESET
10:35:42.237 T:3923776416 DEBUG: unrecognized XipComment name: DVDA_TRACK
10:35:42.237 T:3923776416 DEBUG: CSMBFile::Close closing fd 10001
10:36:12.238 T:3923776416 DEBUG: Thread JobWorker 3923776416 terminating (autodelete)
10:37:07.528 T:4118179776 DEBUG: Keyboard: scancode: 0xa6, sym: 0x00b2, unicode: 0x0000, modifier: 0x0
10:37:07.528 T:4118179776 DEBUG: OnKey: stop (0xf0bc) pressed, action is Stop
10:37:07.608 T:4096639904 DEBUG: CActiveAE::DiscardStream - audio stream deleted
10:37:07.609 T:4096639904 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
10:37:07.612 T:4118179776 DEBUG: Previous line repeats 2 times.
10:37:07.612 T:4118179776 DEBUG: CSMBFile::Close closing fd 10000
10:37:07.613 T:4030718880 DEBUG: OnPlayBackStopped: play state was 2, starting 0
10:37:07.613 T:4030718880 DEBUG: Thread PAPlayer 4030718880 terminating
10:37:07.621 T:4118164384 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
10:37:07.621 T:4118164384 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
10:37:07.790 T:4030718880 DEBUG: Thread JobWorker start, auto delete: true
10:37:07.790 T:4030718880 DEBUG: DoWork - Saving file state for audio item smb://QUIETBUNTU/FLAC/Carly Simon/No Secrets (DVDA 2.0)/3 - You're So Vain.flac
10:37:07.790 T:4118179776 DEBUG: Keyboard: scancode: 0xa6, sym: 0x00b2, unicode: 0x0000, modifier: 0x0
10:37:08.006 T:4086297504 INFO: CActiveAESink::OpenSink - initialize sink
10:37:08.207 T:4086297504 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0
10:37:08.207 T:4086297504 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=AMLM8AUDIO,DEV=0"
10:37:08.215 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_direct.c:939:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
10:37:08.216 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_dmix.c:1053:(snd_pcm_dmix_open) unable to initialize slave
10:37:08.216 T:4086297504 INFO: CAESinkALSA - Unable to open device "sysdefault:CARD=AMLM8AUDIO" for playback
10:37:08.219 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_direct.c:939:(snd1_pcm_direct_initialize_slave) slave plugin does not support mmap interleaved or mmap noninterleaved access
10:37:08.219 T:4086297504 INFO: CAESinkALSA - ALSA: /home/kszaq/ocz/le-master/build.LibreELEC-S905.arm-8.0-devel/alsa-lib-1.1.2/src/pcm/pcm_dmix.c:1053:(snd_pcm_dmix_open) unable to initialize slave
10:37:08.219 T:4086297504 INFO: CAESinkALSA - Unable to open device "default:CARD=AMLM8AUDIO" for playback
10:37:08.221 T:4086297504 INFO: CAESinkALSA::Initialize - Opened device "front:CARD=AMLM8AUDIO,DEV=0"
10:37:08.227 T:4086297504 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
10:37:08.227 T:4086297504 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
10:37:08.227 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2205, bufferSize 8820
10:37:08.228 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
10:37:08.228 T:4086297504 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
10:37:08.229 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 2 Output Channel Count: 2
10:37:08.229 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR
10:37:08.229 T:4086297504 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR (ALSA: none)
10:37:08.229 T:4086297504 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
10:37:08.229 T:4086297504 DEBUG: Output Device : AML-M8AUDIO
10:37:08.229 T:4086297504 DEBUG: Sample Rate : 44100
10:37:08.229 T:4086297504 DEBUG: Sample Format : AE_FMT_S32NE
10:37:08.229 T:4086297504 DEBUG: Channel Count : 2
Display More
The only difference I can see is that the initialisation is "surround51:CARD=AMLM8AUDIO,DEV=0" in the working example and "front:CARD=AMLM8AUDIO,DEV=0" in the example where no audio is output.
Full log here - log-2017-03-08-11.16.43.zip
Sorry kszaq but the quoted post do not answer the relevant question asked by renzz :
" kszaq - on my box the current value for /sys/class/mpgpu/cur_freq is 500, not a single digit. Should I still change it to just 5 if I want to try the higher frequency?"
I use the folowing;
echo 5 > /sys/class/mpgpu/max_freq
echo 5 > /sys/class/mpgpu/min_freq
echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Full sped all the time;)
Hey folks,
I just want to report a problem that I have with my s905 with 8.0.0c and d-version.
Sometimes my beelink mini mx iii is going to suspend and it won't turn on with cec-communcaction. The box turns off after the tv is off for some hours or minutes, so I guess it's something with energy saving or deep standby.
Maybe someone has the same problems or can tell me where I can find those options to turn it off.
Thanks!
