kszaq this is the dmesg | paste output (to HaZM ) - I hope to be understood what you need..
[ 0.000000@0] Initializing cgroup subsys cpu
[ 0.000000@0] Linux version 3.14.29 (kszaq@FPGAWorker) (gcc version 5.3.0 (GCC) ) #1 SMP Sun Aug 21 04:15:56 CEST 2016
[ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000@0] no prop version_code
[ 0.000000@0] bootconsole [earlycon0] enabled
[ 0.000000@0] fdt Reserved memory table:
[ 0.000000@0] linux,meson-fb: 0x000000007bb80000 - 0x0000000080000000 (68 MiB)
[ 0.000000@0] linux,di: 0x0000000079d80000 - 0x000000007bb80000 (30 MiB)
[ 0.000000@0] DI: DI reserved memory: created CMA memory pool at 0x0000000079d80000, size 30 MiB
[ 0.000000@0] linux,ion-dev: 0x0000000077d80000 - 0x0000000079d80000 (32 MiB)
[ 0.000000@0] linux,codec_mm_cma: 0x0000000067c00000 - 0x0000000073c00000 (192 MiB)
[ 0.000000@0] linux,codec_mm_reserved: 0x0000000063b00000 - 0x0000000067c00000 (65 MiB)
[ 0.000000@0] fdt Reserved memory total: 390 MiB
[ 0.000000@0] cma: Reserved 8 MiB at 77400000
[ 0.000000@0] On node 0 totalpages: 501888
[ 0.000000@0] Normal zone: 8836 pages used for memmap
[ 0.000000@0] Normal zone: 0 pages reserved
[ 0.000000@0] Normal zone: 501888 pages, LIFO batch:31
[ 0.000000@0] psci: probing function IDs from device-tree
[ 0.000000@0] PERCPU: Embedded 12 pages/cpu @ffffffc077d1f000 s17408 r8192 d23552 u49152
[ 0.000000@0] pcpu-alloc: s17408 r8192 d23552 u49152 alloc=12*4096
[ 0.000000@0] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 493052
[ 0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.mem_address=0x20000000 ramoops.mem_size=0x100000 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive logo=osd1,loaded,0x3f800000,1080p60hz hdmimode=1080p60hz cvbsmode=576cvbs hdmitx= androidboot.firstboot=0 mac=D0:76:58:04:B6:93 androidboot.mac=D0:76:58:04:B6:93 bootfromsd console=tty0 quiet
[ 0.000000@0] logo: osd1
[ 0.000000@0] logo: loaded
[ 0.000000@0] logo: 0x3f800000
[ 0.000000@0] logo: 1080p60hz
[ 0.000000@0] vout_serve: 1080p60hz: 16
[ 0.000000@0] vout_serve: en: 1
[ 0.000000@0] logo: get hdmimode: 1080p60hz
[ 0.000000@0] logo: get cvbsmode: 576cvbs
[ 0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000@0] Memory: 1610624K/2007552K available (7413K kernel code, 654K rwdata, 2808K rodata, 817K init, 5098K bss, 396928K reserved)
[ 0.000000@0] Virtual kernel memory layout:
[ 0.000000@0] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB)
[ 0.000000@0] vmemmap : 0xffffff8040010000 - 0xffffff80422dbc00 ( 34 MB)
[ 0.000000@0] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
[ 0.000000@0] memory : 0xffffffc000000000 - 0xffffffc07bb80000 ( 1979 MB)
[ 0.000000@0] .init : 0xffffffc001a7d000 - 0xffffffc001b49400 ( 817 kB)
[ 0.000000@0] .text : 0xffffffc001080000 - 0xffffffc001a7c424 ( 10226 kB)
[ 0.000000@0] .data : 0xffffffc001b4a000 - 0xffffffc001bed858 ( 655 kB)
[ 0.000000@0] PM: Registered nosave memory: [mem 0x01080000-0x01a7bfff]
[ 0.000000@0] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000@0] arch_multi_cluster:0
[ 0.000000@0] Hierarchical RCU implementation.
[ 0.000000@0] RCU debugfs-based tracing is enabled.
[ 0.000000@0] CONFIG_RCU_FANOUT set to non-default value of 32
[ 0.000000@0] NR_IRQS:64 nr_irqs:64 0
[ 0.000000@0] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000003@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
[ 0.000170@0] Console: colour dummy device 80x25
[ 0.000176@0] console [tty0] enabled
[ 0.000180@0] bootconsole [earlycon0] disabled
[ 0.000192@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000198@0] pid_max: default: 32768 minimum: 301
[ 0.000286@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000291@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.001739@0] device-tree: Duplicate name in /efusekey, renamed to "key0#1"
[ 0.001747@0] device-tree: Duplicate name in /efusekey, renamed to "key1#1"
[ 0.001754@0] device-tree: Duplicate name in /efusekey, renamed to "key2#1"
[ 0.001759@0] device-tree: Duplicate name in /efusekey, renamed to "key3#1"
[ 0.004032@0] ftrace: allocating 25821 entries in 101 pages
[ 0.024709@0] /cpus/cpu@0: Missing clock-frequency property
[ 0.024725@0] /cpus/cpu@1: Missing clock-frequency property
[ 0.024731@0] /cpus/cpu@2: Missing clock-frequency property
[ 0.024737@0] /cpus/cpu@3: Missing clock-frequency property
[ 0.025041@0] ftrace: Allocated trace_printk buffers
[ 0.025430@0] Meson chip version = RevC (1F:C - 13:0)
[ 0.026443@1] CPU1: Booted secondary processor
[ 0.027464@2] CPU2: Booted secondary processor
[ 0.028458@3] CPU3: Booted secondary processor
[ 0.028509@0] Brought up 4 CPUs
[ 0.028519@0] SMP: Total of 4 processors activated.
[ 0.028885@0] devtmpfs: initialized
[ 0.033443@0] instabooting: 0
[ 0.038722@0] pinctrl core: initialized pinctrl subsystem
[ 0.039200@0] regulator-dummy: no parameters
[ 0.039708@0] NET: Registered protocol family 16
[ 0.041187@0] aml_vdac_init: module init
[ 0.041287@0] register canvas platform driver
[ 0.041341@0] register rdma platform driver
[ 0.042140@0] vdso: 2 pages (1 code, 1 data) at base ffffffc001b54000
[ 0.042638@0] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.043830@0] software IO TLB [mem 0x62c00000-0x63000000] (4MB) mapped at [ffffffc062c00000-ffffffc062ffffff]
[ 0.044005@0] aml_i2c version: 20140813
[ 0.044155@0] i2c-core: driver [pmu4] using legacy resume method
[ 0.044205@0] codec_mm:codec_mm_module_init
[ 0.044438@0] gxbb_mpll_clk: register mpll_clk_out0 success done
[ 0.044447@0] gxbb_mpll_clk: register mpll_clk_out1 success done
[ 0.044454@0] gxbb_mpll_clk: register mpll_clk_out2 success done
[ 0.044609@0] clk_sys: register PLL sys_pll success done
[ 0.044642@0] gxbb_clk: [ xtal ] ->clockrate: 24000000Hz
[ 0.044646@0] gxbb_clk: [ 32Khz ] ->clockrate: 32000Hz
[ 0.044650@0] gxbb_clk: [ clk81 ] ->clockrate: 166666666Hz
[ 0.044654@0] gxbb_clk: [ fixed_pll ] ->clockrate: 2000000000Hz
[ 0.044657@0] gxbb_clk: [ fclk_div2 ] ->clockrate: 1000000000Hz
[ 0.044660@0] gxbb_clk: [ fclk_div3 ] ->clockrate: 666666666Hz
[ 0.044664@0] gxbb_clk: [ fclk_div4 ] ->clockrate: 500000000Hz
[ 0.044667@0] gxbb_clk: [ fclk_div5 ] ->clockrate: 400000000Hz
[ 0.044670@0] gxbb_clk: [ fclk_div7 ] ->clockrate: 285714285Hz
[ 0.044691@0] gxbb_clk: clock initialization complete
[ 0.044816@0] clkmsr: msr_clk_reg0=ffffff800005875c,msr_clk_reg2=ffffff800005a764
[ 0.046355@0] aml_iomap: amlogic iomap probe done
[ 0.046808@0] pinmux-gxbb c1109880.pinmux: Init pinux probe!
[ 0.047395@0] pinmux-gxbb c1109880.pinmux: Probed amlogic pinctrl driver
[ 0.047736@0] aml-i2c c1108500.i2c: add adapter aml_i2c_adap1(ffffffc0631a30e0)
[ 0.049902@0] codec_mm has 2 memory regions
[ 0.049922@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_cma ok
[ 0.049932@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_reserved ok
[ 0.049987@0] codec_mm has 2 memory regions
[ 0.049995@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_cma ok
[ 0.050002@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_reserved ok
[ 0.051156@0] vpu: driver version: v02
[ 0.051171@0] vpu: load vpu_clk: 666667000Hz(7)
[ 0.051228@0] vpu: vpu_probe OK
[ 0.052333@0] tv_vout: tvout_probe
[ 0.052342@0] tv_vout: major number 254 for disp
[ 0.052352@0] vout_notify: vout_register_server
[ 0.052355@0] tv_vout: register tv module server ok
[ 0.052410@0] tv_vout: tvout_probe OK
[ 0.052775@0] canvas_probe reg=00000000c8838000,size=400
[ 0.052787@0] canvas maped reg_base =ffffff800018e000
[ 0.055767@0] rdma_probe
[ 0.166754@0] bio: create slab <bio-0> at 0
[ 0.167340@0] SCSI subsystem initialized
[ 0.167662@0] usbcore: registered new interface driver usbfs
[ 0.167724@0] usbcore: registered new interface driver hub
[ 0.167798@0] usbcore: registered new device driver usb
[ 0.168342@0] i2c-gpio i2c_gpio.35: using pins 153 (SDA) and 154 (SCL)
[ 0.168465@0] pps_core: LinuxPPS API ver. 1 registered
[ 0.168469@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.168513@0] PTP clock support registered
[ 0.168873@0] hdmitx: system: amhdmitx_init
[ 0.168877@0] hdmitx: system: Ver: 2014May6
[ 0.168976@0] hdmitx: system: amhdmitx_probe
[ 0.169189@0] hdmitx: system: not find match init-data
[ 0.169193@0] hdmitx: system: not find match pwr-ctl
[ 0.169197@0] hdmitx hpd irq = 89
[ 0.169533@0] hdmitx20: Mapped PHY: 0xc0800000
[ 0.169543@0] hdmitx20: Mapped PHY: 0xc1104400
[ 0.169560@0] hdmitx20: Mapped PHY: 0xc8100000
[ 0.169564@0] hdmitx20: Mapped PHY: 0xc8834000
[ 0.169568@0] hdmitx20: Mapped PHY: 0xc883a000
[ 0.169571@0] hdmitx20: Mapped PHY: 0xc883c000
[ 0.169577@0] hdmitx20: Mapped PHY: 0xd0100000
[ 0.169585@0] hdmitx20: Mapped PHY: 0xda83a000
[ 0.169596@0] hdmitx: alread display in uboot 0x10
[ 0.169615@0] avmute set to 1
[ 0.169830@0] vout_serve: vout_init_module
[ 0.169889@0] tv_vout: tv_set_current_vmode[756]fps_target_mode=16
[ 0.169895@0] tv_vout: mode is 16,sync_duration_den=1,sync_duration_num=60
[ 0.169902@0] tv_vout: already display in uboot
[ 0.169905@0] vout_serve: vinfo mode is: 1080p60hz
[ 0.169908@0] vout_serve: init mode 1080p60hz
[ 0.169961@0] vout_serve: create vout attribute OK
[ 0.169964@0] vout_serve: meson_vout_probe OK
[ 0.170066@0] logo: logo_init
[ 0.170240@0] osd_rdma: osd_rdma_init: rmda_table p=0x77441000,op=0x77441000 , v=0xffffff80001b1000
[ 0.170320@0] Advanced Linux Sound Architecture Driver Initialized.
[ 0.171752@0] Switched to clocksource arch_sys_counter
[ 0.176597@0] hdmitx: system: irq 2
[ 0.188019@0] NET: Registered protocol family 2
[ 0.188398@0] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.188506@0] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.188711@0] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.188773@0] TCP: reno registered
[ 0.188782@0] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.188815@0] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.188960@0] NET: Registered protocol family 1
[ 0.189112@0] RPC: Registered named UNIX socket transport module.
[ 0.189117@0] RPC: Registered udp transport module.
[ 0.189120@0] RPC: Registered tcp transport module.
[ 0.189124@0] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.189275@0] aml_wifi wifi.30: [wifi_dev_probe] set pwm as 32k output
[ 0.189316@0] aml_wifi wifi.30: [wifi_dev_probe] interrupt_pin=235
[ 0.189321@0] aml_wifi wifi.30: [wifi_dev_probe] irq_num=100, irq_trigger_type=0
[ 0.189325@0] aml_wifi wifi.30: [wifi_dev_probe] power_on_pin=234
[ 0.189330@0] aml_wifi wifi.30: [wifi_dev_probe] clock_32k_pin=0
[ 0.189562@0] aml_wifi wifi.30: [wifi_setup_dt] wifi_setup_dt
[ 0.189587@0] aml_wifi wifi.30: [wifi_setup_dt] interrupt_pin(235)
[ 0.189599@0] aml_wifi wifi.30: [wifi_setup_dt] power_on_pin(234)
[ 0.189609@0] aml_wifi wifi.30: [wifi_setup_dt] power_on_pin2(248)
[ 0.189749@0] Unpacking initramfs...
[ 0.208285@0] Freeing initrd memory: 2796K (ffffffc073c06000 - ffffffc073ec1000)
[ 0.210194@0] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.216798@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.217947@0] NFS: Registering the id_resolver key type
[ 0.217974@0] Key type id_resolver registered
[ 0.217978@0] Key type id_legacy registered
[ 0.217985@0] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.218779@0] msgmni has been set to 3551
[ 0.219526@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.219532@0] io scheduler noop registered (default)
[ 0.219536@0] io scheduler deadline registered
[ 0.219644@0] io scheduler cfq registered
[ 0.220461@0] meson-rng c8834000.rng: hwrng registered
[ 0.223280@0] loop: module loaded
[ 0.224156@0] tun: Universal TUN/TAP device driver, 1.6
[ 0.224161@0] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 0.227672@0] libphy: stmmac: probed
[ 0.227679@0] eth0: PHY ID 02430c54 at 0 IRQ POLL (stmmac-0:00) active
[ 0.227996@0] PPP generic driver version 2.4.2
[ 0.228143@0] NET: Registered protocol family 24
[ 0.228227@0] usbcore: registered new interface driver smsc95xx
[ 0.228352@0] usbcore: registered new interface driver usb-storage
[ 0.228488@0] usbcore: registered new interface driver usbserial
[ 0.228542@0] usbcore: registered new interface driver usbserial_generic
[ 0.228602@0] usbserial: USB Serial support registered for generic
[ 0.228659@0] usbcore: registered new interface driver pl2303
[ 0.228712@0] usbserial: USB Serial support registered for pl2303
[ 0.229283@0] mousedev: PS/2 mouse device common for all mice
[ 0.229373@0] i2c /dev entries driver
[ 0.229960@0] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.230078@0] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.231608@0] usbcore: registered new interface driver usbhid
[ 0.231612@0] usbhid: USB HID core driver
[ 0.231949@0] ashmem: initialized
[ 0.232083@0] logger: created 256K log 'log_main'
[ 0.232204@0] logger: created 256K log 'log_events'
[ 0.232322@0] logger: created 256K log 'log_radio'
[ 0.232441@0] logger: created 256K log 'log_system'
[ 0.232681@0] meson_uart c81004c0.serial: ==uart0 reg addr = ffffff80001ec4c0
[ 0.232701@0] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 1500000) is a meson_uart
[ 0.232714@0] meson_uart c81004c0.serial: ttyS0 use xtal(8M) 24000000 change 0 to 115200
[ 0.233067@0] console [ttyS0] enabled
[ 0.233278@0] meson_uart c11084c0.serial: ==uart1 reg addr = ffffff80001ee4c0
[ 0.233291@0] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 58, base_baud = 1500000) is a meson_uart
[ 0.233630@0] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c0000020, ctrl: 0
[ 0.733761@0] hdmitx: plugin
[ 0.736337@3] dwc_otg: Core Release: 3.10a
[ 0.736344@3] dwc_otg: Setting default values for core params
[ 0.736357@3] dwc_otg: curmode: 1, host_only: 1
[ 0.748526@3] dwc_otg: Using Buffer DMA mode
[ 0.748531@3] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[ 0.748535@3] dwc_otg: Working on port type = HOST
[ 0.761185@3] dwc_otg dwc2_b: DWC OTG Controller
[ 0.761206@3] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1
[ 0.761228@3] dwc_otg dwc2_b: irq 63, io mem 0x00000000
[ 0.761233@3] dwc_otg: -------hcd->flags.d32 = 0
[ 0.761252@3] dwc_otg: Init: Port Power? op_state=1
[ 0.761255@3] dwc_otg: Init1: Power Port (0)
[ 0.761390@3] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.761396@3] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.761401@3] usb usb1: Product: DWC OTG Controller
[ 0.761405@3] usb usb1: Manufacturer: Linux 3.14.29 dwc_otg_hcd
[ 0.761410@3] usb usb1: SerialNumber: dwc2_b
[ 0.761851@3] hub 1-0:1.0: USB hub found
[ 0.761871@3] hub 1-0:1.0: 1 port detected
[ 0.762058@3] dwc_otg: usb0: type: 1 speed: 0, config: 0, dma: 0, id: 0, phy: c0000000, ctrl: 0
[ 0.773650@3] dwc_otg: Core Release: 3.10a
[ 0.773656@3] dwc_otg: Setting default values for core params
[ 0.773667@3] dwc_otg: curmode: 1, host_only: 1
[ 0.785825@3] dwc_otg: Using Buffer DMA mode
[ 0.785829@3] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[ 0.785833@3] dwc_otg: Working on port type = HOST
[ 0.785906@3] dwc_otg dwc2_a: DWC OTG Controller
[ 0.785919@3] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2
[ 0.785933@3] dwc_otg dwc2_a: irq 62, io mem 0x00000000
[ 0.785937@3] dwc_otg: -------hcd->flags.d32 = 0
[ 0.785955@3] dwc_otg: Init: Port Power? op_state=1
[ 0.785958@3] dwc_otg: Init1: Power Port (0)
[ 0.786083@3] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.786089@3] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.786093@3] usb usb2: Product: DWC OTG Controller
[ 0.786098@3] usb usb2: Manufacturer: Linux 3.14.29 dwc_otg_hcd
[ 0.786102@3] usb usb2: SerialNumber: dwc2_a
[ 0.786460@3] hub 2-0:1.0: USB hub found
[ 0.786478@3] hub 2-0:1.0: 1 port detected
[ 0.786878@3] hdmitx: system: hdmitx_hdcp_init
[ 0.786983@3] ESM HLD: Initializing...
[ 0.786988@3] ESM HLD: Registering device range 'esm'...
[ 0.786997@3] ESM HLD: Device range 'esm' has been registered.
[ 0.787000@3] ESM HLD: Creating class /sys/class/elliptic...
[ 0.787055@3] ESM HLD: The class /sys/class/elliptic has been created.
[ 0.787059@3] ESM HLD: Creating device 'esm'...
[ 0.787176@3] ESM HLD: Device 'esm' has been created.
[ 0.787180@3] ESM HLD: Done initializing the HLD driver.
[ 0.797490@3] aml_vrtc rtc.29: rtc core: registered aml_vrtc as rtc0
[ 0.797635@3] secmon has 1 memory regions
[ 0.797669@3] secmon: share in base: 0xffffff80001fe000, share out base: 0xffffff8000402000
[ 0.797675@3] secmon secmon.4: assigned reserved memory node linux,secmon ok
[ 0.797678@3] secmon: probe done
[ 0.797826@3] storage: storage in base: 0xffffff8001700000
[ 0.797829@3] storage: storage out base: 0xffffff8001780000
[ 0.797832@3] storage: storage block base: 0xffffff8001800000
[ 0.797835@3] storage: probe done!
[ 0.799269@3] aml_sd_emmc_probe: line 3556
[ 0.799275@3] mmc driver version: 1.07, 2015-01-21: fix a bug in tuning which caused eMMC data CRC error
[ 0.799490@3] aml_sd_emmc_reg_init 1144
[ 0.799550@3] get property: port, value:0x00000001
[ 0.799554@3] get property: ocr_avail, value:0x00200080
[ 0.799559@3] get property: f_min, value:400000
[ 0.799563@3] get property: f_max, value:100000000
[ 0.799568@3] get property: max_req_size, value:0x00020000
[ 0.799571@3] get property: irq_in, value:3
[ 0.799574@3] get property: irq_out, value:5
[ 0.799586@3] get property: gpio_cd, str:
[ 0.799591@3] get property: pinname, str:sd
[ 0.799596@3] get property: jtag_pin, str:
[ 0.799601@3] get property: card_type, value:5
[ 0.799605@3] get property: gpio_dat3, str:
[ 0.799619@3] sd:pdata->caps = 7
[ 0.799623@3] sd:pdata->caps2 = 0
[ 0.799689@3] [aml_is_card_insert] card IN
[ 0.866266@0] hdmitx: edid: check sum valid
[ 0.866270@0] hdmitx: edid: check sum valid
[ 0.866275@0] hdmitx: edid: blk0 raw data
[ 0.866307@0] 00ffffffffffff003dcb9c080000000000110103800000780aee03a4574d9a25
[ 0.866307@0] 0e4b62bdef8081c0810081809500a940d1c0617c813c023a801871382d40582c
[ 0.866307@0] 450000000000001e023a801871382d40582c450000000000001e000000fc0050
[ 0.866307@0] 522d53433838360a20202020000000fd0017780f6611000a20202020202001e8
[ 0.866307@0]
[ 0.866307@0]
[ 0.866318@0] hdmitx: edid: blk1 raw data
[ 0.866349@0] 02034c715a15061f10038405111314021220212201190a0f1d0e1e2425232638
[ 0.866349@0] 097f070f7f071707503f06c04d02005706005f7e01675e00834f00006c030c00
[ 0.866349@0] 1400982dc000000000e200ff011d8018711c1620582c250000000000009e011d
[ 0.866349@0] 00bc52d01e20b828554000000000001e000000000000000000000000000000df
[ 0.866349@0]
[ 0.866349@0]
[ 0.866361@0] EDID Parser:
[ 0.866557@0] hdmitx: edid: find IEEEOUT
[ 0.866609@0]
[ 0.866613@0] hdmitx: update RX hdr info 0
[ 0.870655@0] receive ksv list len:1,depth:1,cas:0,dev:0
[ 0.870662@0] hdmitx: video: get current mode: 1080p60hz
[ 0.870664@0] hdmitx: update rx hdr info 0
[ 0.870680@0] hdmitx: system: [set_disp_mode_auto] ALREADY init VIC = 16
[ 0.870686@0] hdmtix: set audio
[ 0.870695@0] hdmitx tx_aud_src = 0
[ 0.870706@0] hdmitx: system: irq 80000001
[ 0.870734@0] hdmitx aud_n_para = 6144
[ 0.870752@0] hdmitx set channel status
[ 0.870828@0] Start = 0x10000100 End = 0x100001ff
[ 0.870837@0] [0x10000103]: 0x00000008
[ 0.870842@0] [0x10000104]: 0x00000001
[ 0.870993@0] [0x10000170]: 0x00000010
[ 0.871018@0] [0x10000180]: 0x000000ff
[ 0.871022@0] [0x10000181]: 0x000000ff
[ 0.871027@0] [0x10000182]: 0x00000003
[ 0.871031@0] [0x10000183]: 0x00000007
[ 0.871035@0] [0x10000184]: 0x0000003f
[ 0.871039@0] [0x10000185]: 0x00000002
[ 0.871045@0] [0x10000187]: 0x000000ff
[ 0.871049@0] [0x10000188]: 0x00000003
[ 0.900877@3] normal card in
[ 0.931906@3] [aml_sd_emmc_probe] aml_sd_emmc_probe() success!
[ 0.931926@2] [aml_is_card_insert] card IN
[ 0.931932@3] aml_sd_emmc_probe: line 3556
[ 0.931984@1] [aml_is_card_insert] card IN
[ 0.932174@3] aml_sd_emmc_reg_init 1144
[ 0.932225@3] get property: ocr_avail, value:0x00200080
[ 0.932229@3] get property: f_min, value:300000
[ 0.932233@3] get property: f_max, value:200000000
[ 0.932237@3] get property: max_req_size, value:0x00020000
[ 0.932243@3] get property: pinname, str:emmc
[ 0.932249@3] get property: card_type, value:1
[ 0.932252@3] get property: tx_phase, value:0
[ 0.932262@3] get property: gpio_dat3, str:
[ 0.932266@3] get property: hw_reset, str:
[ 0.932293@3] emmc:pdata->caps = c0000d47
[ 0.932300@3] emmc:pdata->caps2 = 60
[ 0.932310@3] storage 1, boot 1
[ 0.932313@3] get_storage_dev return 1
[ 0.971760@1] [aml_sd_emmc_probe] aml_sd_emmc_probe() success!
[ 0.971785@1] aml_sd_emmc_probe: line 3556
[ 0.971943@1] aml_sd_emmc_reg_init 1144
[ 0.971991@1] get property: ocr_avail, value:0x00200080
[ 0.971995@1] get property: f_min, value:400000
[ 0.971998@1] get property: f_max, value:200000000
[ 0.972002@1] get property: max_req_size, value:0x00020000
[ 0.972008@1] get property: pinname, str:sdio
[ 0.972012@1] get property: card_type, value:3
[ 0.972045@1] sdio:pdata->caps = 7810f
[ 0.972049@1] sdio:pdata->caps2 = 0
[ 0.973427@0] sd: new high speed SDHC card at address 0007
[ 0.973432@0] sd: clock 50000000, 4-bit-bus-width
[ 0.973432@0]
[ 0.973684@0] mmcblk0: sd:0007 SS08G 7.21 GiB
[ 0.974591@1] mmcblk0: p1 p2
[ 0.974993@1] aml_emmc_hw_reset 1486
[ 0.991876@1] dwc_otg: Indeed it is in host mode hprt0 = 00021501
[ 1.011767@3] [aml_sd_emmc_probe] aml_sd_emmc_probe() success!
[ 1.011998@3] ion_dev has 1 memory regions
[ 1.014123@2] fb: osd_init_module
[ 1.014184@2] fb: viu vsync irq: 35
[ 1.014190@2] meson-fb has 1 memory regions
[ 1.014211@2] meson-fb meson-fb.15: assigned reserved memory node linux,meson-fb ok
[ 1.014223@2] fb: osd_probe vinfo:ffffffc001bbc548
[ 1.014228@2] fb: init fbdev bpp is:32
[ 1.015146@2] fb: Frame buffer memory assigned at
[ 1.015146@2] fb: 0, phy: 0x000000007bb80000, vir:0xffffff8001a00000, size=69120K
[ 1.015146@2]
[ 1.015148@2] fb: ---------------clear fb0 memory ffffff8001a00000
[ 1.053495@2] fb: osd[0] canvas.idx =0x40
[ 1.053497@2] fb: osd[0] canvas.addr=0x7bb80000
[ 1.053498@2] fb: osd[0] canvas.width=7680
[ 1.053499@2] fb: osd[0] canvas.height=3240
[ 1.053500@2] fb: osd[0] frame.width=1920
[ 1.053501@2] fb: osd[0] frame.height=1080
[ 1.053562@2] emmc: BKOPS_EN bit is not set
[ 1.059792@2] emmc: trying cali 0-th time(s)
[ 1.098161@0] Console: switching to colour frame buffer device 240x67
[ 1.127782@0] fb: osd probe OK
[ 1.127943@2] ge2d: ge2d_init_module
[ 1.127953@2] ge2d: ge2d_dev major:244
[ 1.128219@2] ge2d: ge2d clock is 400 MHZ
[ 1.128225@2] ge2d: ge2d: pdev=ffffffc06322d000, irq=182, rstc=0xffffffc063369c40, clk=ffffffc063115d00
[ 1.128266@2] ge2d: mapped phy: 0xd0160000
[ 1.128273@2] ge2d: ge2d start monitor
[ 1.128321@3] ge2d: ge2d workqueue monitor start
[ 1.128478@2] codec:Amlogic A/V streaming port init
[ 1.129767@2] codec:get gate demux control ok ffffffc063370080
[ 1.129774@2] codec:get gate parser_top control ok ffffffc063370100
[ 1.129779@2] codec:get gate vpu_intr control ok ffffffc063370180
[ 1.129785@2] codec:get gate vdec control ok ffffffc063370200
[ 1.130174@2] codec:[tsync_pcr_init]init success.
[ 1.130179@2] codec:amvideocap_init_module
[ 1.130243@2] codec:amvideocap_probe,amvideocap
[ 1.130246@2] codec:use cma buf.
[ 1.130249@2] codec:amvideocap_dev_register
[ 1.131736@2] codec:create_ge2d_work_queue video task ok
[ 1.132069@2] codec:register clk_set_setting cpu[31]
[ 1.132302@2] DI: di_module_init ok.
[ 1.132313@2] DI: di_module_init: major 240
[ 1.132522@2] DI: di_probe
[ 1.132652@2] deinterlace has 1 memory regions
[ 1.132682@2] DI: di reveser memory 0x79d80000, size 30MB.
[ 1.132690@2] deinterlace deinterlace.25: assigned reserved memory node linux,di ok
[ 1.132711@2] di_irq:78,timerc_irq:38
[ 1.132856@2] rdma_register, rdma_table_addr ffffff8000434000 rdma_table_addr_phy 7744a000 reg_buf ffffffc0625be000
[ 1.132860@2] rdma_register success, handle 1 table_size 8192
[ 1.132864@2] DI: di_probe allocate rdma channel 1.
[ 1.132868@2] DI: DI hw version 2.
[ 1.132878@2] 0x000000db:Y=db,U=0,V=0
[ 1.132881@2] 0x000000dc:Y=dc,U=0,V=0
[ 1.132884@2] 0x000000dd:Y=dd,U=0,V=0
[ 1.132887@2] 0x000000de:Y=de,U=0,V=0
[ 1.132891@2] 0x000000df:Y=df,U=0,V=0
[ 1.132894@2] 0x000000e0:Y=e0,U=0,V=0
[ 1.132897@2] 0x000000e1:Y=e1,U=0,V=0
[ 1.132900@2] 0x000000e2:Y=e2,U=0,V=0
[ 1.132903@2] 0x000000e3:Y=e3,U=0,V=0
[ 1.132906@2] 0x000000f0:Y=f0,U=0,V=0
[ 1.132911@2] 0x000000f1:Y=f1,U=0,V=0
[ 1.132914@2] 0x000000f2:Y=f2,U=0,V=0
[ 1.132917@2] 0x000000f3:Y=f3,U=0,V=0
[ 1.132920@2] 0x000000f4:Y=f4,U=0,V=0
[ 1.132923@2] 0x000000f5:Y=f5,U=0,V=0
[ 1.132926@2] 0x000000f6:Y=f6,U=0,V=0
[ 1.132930@2] 0x000000f7:Y=f7,U=0,V=0
[ 1.132933@2] 0x000000f8:Y=f8,U=0,V=0
[ 1.132936@2] 0x000000f9:Y=f9,U=0,V=0
[ 1.132939@2] 0x000000fa:Y=fa,U=0,V=0
[ 1.132943@2] 0x000000fb:Y=fb,U=0,V=0
[ 1.132946@2] 0x000000fc:Y=fc,U=0,V=0
[ 1.133038@2] DI: di_probe here.
[ 1.133245@2] efusekeynum: 4
[ 1.133253@2] efusekeyname: mac offset: 0 size: 6
[ 1.133259@2] efusekeyname: mac_bt offset: 6 size: 6
[ 1.133265@2] efusekeyname: mac_wifi offset: 12 size: 6
[ 1.133272@2] efusekeyname: usid offset: 18 size: 16
[ 1.133446@2] efuse efuse.10: probe OK!
[ 1.133623@2] key unify config unifykey-num is 14
[ 1.133659@2] key unify fact unifykey-num is 14
[ 1.133664@2] aml_unifykeys_probe:1202=============unifykey_devno:ee00000
[ 1.133836@2] 6unifykey: device unifykeys created ok
[ 1.133902@2] 6aml_unifykeys_init done!
[ 1.133905@2] PPMGRDRV: warn: ppmgr module init func called
[ 1.133949@2] PPMGRDRV: err: ppmgr_driver_probe called
[ 1.134068@2] ppmgr has 1 memory regions
[ 1.134088@2] PPMGRDRV: info: init ppmgr memsource 77d80000->79d7ffff
[ 1.134103@2] PPMGRDRV: info: ppmgr_dev major:237
[ 1.134277@2] PPMGRDRV: info: ppmgr_probe done
[ 1.134472@2] amlogic rfkill init
[ 1.134576@2] audio_dsp: [dsp]register dsp to char divece(257)
[ 1.135110@2] amaudio: amaudio: driver amaudio succuess!
[ 1.135418@2] hdmirx: hdmirx_init.
[ 1.135423@2] ESM HLD: Initializing...
[ 1.135426@2] ESM HLD: Registering device range 'esm_rx'...
[ 1.135432@2] ESM HLD: Device range 'esm_rx' has been registered.
[ 1.135436@2] ESM HLD: Creating class /sys/class/elliptic_rx...
[ 1.135489@2] ESM HLD: The class /sys/class/elliptic_rx has been created.
[ 1.135493@2] ESM HLD: Creating device 'esm_rx'...
[ 1.135599@2] ESM HLD: Device 'esm_rx' has been created.
[ 1.135603@2] ESM HLD: Done initializing the HLD driver.
[ 1.135788@2] nandphy: storage 1, boot 1
[ 1.135788@2]
[ 1.135794@2] nandphy: get_storage_dev return 1
[ 1.135794@2]
[ 1.135801@2] aml_nand d0074800.nand: do not init nand
[ 1.138691@2] remote: Driver init
[ 1.138725@2] remote: platform_data g_remote_ao_offset=580
[ 1.138729@2] remote: platform_data irq =228
[ 1.138756@2] remote: set drvdata completed
[ 1.138767@2] remote: device_create_file completed
[ 1.139036@2] input: aml_keypad as /devices/meson-remote.12/input/input0
[ 1.139235@2] remote: input_register_device completed
[ 1.139291@2] remote: set_remote_mode[74]
[ 1.139313@2] remote: remote config major:235
[ 1.139452@2] remote: physical address:0x6283e000
[ 1.139628@2] gpio-key gpio_keypad.46: gpio_key: 0 name(power) pin()
[ 1.139634@2] gpio-key gpio_keypad.46: amlogic_gpio_name_map_num pin 0!::
[ 1.139645@2] gpio-key gpio_keypad.46: gpio_key: 0 power(125)
[ 1.139668@2] gpio-key gpio_keypad.46: start setup_timer
[ 1.139676@2] gpio-key gpio_keypad.46: power key(116) registed.
[ 1.139803@2] input: gpio_keypad as /devices/gpio_keypad.46/input/input1
[ 1.139918@2] gpio-key gpio_keypad.46: gpio keypad register input device completed.
[ 1.139926@2] input input1: gpio keypad major:234
[ 1.142527@2] cpuinfo: probe done
[ 1.142762@2] cectx aocec: aml_cec_probe(): alloc chrdev e9
[ 1.143064@2] input: cec_input as /devices/virtual/input/input2
[ 1.143173@2] cectx aocec: aml_cec_probe(): using EE cec:0
[ 1.143254@2] cectx aocec: aml_cec_probe(): no hdmirx reg resource
[ 1.148633@2] cectx aocec: aml_cec_probe(): no hhi reg resource
[ 1.154578@2] cectx aocec: aml_cec_probe(): can't find hdmirx
[ 1.160408@2] cectx aocec: cec_enable_irq(): enable:int mask:0x6
[ 1.161209@2] cec: wake up flag:0
[ 1.163692@2] aml_spdif_dai: enterd aml_spdif_play,set_clock:-1,sample_rate=4
[ 1.163707@2] aml_spdif_dai: set normal 512 fs /4 fs
[ 1.163714@2] aml_audio_hw: IEC958 16bit
[ 1.163719@2] hdmitx: audio: aout notify rate 48000
[ 1.163722@2] hdmitx: audio: aout notify size 16
[ 1.163726@2] hdmitx: audio: aout notify format CT_PCM
[ 1.163730@2] hdmtix: set audio
[ 1.163743@2] hdmitx tx_aud_src = 0
[ 1.163769@2] hdmitx aud_n_para = 6144
[ 1.163787@2] hdmitx set channel status
[ 1.163848@2] hdmitx: audio: Audio Type: PCM
[ 1.163851@2] hdmitx: audio: set audio param
[ 1.164360@2] aml_snd_card: headphone detection disable=1
[ 1.164366@2] aml_snd_card: no spk event delay time set
[ 1.164929@2] aml_snd_m8_card aml_m8_snd.45: dummy <-> I2S.37 mapping ok
[ 1.165275@2] aml_snd_m8_card aml_m8_snd.45: dit-hifi <-> SPDIF.38 mapping ok
[ 1.165369@2] aml_snd_m8_card aml_m8_snd.45: pcm2bt-pcm <-> PCM.39 mapping ok
[ 1.171805@1] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.172044@0] dwc_otg: Indeed it is in host mode hprt0 = 00001101
[ 1.208164@2] emmc: delay[0]= 3125 padding= 7, bidx=3
[ 1.208168@2] emmc: delay[1]= 3250 padding= 6, bidx=3
[ 1.208173@2] emmc: delay[2]= 3875 padding= 1, bidx=3
[ 1.208176@2] emmc: delay[3]= 3375 padding= 5, bidx=3
[ 1.208181@2] emmc: delay[4]= 3250 padding= 6, bidx=3
[ 1.208184@2] emmc: delay[5]= 3000 padding= 8, bidx=3
[ 1.208188@2] emmc: delay[6]= 3375 padding= 5, bidx=3
[ 1.208192@2] emmc: delay[7]= 3000 padding= 8, bidx=3
[ 1.208195@2] emmc: calibration result @ 0: max(3875), min(3000)
[ 1.208199@2] emmc: line_delay =0x74754056, max_cal_result =3875
[ 1.208203@2] emmc: base_index_max 3, base_index_min 3
[ 1.208209@2] emmc: clk 200000000 SDR mode tuning start
[ 1.208492@2] emmc: rx_tuning_result[0] = 10
[ 1.208698@2] emmc: rx_tuning_result[1] = 10
[ 1.208902@2] emmc: rx_tuning_result[2] = 10
[ 1.209127@2] emmc: rx_tuning_result[4] = 10
[ 1.209132@2] emmc: best_win_start =4, best_win_size =4
[ 1.209135@2] emmc: adj_win_start 5
[ 1.209139@2] emmc: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x2007
[ 1.209143@2] emmc: gclock =0x1000245, gdelay=0x74754056, gadjust=0x2007
[ 1.209215@2] emmc: new HS200 MMC card at address 0001
[ 1.209219@1] emmc: clock 200000000, 8-bit-bus-width
[ 1.209219@1]
[ 1.209538@1] mmcblk1: emmc:0001 AWPD3R 14.5 GiB
[ 1.209634@1] mmcblk1boot0: emmc:0001 AWPD3R partition 1 4.00 MiB
[ 1.209736@1] mmcblk1boot1: emmc:0001 AWPD3R partition 2 4.00 MiB
[ 1.209829@1] mmcblk1rpmb: emmc:0001 AWPD3R partition 3 4.00 MiB
[ 1.210325@1] mmcblk1: unknown partition table
[ 1.210892@2] [mmc_read_partition_tbl] mmc read partition OK!
[ 1.210896@2] add_emmc_partition
[ 1.211028@1] [mmcblk1p01] bootloader offset 0x000000000000, size 0x000000400000
[ 1.211149@1] [mmcblk1p02] reserved offset 0x000002400000, size 0x000004000000
[ 1.211263@1] [mmcblk1p03] cache offset 0x000006c00000, size 0x000020000000
[ 1.211376@1] [mmcblk1p04] env offset 0x000027400000, size 0x000000800000
[ 1.211487@1] [mmcblk1p05] logo offset 0x000028400000, size 0x000002000000
[ 1.211601@1] [mmcblk1p06] recovery offset 0x00002ac00000, size 0x000002000000
[ 1.211713@1] [mmcblk1p07] rsv offset 0x00002d400000, size 0x000000800000
[ 1.211836@1] [mmcblk1p08] tee offset 0x00002e400000, size 0x000000800000
[ 1.211959@1] [mmcblk1p09] crypt offset 0x00002f400000, size 0x000002000000
[ 1.212074@1] [mmcblk1p10] misc offset 0x000031c00000, size 0x000002000000
[ 1.212185@1] [mmcblk1p11] instaboot offset 0x000034400000, size 0x000020000000
[ 1.212298@1] [mmcblk1p12] boot offset 0x000054c00000, size 0x000002000000
[ 1.212408@1] [mmcblk1p13] system offset 0x000057400000, size 0x000040000000
[ 1.212524@1] [mmcblk1p14] data offset 0x000097c00000, size 0x00030c200000
[ 1.212549@1] card key: card_blk_probe.
[ 1.212554@1] emmc_key_init:524 emmc key lba_start:0x12020,lba_end:0x12220
[ 1.212558@1] emmc key: emmc_key_init:549 ok.
[ 1.212562@1] amlmmc_dtb_init: register dtb chardev
[ 1.212705@1] amlmmc_dtb_init: register dtb chardev OK<6>[ 1.212764@1] Exit aml_emmc_partition_ops OK.
[ 1.213568@1] mmcblk1boot1: unknown partition table
[ 1.214124@1] mmcblk1boot0: unknown partition table
[ 1.214239@1] clear_emmc_wait_flag
[ 1.231771@2] input input1: key 116 up
[ 1.273960@2] aml_snd_card: audio use jtag pinmux as i2s output, read val =ffffffff
[ 1.278271@1] TCP: cubic registered
[ 1.278733@1] NET: Registered protocol family 10
[ 1.279286@1] NET: Registered protocol family 17
[ 1.279329@1] Key type dns_resolver registered
[ 1.280189@1] Registering SWP/SWPB emulation handler
[ 1.280899@1] regulator-dummy: disabling
[ 1.281126@1] console [netcon0] enabled
[ 1.281130@1] netconsole: network logging started
[ 1.281160@1] aml_vrtc rtc.29: setting system clock to 2015-01-01 00:00:04 UTC (1420070404)
[ 1.281866@1] cpufreq-scpi cpufreq-meson.7: enter cpufreq
[ 1.281894@1] cpufreq-scpi cpufreq-meson.7: probe cpufreq okay
[ 1.284352@0] gxbb_pm: enter meson_pm_probe!
[ 1.284392@0] gxbb_pm: meson_pm_probe done
[ 1.284536@0] aml_istbt_dev_ready NULL
[ 1.284649@0] ALSA device list:
[ 1.284653@0] #0: AML-M8AUDIO
[ 1.285042@0] Freeing unused kernel memory: 816K (ffffffc001a7d000 - ffffffc001b49000)
[ 1.306447@1] fb: osd[0] canvas.idx =0x40
[ 1.306449@1] fb: osd[0] canvas.addr=0x7bb80000
[ 1.306450@1] fb: osd[0] canvas.width=7680
[ 1.306451@1] fb: osd[0] canvas.height=2160
[ 1.306453@1] fb: osd[0] frame.width=1920
[ 1.306454@1] fb: osd[0] frame.height=1080
[ 1.332668@1] fb: Frame buffer memory assigned at
[ 1.332680@1] fb: 1, phy: 0x000000007ff00000, vir:0xffffff8005f00000, size=1024K
[ 1.332680@1]
[ 1.332687@1] fb: fb1 open, logo index:1
[ 1.361244@3] vfm_map_store:rm default
[ 1.361244@3]
[ 1.361323@3] vfm_map_store:add default decoder ppmgr deinterlace amvideo
[ 1.361323@3]
[ 1.361403@3] fb: osd[0] enable: 1 (platform_init)
[ 1.373073@3] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610
[ 1.373078@3] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.373082@3] usb 1-1: Product: USB2.0 Hub
[ 1.373801@3] hub 1-1:1.0: USB hub found
[ 1.374086@3] hub 1-1:1.0: 4 ports detected
[ 1.435481@3] aml_nftl_dev: module license 'Proprietary' taints kernel.
[ 1.435495@3] Disabling lock debugging due to kernel taint
[ 1.652261@3] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.794339@3] usb 1-1.1: New USB device found, idVendor=0bc2, idProduct=2320
[ 1.794381@3] usb 1-1.1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 1.794409@3] usb 1-1.1: Product: Expansion
[ 1.794435@3] usb 1-1.1: Manufacturer: Seagate
[ 1.794462@3] usb 1-1.1: SerialNumber: 123456789012
[ 1.796643@3] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 1.798567@3] scsi0 : usb-storage 1-1.1:1.0
[ 1.872220@3] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 1.973863@2] usb 1-1.3: New USB device found, idVendor=0480, idProduct=a006
[ 1.973900@2] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.973928@2] usb 1-1.3: Product: External USB 3.0
[ 1.973955@2] usb 1-1.3: Manufacturer: Toshiba
[ 1.973982@2] usb 1-1.3: SerialNumber: 2012112921438
[ 1.976037@1] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[ 1.976590@1] scsi1 : usb-storage 1-1.3:1.0
[ 2.244757@0] random: nonblocking pool is initialized
[ 2.793283@3] scsi 0:0:0:0: Direct-Access Seagate Expansion 060E PQ: 0 ANSI: 6
[ 2.796245@1] sd 0:0:0:0: [sda] 1953525167 512-byte logical blocks: (1.00 TB/931 GiB)
[ 2.811430@1] sd 0:0:0:0: [sda] Write Protect is off
[ 2.811469@1] sd 0:0:0:0: [sda] Mode Sense: 4f 00 00 00
[ 2.812422@1] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.851392@1] sda: sda1
[ 2.854987@1] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.371026@2] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 5.372240@2] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 5.642125@0] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 6.649712@1] scsi 1:0:0:0: Direct-Access TOSHIBA External USB 3.0 0001 PQ: 0 ANSI: 6
[ 6.653145@1] sd 1:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[ 6.653620@1] sd 1:0:0:0: [sdb] Write Protect is off
[ 6.653639@1] sd 1:0:0:0: [sdb] Mode Sense: 33 00 00 08
[ 6.654121@1] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 6.681465@1] sdb: sdb1
[ 6.684138@1] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 12.299903@2] systemd[1]: System time before build time, advancing clock.
[ 12.304977@2] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS -ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 12.305378@2] systemd[1]: Detected architecture arm64.
[ 12.305650@2] systemd[1]: Set hostname to <LibreELEC>.
[ 12.387462@2] systemd[1]: Created slice User and Session Slice.
[ 12.387648@2] systemd[1]: Created slice System Slice.
[ 12.387763@2] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 12.387794@2] systemd[1]: Reached target Slices.
[ 12.387913@2] systemd[1]: Listening on Journal Socket.
[ 12.388685@2] systemd[1]: Mounting Temporary Directory...
[ 12.389769@2] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.391116@2] systemd[1]: Mounting Debug File System...
[ 12.392760@2] systemd[1]: Listening on udev Kernel Socket.
[ 12.393001@2] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.397329@2] systemd[1]: Starting Setup machine-id...
[ 12.399382@2] systemd[1]: Mounting Variable Directory...
[ 12.402713@2] systemd[1]: Starting Load Kernel Modules...
[ 12.402912@2] systemd[1]: Listening on udev Control Socket.
[ 12.403130@2] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 12.403297@2] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 12.403332@2] systemd[1]: Reached target Paths.
[ 12.404736@2] systemd[1]: Starting Show Version...
[ 12.405907@2] systemd[1]: Starting Mounting swapfile...
[ 12.408577@2] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 12.410094@2] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.412900@2] systemd[1]: Mounted Debug File System.
[ 12.413012@2] systemd[1]: Mounted POSIX Message Queue File System.
[ 12.413059@2] systemd[1]: Mounted Variable Directory.
[ 12.413105@2] systemd[1]: Mounted Temporary Directory.
[ 12.414005@2] systemd[1]: Started Setup machine-id.
[ 12.414499@2] systemd[1]: Started Show Version.
[ 12.414797@2] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 12.415101@2] systemd[1]: Started Remount Root and Kernel File Systems.
[ 12.618816@2] systemd[1]: Starting udev Coldplug all Devices...
[ 12.623119@2] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 12.627104@2] systemd[1]: Starting Journal Service...
[ 12.633378@2] systemd[1]: Starting Setup Timezone data...
[ 12.662168@2] systemd[1]: Started Setup Timezone data.
[ 12.672397@2] systemd[1]: Started Create Static Device Nodes in /dev.
[ 12.675033@0] mali-utgard d00c0000.mali: set min pp to default 1
[ 12.675051@0] mali-utgard d00c0000.mali: set min clk default to 0
[ 12.675161@0] mali-utgard d00c0000.mali: max clk set 4
[ 12.675172@0] mali-utgard d00c0000.mali: turbo clk set to 5
[ 12.681692@2] systemd[1]: Reached target Local File Systems (Pre).
[ 12.683024@3] Mali: Mali device driver loaded
[ 12.684469@2] systemd[1]: Reached target Local File Systems.
[ 12.685550@2] systemd[1]: Started Load Kernel Modules.
[ 12.707911@2] systemd[1]: Mounting Configuration File System...
[ 12.709171@2] systemd[1]: Starting Apply Kernel Variables...
[ 12.713672@2] systemd[1]: Mounted Configuration File System.
[ 12.718212@2] systemd[1]: Started Apply Kernel Variables.
[ 12.749763@2] systemd[1]: Started Journal Service.
[ 12.792394@3] systemd-journald[1651]: Received request to flush runtime journal from PID 1
[ 13.398437@1] Console: switching to colour dummy device 80x25
[ 13.421418@1] Triggered SDIO WiFi power on and bus rescan.
[ 13.421448@1] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Disable! 234
[ 13.544183@3] remote: cur_mode = 0
[ 13.544206@3] remote: set_remote_mode[74]
[ 13.721830@1] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Enable! 234
[ 14.063050@2] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[ 14.067624@2] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[ 14.070168@2] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[ 14.142724@0] fuse init (API version 7.22)
[ 14.164051@2] sdio: clk 200000000 SDR mode tuning start
[ 14.164215@2] sdio: rx_tuning_result[0] = 10
[ 14.164363@2] sdio: rx_tuning_result[1] = 10
[ 14.164523@2] sdio: rx_tuning_result[3] = 10
[ 14.164670@2] sdio: rx_tuning_result[4] = 10
[ 14.164674@2] sdio: best_win_start =3, best_win_size =4
[ 14.164679@2] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x2000
[ 14.164688@2] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x2000
[ 14.166755@2] sdio: queuing unknown CIS tuple 0x91 (3 bytes)
[ 14.166782@2] sdio: new ultra high speed SDR104 SDIO card at address 0001
[ 14.166787@1] sdio: clock 200000000, 4-bit-bus-width
[ 14.166787@1]
[ 14.169541@1] [sdio_reinit] finish
[ 14.178682@0] Bluetooth: Core ver 2.18
[ 14.178948@0] NET: Registered protocol family 31
[ 14.178957@0] Bluetooth: HCI device and connection manager initialized
[ 14.178982@0] Bluetooth: HCI socket layer initialized
[ 14.178988@0] Bluetooth: L2CAP socket layer initialized
[ 14.179013@0] Bluetooth: SCO socket layer initialized
[ 14.184318@0] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 14.184937@3] cfg80211: Calling CRDA to update world regulatory domain
[ 14.205363@3] dhd_module_init: in
[ 14.205378@3] ======== bcm_wlan_set_plat_data ========
[ 14.205382@3] host_oob_irq: 100
[ 14.205385@3] host_oob_irq_flags=0x414
[ 14.205388@3] dhd_wifi_platform_load: Enter
[ 14.205404@3] Power-up adapter 'DHD generic adapter'
[ 14.205408@3] wifi_platform_set_power = 1
[ 14.205411@3] ======== PULL WL_REG_ON HIGH! ========
[ 14.205440@3] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Disable! 234
[ 14.225215@1] meson_uart c11084c0.serial: ttyS1 use xtal(8M) 24000000 change 0 to 9600
[ 14.226601@1] meson_uart c11084c0.serial: ttyS1 use xtal(8M) 24000000 change 9600 to 9600
[ 14.226632@1] meson_uart c11084c0.serial: ttyS1 use xtal(8M) 24000000 change 9600 to 115200
[ 14.322212@0] **************ip101 re***************
[ 14.405487@3] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Enable! 234
[ 14.730677@0] 8021q: 802.1Q VLAN Support v1.8
[ 14.911789@3] wifi_platform_bus_enumerate device present 1
[ 14.911802@3] ======== Card detection to detect SDIO card! ========
[ 14.911806@3] sdio_reset_comm():
[ 16.219531@2] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[ 16.224147@2] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[ 16.226718@2] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[ 16.321990@2] sdio: clk 200000000 SDR mode tuning start
[ 16.322162@2] sdio: rx_tuning_result[0] = 10
[ 16.322314@2] sdio: rx_tuning_result[1] = 10
[ 16.322475@2] sdio: rx_tuning_result[3] = 10
[ 16.322622@2] sdio: rx_tuning_result[4] = 10
[ 16.322627@2] sdio: best_win_start =3, best_win_size =4
[ 16.322631@2] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x2000
[ 16.322636@2] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x2000
[ 16.322641@2] [sdio_reinit] finish
[ 16.339942@2] bcmsdh_register: register client driver
[ 16.340008@2] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 16.340050@2] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[ 16.340055@2] bus num (host idx)=0, slot num (rca)=1
[ 16.340058@2] found adapter info 'DHD generic adapter'
[ 16.340092@2] sdioh_attach: set sd_f2_blocksize 128
[ 16.340272@2] dhdsdio_probe : no mutex held. set lock
[ 16.340341@2] F1 signature read @0x18000000=0x16014335
[ 16.342454@2] F1 signature OK, socitype:0x1 chip:0x4335 rev:0x1 pkg:0x0
[ 16.342766@2] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 16.342823@2] dhd_conf_set_chiprev: chip=0x4335, chiprev=1
[ 16.342860@2] dhd_conf_set_conf_path_by_nv_path: config_path=/lib/firmware/brcm/config.txt
[ 16.343335@0] dhd_conf_read_nv_by_chip: nv_by_chip_count=5
[ 16.343341@0] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=0, name=nvram_ap6181.txt
[ 16.343345@0] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=1, name=nvram_ap6210.txt
[ 16.343350@0] dhd_conf_read_nv_by_chip: chip=0xa9a6, chiprev=0, name=nvram_ap6212.txt
[ 16.343354@0] dhd_conf_read_nv_by_chip: chip=0x4330, chiprev=4, name=nvram_ap6330.txt
[ 16.343358@0] dhd_conf_read_nv_by_chip: chip=0x4339, chiprev=1, name=nvram_ap6335e.txt
[ 16.343535@0] dhd_conf_read_config: bcn_timeout = 20
[ 16.343571@0] dhd_conf_read_config: kso_enable = 0
[ 16.343703@0] dhd_conf_read_config: PM = 0
[ 16.344547@3] wl_create_event_handler(): thread:wl_event_handler:a5b started
[ 16.344554@2] tsk Enter, tsk = 0xffffff80019e7940
[ 16.344704@3] dhd_attach(): thread:dhd_watchdog_thread:a5d started
[ 16.344730@3] dhd_attach(): thread:dhd_dpc:a5e started
[ 16.344742@2] dhd_dpc_thread: set dpc_cpucore 0 from config.txt
[ 16.344770@3] dhd_attach(): thread:dhd_rxf:a5f started
[ 16.344779@3] dhd_deferred_work_init: work queue initialized
[ 16.350797@2] Dongle Host Driver, version 1.201.59.6 (r506368)
[ 16.350797@2] Compiled in drivers/net/wireless/bcmdhd
[ 16.351288@2] Register interface [wlan0] MAC: cc:3a:61:04:15:eb
[ 16.351288@2]
[ 16.351297@2] dhd_prot_ioctl : bus is down. we have nothing to do
[ 16.351336@2] bcmsdh_oob_intr_unregister: Enter
[ 16.351340@2] bcmsdh_oob_intr_unregister: irq is not registered
[ 16.351348@2] dhd_txglom_enable: enable 0
[ 16.351351@2] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 16.351355@2] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 16.351358@2] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0
[ 16.351362@2] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
[ 16.351365@2] dhd_bus_devreset: WLAN OFF DONE
[ 16.351401@2] wifi_platform_set_power = 0
[ 16.351405@2] ======== PULL WL_REG_ON LOW! ========
[ 16.351409@2] dhdsdio_probe : the lock is released.
[ 16.351489@2] dhd_module_init: Exit err=0
[ 16.403928@0] dhd_open: Enter ffffffc062bf5000
[ 16.403944@0]
[ 16.403944@0] Dongle Host Driver, version 1.201.59.6 (r506368)
[ 16.403944@0] Compiled in drivers/net/wireless/bcmdhd
[ 16.403954@0] wl_android_wifi_on in 1
[ 16.403959@0] wl_android_wifi_on in 2: g_wifi_on=0
[ 16.403967@0] wifi_platform_set_power = 1
[ 16.403971@0] ======== PULL WL_REG_ON HIGH! ========
[ 16.403998@0] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Disable! 234
[ 16.604031@0] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Enable! 234
[ 17.111932@0] sdio_reset_comm():
[ 17.144580@2] sdio: queuing unknown CIS tuple 0x80 (2 bytes)
[ 17.150203@2] sdio: queuing unknown CIS tuple 0x80 (7 bytes)
[ 17.153976@2] sdio: queuing unknown CIS tuple 0x80 (3 bytes)
[ 17.247064@2] sdio: clk 200000000 SDR mode tuning start
[ 17.247263@2] sdio: rx_tuning_result[0] = 10
[ 17.247452@2] sdio: rx_tuning_result[1] = 10
[ 17.247658@2] sdio: rx_tuning_result[3] = 10
[ 17.247847@2] sdio: rx_tuning_result[4] = 10
[ 17.247853@2] sdio: best_win_start =3, best_win_size =4
[ 17.247859@2] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x2000
[ 17.247866@2] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x2000
[ 17.247907@2] sdioh_start: set sd_f2_blocksize 128
[ 17.248186@2]
[ 17.248186@2]
[ 17.248186@2] dhd_bus_devreset: == WLAN ON ==
[ 17.248279@2] F1 signature read @0x18000000=0x16014335
[ 17.250900@2] F1 signature OK, socitype:0x1 chip:0x4335 rev:0x1 pkg:0x0
[ 17.251321@2] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 17.251867@2] dhd_conf_read_nv_by_chip: nv_by_chip_count=5
[ 17.251884@2] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=0, name=nvram_ap6181.txt
[ 17.251897@2] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=1, name=nvram_ap6210.txt
[ 17.251910@2] dhd_conf_read_nv_by_chip: chip=0xa9a6, chiprev=0, name=nvram_ap6212.txt
[ 17.251923@2] dhd_conf_read_nv_by_chip: chip=0x4330, chiprev=4, name=nvram_ap6330.txt
[ 17.251935@2] dhd_conf_read_nv_by_chip: chip=0x4339, chiprev=1, name=nvram_ap6335e.txt
[ 17.252456@2] dhd_conf_read_config: bcn_timeout = 20
[ 17.252570@2] dhd_conf_read_config: kso_enable = 0
[ 17.252967@2] dhd_conf_read_config: PM = 0
[ 17.253372@2] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/
[ 17.253384@2] dhdsdio_download_firmware: set use_rxchain 0
[ 17.253393@2] dhdsdio_download_firmware: set txglomsize 40
[ 17.253403@2] sdioh_set_mode: set txglom_mode to multi-desc
[ 17.253411@2] Final fw_path=/lib/firmware/brcm/
[ 17.253425@2] Final nv_path=/lib/firmware/brcm/
[ 17.253433@2] Final conf_path=/lib/firmware/brcm/config.txt
[ 17.254062@2] dhdsdio_download_code_file: dhd_os_get_image_block failed (-21)
[ 17.254077@2] _dhdsdio_download_firmware: dongle image file download failed
[ 17.254126@2] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 17.254139@2] dhd_prot_ioctl : bus is down. we have nothing to do
[ 17.254151@2] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 17.254228@2] wifi_platform_set_power = 0
[ 17.254239@2] ======== PULL WL_REG_ON LOW! ========
[ 17.254248@2] wl_android_wifi_on: Failed
[ 17.254258@2] dhd_open : wl_android_wifi_on failed (-35)
[ 17.254270@2] dhd_stop: Enter ffffffc062bf5000
[ 17.254279@2] wl_android_wifi_off in 1
[ 17.254294@2] wl_android_wifi_off in 2: g_wifi_on=0
[ 17.254302@2] wl_android_wifi_off out
[ 17.254310@2] dhd_stop: Exit
[ 17.254321@2] dhd_open: Exit ret=-1
[ 17.254968@2] dhd_open: Enter ffffffc062bf5000
[ 17.254986@2]
[ 17.254986@2] Dongle Host Driver, version 1.201.59.6 (r506368)
[ 17.254986@2] Compiled in drivers/net/wireless/bcmdhd
[ 17.255004@2] wl_android_wifi_on in 1
[ 17.255013@2] wl_android_wifi_on in 2: g_wifi_on=0
[ 17.255022@2] wifi_platform_set_power = 1
[ 17.255030@2] ======== PULL WL_REG_ON HIGH! ========
[ 17.255076@2] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Disable! 234
[ 17.455118@2] aml_wifi wifi.30: [extern_wifi_set_enable] WIFI Enable! 234
[ 17.961805@2] sdio_reset_comm():
[ 18.091663@2] sdio: clk 200000000 SDR mode tuning start
[ 18.091985@2] sdio: rx_tuning_result[0] = 10
[ 18.092177@2] sdio: rx_tuning_result[1] = 10
[ 18.092385@2] sdio: rx_tuning_result[3] = 10
[ 18.092574@2] sdio: rx_tuning_result[4] = 10
[ 18.092580@2] sdio: best_win_start =3, best_win_size =4
[ 18.092586@2] sdio: sd_emmc_regs->gclock=0x1000245,sd_emmc_regs->gadjust=0x2000
[ 18.092592@2] sdio: gclock =0x1000245, gdelay=0x0, gadjust=0x2000
[ 18.092634@2] sdioh_start: set sd_f2_blocksize 128
[ 18.092914@2]
[ 18.092914@2]
[ 18.092914@2] dhd_bus_devreset: == WLAN ON ==
[ 18.093053@2] F1 signature read @0x18000000=0x16014335
[ 18.095685@2] F1 signature OK, socitype:0x1 chip:0x4335 rev:0x1 pkg:0x0
[ 18.096109@2] DHD: dongle ram size is set to 786432(orig 786432) at 0x180000
[ 18.096574@2] dhd_conf_read_nv_by_chip: nv_by_chip_count=5
[ 18.096582@2] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=0, name=nvram_ap6181.txt
[ 18.096589@2] dhd_conf_read_nv_by_chip: chip=0xa962, chiprev=1, name=nvram_ap6210.txt
[ 18.096595@2] dhd_conf_read_nv_by_chip: chip=0xa9a6, chiprev=0, name=nvram_ap6212.txt
[ 18.096602@2] dhd_conf_read_nv_by_chip: chip=0x4330, chiprev=4, name=nvram_ap6330.txt
[ 18.096608@2] dhd_conf_read_nv_by_chip: chip=0x4339, chiprev=1, name=nvram_ap6335e.txt
[ 18.096870@2] dhd_conf_read_config: bcn_timeout = 20
[ 18.096924@2] dhd_conf_read_config: kso_enable = 0
[ 18.097123@2] dhd_conf_read_config: PM = 0
[ 18.097325@2] dhd_conf_set_fw_name_by_chip: firmware_path=/lib/firmware/brcm/
[ 18.097332@2] dhdsdio_download_firmware: set use_rxchain 0
[ 18.097336@2] dhdsdio_download_firmware: set txglomsize 40
[ 18.097341@2] sdioh_set_mode: set txglom_mode to multi-desc
[ 18.097346@2] Final fw_path=/lib/firmware/brcm/
[ 18.097350@2] Final nv_path=/lib/firmware/brcm/
[ 18.097354@2] Final conf_path=/lib/firmware/brcm/config.txt
[ 18.097696@2] dhdsdio_download_code_file: dhd_os_get_image_block failed (-21)
[ 18.097703@2] _dhdsdio_download_firmware: dongle image file download failed
[ 18.097733@2] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 18.097740@2] dhd_prot_ioctl : bus is down. we have nothing to do
[ 18.097746@2] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 18.097785@2] wifi_platform_set_power = 0
[ 18.097790@2] ======== PULL WL_REG_ON LOW! ========
[ 18.097795@2] wl_android_wifi_on: Failed
[ 18.097800@2] dhd_open : wl_android_wifi_on failed (-35)
[ 18.097806@2] dhd_stop: Enter ffffffc062bf5000
[ 18.097811@2] wl_android_wifi_off in 1
[ 18.097815@2] wl_android_wifi_off in 2: g_wifi_on=0
[ 18.097819@2] wl_android_wifi_off out
[ 18.097823@2] dhd_stop: Exit
[ 18.097830@2] dhd_open: Exit ret=-1
[ 18.322070@0] libphy: stmmac-0:00 - Link is Up - 100/Full
[ 18.322135@0] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 24.947353@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.947369@3] aml_audio_hw: IEC958 16bit
[ 24.947375@3] hdmitx: audio: aout notify rate 48000
[ 24.947378@3] hdmitx: audio: aout notify size 16
[ 24.947382@3] hdmitx: audio: no update
[ 24.963341@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.963356@3] aml_audio_hw: IEC958 16bit
[ 24.963362@3] hdmitx: audio: aout notify rate 48000
[ 24.963366@3] hdmitx: audio: aout notify size 16
[ 24.963369@3] hdmitx: audio: no update
[ 24.964678@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.964688@3] aml_audio_hw: IEC958 16bit
[ 24.964693@3] hdmitx: audio: aout notify rate 48000
[ 24.964696@3] hdmitx: audio: aout notify size 16
[ 24.964699@3] hdmitx: audio: no update
[ 24.965332@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.965341@3] aml_audio_hw: IEC958 16bit
[ 24.965345@3] hdmitx: audio: aout notify rate 48000
[ 24.965348@3] hdmitx: audio: aout notify size 16
[ 24.965352@3] hdmitx: audio: no update
[ 24.966454@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.966462@3] aml_audio_hw: IEC958 16bit
[ 24.966466@3] hdmitx: audio: aout notify rate 48000
[ 24.966469@3] hdmitx: audio: aout notify size 16
[ 24.966471@3] hdmitx: audio: no update
[ 24.967574@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.967583@3] aml_audio_hw: IEC958 16bit
[ 24.967587@3] hdmitx: audio: aout notify rate 48000
[ 24.967590@3] hdmitx: audio: aout notify size 16
[ 24.967592@3] hdmitx: audio: no update
[ 24.968217@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 24.968227@3] aml_audio_hw: IEC958 16bit
[ 24.968231@3] hdmitx: audio: aout notify rate 48000
[ 24.968234@3] hdmitx: audio: aout notify size 16
[ 24.968237@3] hdmitx: audio: no update
[ 25.029324@1] audio_dsp: buf=0
[ 25.029338@1] audio_dsp: IEC958_mode_raw=0
[ 25.029365@1] audio_dsp: IEC958_mode_codec= 0, IEC958 type 2 CH PCM
[ 25.029369@1] audio_dsp: last mode 0,now 0
[ 25.033745@1] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100
[ 25.033769@1] aml_spdif_dai: set normal 512 fs /4 fs
[ 25.033774@1] aml_spdif_dai: iec958 mode PCM16
[ 25.033781@1] aml_audio_hw: IEC958 16bit
[ 25.033786@1] hdmitx: audio: aout notify rate 44100
[ 25.033789@1] hdmitx: audio: aout notify size 16
[ 25.033794@1] hdmtix: set audio
[ 25.033807@1] hdmitx tx_aud_src = 0
[ 25.033833@1] hdmitx aud_n_para = 6144
[ 25.033851@1] hdmitx set channel status
[ 25.033910@1] hdmitx: audio: Audio Type: PCM
[ 25.033913@1] hdmitx: audio: set audio param
[ 25.034129@3] aml_spdif_dai: aml_hw_iec958_init,runtime->rate=44100
[ 25.034134@3] aml_spdif_dai: set normal 512 fs /4 fs
[ 25.034138@3] aml_spdif_dai: iec958 mode PCM16
[ 25.034143@3] aml_audio_hw: IEC958 16bit
[ 25.034147@3] hdmitx: audio: aout notify rate 44100
[ 25.034149@3] hdmitx: audio: aout notify size 16
[ 25.034152@3] hdmitx: audio: no update
[ 25.038670@3] aml_spdif_dai: aiu 958 playback enable
[ 25.246128@0] fb: osd[0] enable: 1 (kodi.bin)
[ 25.886833@1] CEC: tx msg len: 1 dat: f0
[ 26.051205@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 26.082787@0] CEC: tx msg len: 1 dat: f0
[ 26.247158@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 26.283929@0] CEC: tx msg len: 1 dat: 44
[ 26.353467@0] CEC: tx msg len: 1 dat: 88
[ 26.517823@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 26.552824@0] CEC: tx msg len: 1 dat: 88
[ 26.717194@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 26.752036@0] cectx aocec: hdmitx_cec_ioctl(): CEC LA ARG:8
[ 26.753595@0] cectx aocec: cec_logicaddr_set(): set logical addr:0x18
[ 26.755213@0] CEC: tx msg len: 5 dat: 8f 84 14 00 04
[ 26.913450@0] CEC: tx msg len: 1 dat: 80
[ 27.077819@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 27.112790@0] CEC: tx msg len: 1 dat: 80
[ 27.277160@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 27.312894@0] CEC: tx msg len: 1 dat: 80
[ 27.477263@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 27.512784@3] CEC: tx msg len: 1 dat: 80
[ 27.677151@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 27.713626@0] CEC: tx msg len: 1 dat: 80
[ 27.877989@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 27.912815@0] CEC: tx msg len: 1 dat: 80
[ 28.077176@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 28.113218@0] CEC: tx msg len: 4 dat: 8f 82 14 00
[ 28.252834@0] CEC: tx msg len: 1 dat: 80
[ 28.417211@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 28.452818@3] CEC: tx msg len: 1 dat: 80
[ 28.617183@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 29.652980@3] CEC: tx msg len: 1 dat: 80
[ 29.817348@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 29.853025@3] CEC: tx msg len: 1 dat: 80
[ 30.017390@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 31.052973@3] CEC: tx msg len: 1 dat: 80
[ 31.217341@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 31.252897@3] CEC: tx msg len: 1 dat: 80
[ 31.417284@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 32.453505@3] CEC: tx msg len: 1 dat: 80
[ 32.617860@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 32.653019@3] CEC: tx msg len: 1 dat: 80
[ 32.817384@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 33.855517@3] CEC: tx msg len: 1 dat: 80
[ 34.019897@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 34.053115@0] CEC: tx msg len: 1 dat: 80
[ 34.217458@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 35.255259@0] CEC: tx msg len: 1 dat: 80
[ 35.419607@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 35.452808@0] CEC: tx msg len: 1 dat: 80
[ 35.617244@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 36.654250@0] CEC: tx msg len: 1 dat: 80
[ 36.818645@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 36.852981@2] CEC: tx msg len: 1 dat: 80
[ 37.017352@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 38.053101@2] CEC: tx msg len: 1 dat: 80
[ 38.217457@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 38.252919@0] CEC: tx msg len: 1 dat: 80
[ 38.417284@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 39.453400@3] CEC: tx msg len: 1 dat: 80
[ 39.617762@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 39.652969@0] CEC: tx msg len: 1 dat: 80
[ 39.817361@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 40.853527@0] CEC: tx msg len: 1 dat: 80
[ 41.017898@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 41.053497@2] CEC: tx msg len: 1 dat: 80
[ 41.217816@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 42.253110@2] CEC: tx msg len: 1 dat: 80
[ 42.417464@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 42.452738@2] CEC: tx msg len: 1 dat: 80
[ 42.617174@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 43.654547@2] CEC: tx msg len: 1 dat: 80
[ 43.818943@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 43.853005@2] CEC: tx msg len: 1 dat: 80
[ 44.017376@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 45.053954@2] CEC: tx msg len: 1 dat: 80
[ 45.218272@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 45.252758@2] CEC: tx msg len: 1 dat: 80
[ 45.417127@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 46.452883@2] CEC: tx msg len: 1 dat: 80
[ 46.617255@0] cectx aocec: tx_irq_handle(): TX ERROR!!!
[ 46.652836@0] CEC: tx msg len: 1 dat: 80
Display More
