[S905] Device trees
  • kostaman I just read your post in your other thread regarding the command you just posted. Is there anyway to enable console access on Libreelec? I can't ssh to the box right now because wifi is not enabled on the box right now and the box does not have ethernet.
  • What does the code that you posted do?
    Identify your Wifi Chip. Don't worry about it. That chip of yours is being used in various new boxes when i googled.
    That's how i got the Manufacturer. Get a PowerLine adapter kit. I hate Wifi for Video Streaming.
  • I tried the download link on the Libreelec 9 thread and it appears to be down.
    Unsupported: [8.90.1] CoreELEC for S905/S912 devices
  • Hi there,
    Can anyone tell me which device tree should I choose for Mecool M8S PRO+ to CoreELEC-S905.arm-8.90.4.img.gz ?!?!?!!?
    I tried this one " gxbb_p200_2G_m8s+_k3_pro " but it didn´t pass the Mecool screen , and I didn´t find anyone with a name resemble to my box ...
    Thanks a lot ...
  • hi all
    i want help for Dune HD Sky 4K Plus : S905D
    here "dtb.img" from Android Firmware
    Files
    • dtb.zip
      (21.25 kB, downloaded 97 times, last: )
  • i've got
    x95mini
    S905W
    SK hynix
    H26m41103HPR
    RAM 1G 8GB
    2ea hynix H5TQ2G43BFR
    SV6051P
    chiset: Q6X V2.2 17355 and
    i used dtb.img file "gxl_p212_1g_nand.dtb"
    from: https://kszaq.libreelec.tv/s905/8.2/device_trees/s905x/
    if i put sdcard , i can use kodi but
    if i enter putty and write "installtointernal "
    and
    "One of BOOT, SYTEM, DATA or DTB partitions is missing.
    Make sure that you are using a correct device tree and a device with internal memory!"
    so i can't use "installtointernal" help me
    and i can speak only a littl english. sorry
  • I have a new Android TV box and new dtb file from Android system.
    Congratulations on your Mystery Android Box.
    No specs supplied.
    Good luck getting anyone's attention here.
  • Here is the dtb file for the XORO HST 260 S Box with internal DVB-S2 Tuner from the original Android Image. I need to run this with LE or CE
    Files
  • Hey Everyone,
    Great work so and THANK YOU ALL
    Adding on I haven't seen yet.
    Goobang Doo M8S-II (only marking on the board is "S905_V03")
    CPU: S905
    RAM: 2G
    ROM: 8G
    NIC: 1G
    OTG Port Yes
    Extracted the dtb directly from the "aml_upgrade_package.img" Android 5.1.1
    Can I use an existing dtb or is it worth it getting this one added to make sure all features are available?
    Files
    • meson1.zip
      (8.45 kB, downloaded 95 times, last: )
  • I got a MGV2000 with gxlx_p261_1g board. CPU is S905Lv2 (or maybe S905L-B but not S905L2)
    and i extract dtb files from android boot.img
    hope it can helps
    Edited 2 times, last by chalesy: link dead , remove it ().
