srt subs are the most basic of basic for subs....you shouldn't really be having problems with srt...if its was ass..then yea I could see it
![](https://forum.libreelec.tv/core/images/avatars/0c/298-0c5223d8271c05b8d8eabc4fbf9b7b500b44e3fe.webp)
[8.90.11a] LibreELEC 9.x for S912
afl1 -
November 13, 2017 at 12:24 PM -
Closed -
here is video prove:
h265 with PGS subtitleExternal Content youtu.beContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.Code
Display MoreVideo ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format-Profil : Main@L4@Main Codec-ID : V_MPEGH/ISO/HEVC Dauer : 1 h 8 min Breite : 1 920 Pixel Höhe : 1 080 Pixel Bildseitenverhältnis : 16:9 Modus der Bildwiederholungsrate : konstant Bildwiederholungsrate : 23,976 (24000/1001) FPS ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 8 bits verwendete Encoder-Bibliothek : x265 2.1:[Windows][GCC 5.4.0][64 bit] 8bit Kodierungseinstellungen : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=20 / lookahead-slices=6 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / log2-max-poc-lsb=8 / no-rd-refine / signhide / deblock=0:0 / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ipratio=1.40 / pbratio=1.30 Default : Ja Forced : Nein colour_range : Limited colour_primaries : BT.709 transfer_characteristics : BT.709 matrix_coefficients : BT.709 Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Format-Einstellungen für Endianess : Big Codec-ID : A_AC3 Dauer : 1 h 8 min Bitraten-Modus : konstant Bitrate : 448 kb/s Kanäle : 6 Kanäle Kanal-Positionen : Front: L C R, Side: L R, LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 31,250 FPS (1536 SPF) BitDepth/String : 16 bits Stream-Größe : 218 MiB (5%) Titel : Surround Sprache : Deutsch ServiceKind/String : Complete Main Default : Ja Forced : Nein Audio #2 ID : 3 Format : TrueHD Format-Profil : TrueHD+Atmos / TrueHD Codec-ID : A_TRUEHD Bitraten-Modus : variabel maximale Bitrate : 8 325 kb/s Kanäle : Object Based / 8 Kanäle Kanal-Positionen : Object Based / Front: L C R, Side: L R, Back: L R, LFE Samplingrate : / 48,0 kHz Bildwiederholungsrate : 1 200,000 FPS (40 SPF) Titel : Surround Sprache : Englisch Default : Nein Forced : Nein Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Format-Einstellungen für Endianess : Big Codec-ID : A_AC3 Dauer : 1 h 8 min Bitraten-Modus : konstant Bitrate : 448 kb/s Kanäle : 6 Kanäle Kanal-Positionen : Front: L C R, Side: L R, LFE Samplingrate : 48,0 kHz Bildwiederholungsrate : 31,250 FPS (1536 SPF) BitDepth/String : 16 bits Stream-Größe : 218 MiB (5%) Titel : Surround Sprache : Spanisch ServiceKind/String : Complete Main Default : Nein Forced : Nein Text #1 ID : 5 Format : PGS Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Sprache : Deutsch Default : Nein Forced : Nein Text #2 ID : 6 Format : PGS Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Sprache : Englisch Default : Nein Forced : Nein Text #3 ID : 7 Format : PGS Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Sprache : Spanisch Default : Nein Forced : Nein Text #4 ID : 8 Format : PGS Codec-ID : S_HDMV/PGS Codec-ID/Info : Picture based subtitle format used on BDs/HD-DVDs Sprache : Spanisch Default : Nein Forced : Nein Menü 00:00:00.000 : :Chapter 1 00:01:55.907 : :Chapter 2 00:10:03.478 : :Chapter 3 00:18:16.929 : :Chapter 4 00:27:40.742 : :Chapter 5 00:38:48.618 : :Chapter 6 00:47:29.930 : :Chapter 7 00:57:17.225 : :Chapter 8 01:06:42.499 : :Chapter 9
Working fine in this example! And that's one of the problems. It does not ALWAYS stutter, but when it starts it gets really annoying. The fact that stuttering is a problem has been established in the thread dropped frames caused by subtitle rendering and the devs are not too optimistic, that it will ever go away completely for the 912.
But the fine people who work for us in their spare time are still at it and maybe/hopefully they succeed. When they do we will know and praise them even more!
And now I'll fire up my minix and update to 8.90.7-K
Well, I will test some more. Surely you have the problem more likely then me since you didnt update until now. The timing improvements only have been added in this latest build (8.9.7) as I understand
Every overlay frame rendering on S912 last longer than frame time. And this value is every frame adding to delay till it crossed the border of next frame. Then it is necessary skip the frame. Optimizing frame rendering timing can remedy this delay on the frames without overlay. To test this frame skipping u can toggle overlay codec info by ctrl-shift-o and see permanent frame skipping.
I’m currently running kzaqs 8.2.1.1 on S912 device.. could somebody please tell me what’s the benefits and drawbacks of upgrading to this build?
- Official Post
"if it works, don't fix it"
Subtitles border outlining sometimes lasts >100ms. I prepared build with disabled border outlining.
Subtitles border outlining sometimes last >100ms. I prepared build with disabled border outlining.
with due respect kindly prepare build for S905X box.
I've just tested it. I see definitely less stuttering but for the most part it's sadly still occurs.
is there an easy way to force video driver to 1920x1080i 50Hz RGB Mode ?
Easy way means to edit a file..
Pls read #1.
Pls read #1.
Oh sorry.. Have different boxes to get ready to be XMAS gift
didn´t see rgb mode not working
afl1 Recently I have developed an improvement for libhybris and updated libMali to r16p0 from Android Nougat. I did some tests with Krypton and software-decoded videos are much smoother than with r11p0. I haven't included the improvement in my builds yet but you can cherry-pick to Leia:
That's great news to know. Does that means playback of streaming from Netflix or Amazon which use software decoding would be improved as well?
wkchick I hope so.
