- kszaq
- Thread is Unresolved
can i use the same image for s905x oder s905?
Pls read instructions
[HOWTO + FAQ] Install community builds on S905/S905X/S912 device
can i use the same image for s905x oder s905? i can only find s905 images...
Sorry if this is a stupid question, iam new with this android boxes...
is this the right image for my antsir d6 tv box wit s905x chipset?
LibreELEC-S905.arm-8.2-8.1.10.img.gz
thanks alot!!
Yes - the images work for both S905 and S905X
thank you very much!!
just remember to use the correct device tree
Hello,
Since version 8.1.9, I am experienced stuttering with live-tv (using dvblink pvr client). On my computer, same configuration, I do not have any problem. I rollbacked to v8.1.8, and the issue has gone.
Does anyone have experienced this also ? Is there any fix regarding this ?
Thank you
Same Problem here
It worked on my tx3pro s905x . Only problem is the included android tv remote doesn't work now. Just using the tv remote or the Kore cell phone app for now.
Thank you
From the "HOWTO page":
"Grab remote.conf file from Android firmware (it's available in /system/etc) and copy it to Configuration folder"
Thank you
Custom remote and keymaps. You might like it.
Does anyone know how to control the LCD display on tanix tx3 mini (S905W) running this LibreELEC build? Mine always shows this text all the time
Google Search LCDs - Official Kodi Wiki
How to test rj45 net speed in LE ??? thnx
iperf
Just a heads up in case you missed this in the news while on vacation. This is an issue that needs to be patched at the LE level. There are stable Linux patches already pushed out, and would be surprised if the patch wasn't already upstream LE even, so it should be fairly easy to pull in, just making sure it gets noticed. Thanks....
Is there a official release for 905 amlogic 905 boxes with install guide? I’ve looked but I can’t see one
Hi,
libreelec is on tv box (antsir d6 tv box wit s905x chipset) runs great, but how can i make bluetooth and remote to work?
can anybody help me?
Thx
Remote repository remote.conf repository
if nothing there search on the forum, creating a remote from scratch
Can I help do some testing to force RGB?
Not official, community
