That works perfectly. Thanks for that.
VPN Manager for OpenVPN
zomboided -
February 16, 2017 at 10:26 AM -
Hi everyone,
I have the libreelec 9.2.8 version / raspberry pi 3b and I can't install vpn manager. I always get this error:
"the dependency on xmbc.python version 3.0.0 could not be satisfied"
Thank you for your help
Hi everyone,
You need LE 10 or higher to get Python 3.
Hi everyone,
Take the old version 6.4.2 instead. But recommendations is to update to matrix/nexus to get updates for the plug-in and new ones
Hello,
I am using libreelec 10.0.0.4 on raspberry 4b, fresh installation with openvpn and Nordvpn and I get dns leak, I tried to search in the topic and googled but I am a bit confused on how to fix it, any tips?
also for instructions that require terminal, I should ssh to the raspberry with creds root/libreelec?
thanks in advance
In order to avoid DNS Leaks you can manually configure the DNS servers to the ones used by NordVPN
NordVPN's DNS server addresses are 103.86.96.100 and 103.86.99.100
ok thanks, I will try it
Since today NordVPN stopped working, I reinstalled and correctly filled in my login, but its giving me an message saying it can't connect.
Logfile: https://paste.kodi.tv/uqopeqagad -
Banned add-ons are installed. No support to be provided.
Hi there,
since two days I get an authentitication error using NordVPN.
I would appreciate, if someone could take a look on the log file and hopefully can advise me what to do to fix it?
It worked now for months and suddenly it wasn't able to connect anymore.
I also changed the password several times (without any special characters).
Without any success.
Thanks in advance for your help.
Kind Regards
See for discussion and fix in progress: https://github.com/Zomboided/service.vpn.manager/issues/393
Hi,
I'm not at home at that time and would need to stop my VPN connection. However, VPN manager restarts it automatically. Is there a way to prevent it to restart the VPN connection without accessing the GUI? A SSH command line, for example?
Hi Zomboided,
I have installed 11.0.5 on a intel PC.
I installed zomboided tools and manager and using PIA vpn.Currently I'm suffering from very low speeds and was wondering:
* The vpn servers are updated automatically or must we manually update them?
* Will you use Wiregard protocol in the future?
I'll test later Libreelec on some other PC to check if it is only a local problem.
PIA vpn On linux and windows is updated and fast... no problems
THere won't be any more developments for this addon, I'm no longer using it and not really interested in maintaining.
You can use User Defined to import an ovpn to continue to use the latest configs
I use PIA outside of Kodi and I've noticed the latency has been horrendous lately.
Hi,
I have the Nordvpn installed, without the vpn I get speeds around 860Mbps , however best I can get with vpn, tried a few servers, is around 160Mbps , wasn't expecting that much of a drop in speed?
Complex cryptography requires compute effort. It's not for free.
Hello,
i have been installed on a Raspberry pi 5 with zomboid 1.3 Repo.
the vpn is marked as depricated
ovpn file
Display Moreclient remote 87-1-de.cg-dialup.net 443 dev tun proto udp auth-user-pass resolv-retry infinite redirect-gateway def1 persist-key persist-tun nobind cipher AES-256-CBC ncp-disable auth SHA256 ping 5 ping-exit 60 ping-timer-rem explicit-exit-notify 2 script-security 2 remote-cert-tls server route-delay 5 verb 4 ca ca.crt cert client.crt key client.key
kodi log
Display MoreZeile 321: 2024-02-23 13:56:10.391 T:939 info <general>: ZTools : (service.py) Starting Zomboided Tools service, version is 0.8.2 Zeile 322: 2024-02-23 13:56:10.391 T:939 info <general>: ZTools : (service.py) Kodi build is 20.3 (20.3.0) Git:20.3-Nexus Suche "VPN Mgr" (58 Treffer in 1 Dateien von 1 gesucht) neu 3 (58 Treffer) Zeile 327: 2024-02-23 13:56:11.090 T:938 info <general>: VPN Mgr : (service.py) Starting VPN monitor service, platform is 2, version is 7.0.3 Zeile 328: 2024-02-23 13:56:11.091 T:938 info <general>: VPN Mgr : (service.py) Kodi build is 20.3 (20.3.0) Git:20.3-Nexus Zeile 329: 2024-02-23 13:56:11.091 T:938 info <general>: VPN Mgr : (service.py) Addon path is /storage/.kodi/addons/service.vpn.manager/ Zeile 337: 2024-02-23 13:56:11.647 T:938 info <general>: VPN Mgr : (service.py) New install, but was using good VPN previously (CyberGhost, /storage/.kodi/addons/service.vpn.manager/CyberGhost/Germany (UDP).ovpn). Regenerate OVPNs Zeile 338: 2024-02-23 13:56:11.654 T:938 info <general>: VPN Mgr : (common.py) Creating VPN provider directory /storage/.kodi/addons/service.vpn.manager/CyberGhost Zeile 339: 2024-02-23 13:56:11.676 T:938 info <general>: VPN Mgr : (vpnproviders.py) Writing default up script Zeile 340: 2024-02-23 13:56:11.681 T:938 info <general>: VPN Mgr : (vpnproviders.py) Fixing default up.sh chmod +x /storage/.kodi/addons/service.vpn.manager/up.sh Zeile 341: 2024-02-23 13:56:11.686 T:938 info <general>: VPN Mgr : (vpnproviders.py) Generating OVPN files for CyberGhost using list Zeile 347: 2024-02-23 13:56:15.125 T:938 error <general>: VPN Mgr : (service.py) VPN monitor service detected VPN connection is not running when it should be Zeile 348: 2024-02-23 13:56:15.125 T:938 info <general>: VPN Mgr : (vpnplatform.py) No VPN configuration exists to write Zeile 349: 2024-02-23 13:56:15.129 T:938 info <general>: VPN Mgr : (vpnplatform.py) No VPN log file exists to write Zeile 369: 2024-02-23 13:56:24.578 T:938 info <general>: VPN Mgr : (service.py) VPN connected to Germany (UDP) Zeile 395: 2024-02-23 13:57:06.878 T:1075 info <general>: VPN Mgr : (common.py) Received connection info from ipinfo.io, IP 88.130.123.135 location North Rhine-Westphalia, DE, ISP AS8881 1&1 Versatel Deutschland GmbH Zeile 396: 2024-02-23 13:57:06.911 T:1075 info <general>: VPN Mgr : (common.py) Disconnected from the VPN Zeile 418: 2024-02-23 13:58:16.248 T:1147 info <general>: VPN Mgr : (common.py) Resetting all validated VPN settings and disconnected existing VPN connections Zeile 420: 2024-02-23 13:58:23.002 T:938 info <general>: VPN Mgr : (service.py) Updating systemd, connect before boot is false, location is Zeile 421: 2024-02-23 13:58:23.008 T:938 info <general>: VPN Mgr : (vpnplatform.py) Disabling systemd service with systemctl disable openvpn.service Zeile 443: 2024-02-23 13:59:58.209 T:938 info <general>: VPN Mgr : (service.py) Abort requested, shutting down service Zeile 446: 2024-02-23 13:59:59.784 T:1273 info <general>: VPN Mgr : (service.py) Starting VPN monitor service, platform is 2, version is 7.0.3 Zeile 447: 2024-02-23 13:59:59.784 T:1273 info <general>: VPN Mgr : (service.py) Kodi build is 20.3 (20.3.0) Git:20.3-Nexus Zeile 448: 2024-02-23 13:59:59.784 T:1273 info <general>: VPN Mgr : (service.py) Addon path is /storage/.kodi/addons/service.vpn.manager/ Zeile 476: 2024-02-23 14:02:05.253 T:1418 error <general>: VPN Mgr : (common.py) VPN provider deprecated, download latest .ovpn files from your provider to use with the User Defined wizard Zeile 486: 2024-02-23 14:02:45.551 T:1467 info <general>: VPN Mgr : (common.py) Resetting all validated VPN settings and disconnected existing VPN connections Zeile 487: 2024-02-23 14:02:46.751 T:1467 info <general>: VPN Mgr : (managefiles.py) Resetting the VPN provider Zeile 508: 2024-02-23 14:04:15.223 T:1492 info <general>: VPN Mgr : (userdefined.py) Creating /storage/.kodi/userdata/addon_data/service.vpn.manager/UserDefined/ Zeile 509: 2024-02-23 14:04:15.823 T:1492 info <general>: VPN Mgr : (userdefined.py) Copying /storage/ca.crt to /storage/.kodi/userdata/addon_data/service.vpn.manager/UserDefined/ca.crt Zeile 510: 2024-02-23 14:04:15.926 T:1492 info <general>: VPN Mgr : (userdefined.py) Copying /storage/client.crt to /storage/.kodi/userdata/addon_data/service.vpn.manager/UserDefined/client.crt Zeile 511: 2024-02-23 14:04:16.027 T:1492 info <general>: VPN Mgr : (userdefined.py) Copying /storage/client.key to /storage/.kodi/userdata/addon_data/service.vpn.manager/UserDefined/client.key Zeile 512: 2024-02-23 14:04:16.424 T:1492 info <general>: VPN Mgr : (userdefined.py) Copying /storage/openvpn.ovpn to /storage/.kodi/userdata/addon_data/service.vpn.manager/UserDefined/openvpn.ovpn Zeile 513: 2024-02-23 14:04:16.427 T:1492 info <general>: VPN Mgr : (userdefined.py) Updating /storage/.kodi/userdata/addon_data/service.vpn.manager/UserDefined/openvpn.ovpn Zeile 633: 2024-02-23 14:13:41.284 T:1602 error <general>: VPN Mgr : (common.py) VPN provider deprecated, download latest .ovpn files from your provider to use with the User Defined wizard Zeile 649: 2024-02-23 14:14:58.172 T:2035 info <general>: VPN Mgr : (common.py) Creating VPN provider directory /storage/.kodi/addons/service.vpn.manager/CyberGhost Zeile 650: 2024-02-23 14:14:58.213 T:2035 info <general>: VPN Mgr : (vpnproviders.py) Writing default up script Zeile 651: 2024-02-23 14:14:58.218 T:2035 info <general>: VPN Mgr : (vpnproviders.py) Fixing default up.sh chmod +x /storage/.kodi/addons/service.vpn.manager/up.sh Zeile 652: 2024-02-23 14:14:58.223 T:2035 info <general>: VPN Mgr : (vpnproviders.py) Generating OVPN files for CyberGhost using list Zeile 658: 2024-02-23 14:15:21.146 T:2035 info <general>: VPN Mgr : (common.py) Received connection info from ipinfo.io, IP 181.214.173.87 location Berlin, DE, ISP AS174 Cogent Communications Zeile 659: 2024-02-23 14:15:21.646 T:2035 info <general>: VPN Mgr : (common.py) [B]Connected to a deprecated VPN[/B] Zeile 664: 2024-02-23 14:15:27.100 T:1273 info <general>: VPN Mgr : (service.py) Updating systemd, connect before boot is false, location is /storage/.kodi/addons/service.vpn.manager/CyberGhost/Germany (UDP).ovpn Zeile 665: 2024-02-23 14:15:27.106 T:1273 info <general>: VPN Mgr : (vpnplatform.py) Disabling systemd service with systemctl disable openvpn.service Zeile 731: 2024-02-23 14:20:42.406 T:2409 info <general>: VPN Mgr : (common.py) Resetting all validated VPN settings and disconnected existing VPN connections Zeile 732: 2024-02-23 14:20:44.115 T:1273 error <general>: VPN Mgr : (service.py) VPN monitor service detected VPN connection is not running when it should be Zeile 733: 2024-02-23 14:20:44.115 T:1273 info <general>: VPN Mgr : (vpnplatform.py) No VPN configuration exists to write Zeile 734: 2024-02-23 14:20:44.126 T:1273 info <general>: VPN Mgr : (vpnplatform.py) VPN log file start >>> Zeile 760: 2024-02-23 14:20:44.126 T:1273 info <general>: VPN Mgr : (vpnplatform.py) <<< VPN log file end Zeile 761: 2024-02-23 14:20:44.126 T:1273 error <general>: VPN Mgr : (service.py) Something killed processes and windows, clearing data. Reconnecting to default profile. Zeile 762: 2024-02-23 14:20:44.148 T:2409 info <general>: VPN Mgr : (managefiles.py) Resetting the VPN provider Zeile 764: 2024-02-23 14:20:45.179 T:1273 error <general>: VPN Mgr : (service.py) Asking to connect to a VPN profile that doesn't exist Zeile 765: 2024-02-23 14:20:49.200 T:1273 info <general>: VPN Mgr : (service.py) Updating systemd, connect before boot is false, location is Zeile 766: 2024-02-23 14:20:49.207 T:1273 info <general>: VPN Mgr : (vpnplatform.py) Disabling systemd service with systemctl disable openvpn.service Zeile 782: 2024-02-23 14:21:58.786 T:2456 info <general>: VPN Mgr : (vpnproviders.py) Checking downloaded ovpn files for CyberGhost with GitHub files Zeile 787: 2024-02-23 14:22:18.116 T:2456 info <general>: VPN Mgr : (common.py) Creating VPN provider directory /storage/.kodi/addons/service.vpn.manager/CyberGhost Zeile 788: 2024-02-23 14:22:18.157 T:2456 info <general>: VPN Mgr : (vpnproviders.py) Writing default up script Zeile 789: 2024-02-23 14:22:18.162 T:2456 info <general>: VPN Mgr : (vpnproviders.py) Fixing default up.sh chmod +x /storage/.kodi/addons/service.vpn.manager/up.sh Zeile 790: 2024-02-23 14:22:18.167 T:2456 info <general>: VPN Mgr : (vpnproviders.py) Generating OVPN files for CyberGhost using list Zeile 801: 2024-02-23 14:22:42.029 T:2456 info <general>: VPN Mgr : (common.py) Received connection info from ipinfo.io, IP 181.214.173.87 location Berlin, DE, ISP AS174 Cogent Communications Zeile 802: 2024-02-23 14:22:42.530 T:2456 info <general>: VPN Mgr : (common.py) [B]Connected to a deprecated VPN[/B] Zeile 807: 2024-02-23 14:22:48.383 T:1273 info <general>: VPN Mgr : (service.py) Updating systemd, connect before boot is false, location is /storage/.kodi/addons/service.vpn.manager/CyberGhost/Germany (UDP).ovpn Zeile 808: 2024-02-23 14:22:48.389 T:1273 info <general>: VPN Mgr : (vpnplatform.py) Disabling systemd service with systemctl disable openvpn.service Suche "ZTool" (2 Treffer in 1 Dateien von 1 gesucht) neu 3 (2 Treffer) Zeile 321: 2024-02-23 13:56:10.391 T:939 info <general>: ZTools : (service.py) Starting Zomboided Tools service, version is 0.8.2 Zeile 322: 2024-02-23 13:56:10.391 T:939 info <general>: ZTools : (service.py) Kodi build is 20.3 (20.3.0) Git:20.3-Nexus
Any hints`?
Guess this is not active now, tried to install on kodi 20 LE 11.0.6 Rpi2. Is it possible to use proton free VPN?
