Sent me your bootable android image especially the boot.img
Sent from the Island of Venus
i install the m8s version to a matricom Q2 works great, the only issue i see is when i shutdown, my box reboot, any idea????'
Yes i will fix it soon
Good morning Demetris just to let you know i update to your latest release (15th) and i must say is working very well. Remote and WiFi work, my external Bluetooth works well, you have fixed the "failed to load kernal module" on boot error i kept seeing.
All in all job VERY well done my friend
Thank you for takimg the time to make these builds Demetris
Many thanks and all the best
Paul
Sent from my SM-G930F using Tapatalk
Demetris - Thank you for the amazing speed of your updates. Question, can you post a link to your github? Also, is it possible for end user to change the bluetooth driver something similar to how the remote.conf can be replaced?
If my way of understanding is correct, modules are done/taken care of before and during the compiling process and those files can't be edited by the end user.
I could be completely wrong but that's what i think lol
Paul
Hi guys, thanks for all your wonderful tips.
Have you guys lost the Libreelec under SYSTEM in the main page? I don't have that anymore; so how can I configure wifi and Bluetooth? I can't very anything and my remote doesn't work so I have to use a mouse.
very frustrating as I never had this issue with 7.0.2 everything worked
I'm using the file LibreELEC-S8X2.arm-8.0.1-S82.zip as I have an MXIII 2G/8G Amlogic box
Any help would be appreciated, thank you.
I have a MXIII 4k S802 2G/8G box with the [font]ap6234[/font] WiFi chipset my wifi is not working any idea if this is supported??
I've started from scratch and FINALLY!! lol
re-flashed Android stock Tronsmart image
used toothpick method to load Android bootloader, flashed LibreELEC-S802.S82.arm-8.0-devel-update.zip and updated to Kodi 17.0; everything works great even wifi and Bluetooth
copied LibreELEC-S8X2.arm-8.0.1-S82.tar file to /storage/.update using ssh
rebooted my box, it updated
remote didn't work but librelec was there and I can confirm wifi is working and bluetooth!
copied remote.conf file that I copied from /system/etc/ before flashing to libreelec to /storage/.config
EVERYTHING WORKS! my god thank you for all the damn posts on this forum and to the man Demetris!
Tronsmart MXIII Plus
LibreELEC-S8X2.arm-8.0.1-MXIII-PLUS.tar133MB Apr 11, 2017 | 09:23PM
LAN -   working
WiFi -  working
Bluetooth - working
Great builds thx
Hi there thanks for the work I tried all these builds on my box and non of them worked and the only updated firmware that I have found that works is this I dont no if there is anything in this that could help thanks again
 Display More
I’ve updated from ‘LibreELEC-S802.arm-8.0.1-MXIII-1G’ to you last version ‘LibreELEC-S8X2.arm-8.0.1-MXIII-1G’ today.The upgrade worked fine, to only thing I had to do was crating the ‘.nocompat’ file in update folder.
After the update the remote didn’t work. I did a find for a remote.conf and it was not there in the whole filesystem. I guess the file was deleted during the upgrade process. I copied a backup of remote.conf via Samba into the ‘Configfiles’ folder, rebooted the box and remote worked again.
- Now my MXIII-1G works stable
 - WIFI works
 - Bloetooth doesn’t work
Kodi screen shows ‘no Bluetooth-Adapter found’
dmesg | grep Bluetooth looks OK for me
[99.466830@1] Bluetooth: Core ver 2.16
[99.467231@1] Bluetooth: HCI device and connection manager initialized
[99.467247@1] Bluetooth: HCI socket layer initialized
[99.467253@1] Bluetooth: L2CAP socket layer initialized
[99.467267@1] Bluetooth: SCO socket layer initialized
[99.496916@2] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[99.496918@2] Bluetooth: BNEP filters: protocol multicast
[99.496944@2] Bluetooth: BNEP socket layer initialized- System status for RAM usage shows 112MB / 539MB (it was the same in the former version)
I do not understand why Libreelec sees only 539MB total Ram in a 1GB box. Is this normal or can it be a bug?
MX-III 1G Model never had bluetooth hardware in the box. Are you sure you had Bluetooth working when the box was running Android?
Hi Demetris,
kszaq has introduced significant audio improvements in his last verson (8.0.1f). Is it possible that you include this changes also in your builds?
Kind rerads,
ippon
To be honest, I'd never tested the box under Android. I bought the box used so I also don't have a specification from it.
I’ve seen Bluetooth never working in this box, neither under Openelec nor under Libreelec in any version. So yes, in fact, it makes absolutely sense that my box has no Bluetooth Hardware.
In this case, sorry for my stupid test/post regarding Bluetooth.
I've noticed that no matter what the box S802 or S812 and on every build I can get it to boot no problem off an SD card, but I can not get the firmware to update from (I forgot the developer who posted to amlinux.ru) 7.0.2 to the newest 8.0.1 Has anyone found a work around to Upgrade, opposed to wipe and clean install?
Have you tried placing demetris update .Tar in storage/.update with a .nocompap file?
Different kernels, I don't think the improvements apply to 3.10 kernel for S8X2.
Good morning you awesome people! I was wondering if there is someone here that has an environment setup where they can sign android apks and zip files? I've been reading what demetris has said about keeping the stock bootloader, unfortunately i have to flash in the following way
Flash android ROM
Flash openelec 6 by ipodtouchdude
Flash libreelec 7 devel
Update to demetris libreelec 8
Unfortunately openelec 6 contains a bootloader.img and so overwrites the android one. If i delete it from the zip it will fail to flash, I've tried deleting the included one and injecting the android one but that fails to flash.
I've tried signing it with
Apk zip signer 1.2
Various android apps that say they do it but none seem to work.
The only thing i can say is when i open ipodtouchdudes image or android ROM it says in the zip, signed by signapk, whenever i try it, it never says that.
I've extracted ipodtouchdudes changed to bootloader for the android one and zipped it again, is there anyone who could sign it for me so i can flash it, all i want to do is keep my stock bootloader lol how hard can it be hahahahaha
Paul
