Hmm, its an Eny M8 which I think is AP6330? Would it help if I pop open case and look?
![](https://forum.libreelec.tv/core/images/avatars/51/556-5134db117346aa261bd58c1b1c2fdde132c20922.webp)
Demetris -
December 7, 2016 at 10:38 PM -
Thread is Resolved
No I mean script to install to flash and erase android should work nowSent from the Island of Venus
Hey Demetris,
Thanks for the new LE version, but my IR remote still isn't working. I have a MX III 2G.
Hey Demetris,
I have MXIII 2G to....put it on confing folder..... remote.conf - Google Drive
So i happened to see drieschel work stalled,
So i decided to open a new one with my builds, i like to go stable so dont ask rolling builds
and i only have an S802 [Beelink S82, Orbsmart S82, Tronsmart S89(-H), MXIII(2G)]
So my builds for other boards are always been builded and released untested!
Download Links:
Krypton:8.xx
LE-8.0 + LE-8.0.1
Download Links:
downloads for Amlogic MXQ TV Box by Demetris. | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers- Kernel updated to latest 3.10.105 LTS
- LE upstream updates
- 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
- 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
- Support for 48000Hz vs 44100Hz rates as previously yay!!
I hope there's someone able to test it as i don't have any capable equipment around here
Enjoy!Jarvis:7.xx
login | AndroidFileHost.com | Download GApps, PA GApps, Roms, Kernels, Themes, Firmware and more. Free file hosting for all Android developers
Enjoy!
You can always find changelog in this link:
thread-2158.html
LE8-Source
LE7-SourceDemetris i don't know what code changes you made between RC 4 and final release but your Krypton RC 4 is working on my T8 AML V2 S802 now usb remote which is an S77 pro working playback fine no issues, just wondered was there a huge difference?
Thanks mate, i'll try that as soon as my box starts. I did the mistake of selecting boot from internal, and now when it starts, doesn't show anything on screen.
All appears to be working again here Demetris, thank you again
Sent from my SM-G930F using Tapatalk
Demetris I tried to upload picture images obviously unsuccessfully I'll try again.Sent from my SM-G900F using Tapatalk
Demetris picture file size too large i tried the top image and says along these lines i'm not new to kodi but i'm new to this so bare with meerror in prepare_sysroot: mount_common: Could not mount /dev/system ***
starting debugging shell... type exit to quit ###
can't access tty; job control turned offI too am getting this issue with the latest 8.0.1 image released on the 25th march. Had no issue with the 12th March version you released? Its as if something has changed bootloader wise between the 2 releases??? several folk seem to be getting this error.
Using the S82 image on a minix x8h
Any chance you can re upload the 12th march 8.0.1 release
same here tried to update today and im getting this error...
That's weird only thing changed was the remote config. Maybe images uploaded are corrupted. I will upload new ones tomorrow.
That worked, thanks! Now the stock remote works again. Only mce remote still isnt (ir receiver light is blinking)
That's weird only thing changed was the remote config. Maybe images uploaded are corrupted. I will upload new ones tomorrow.Sent from the Island of Venus
Hey Demetris,
I updated the LE from the 25th, but then i rebooted the box and now its bricked, it turns on and then does nothing. I get a black screen and no signal. My USB drive just flashes and does nothing.
New images are up, enjoy.
Just tried the latest update and the remote doesn't wor only the power button from the remote works lol I will downgrade until this is fixed my box is t8
flashed the latest firmware. stock remote is working , mce remote still isn't (worked before).
New images are up, enjoy.Can now confirm it is back to 8.0.1a behaviour on the MXIII 2GB.
i.e., Remote works fine after copying Beelink S82 remote.conf file. Bluetooth not working (same as 8.0.1a)The ageing MXIII 2GB is now useable with the Latest Kodi release, Thanks to you!
got a question?
I can run the s82 file from sd perfect on a minix neo x8-h.All functions seem to work fine but when I try to install to internal with putty I get an error permission denied.i tried reboot etc any idea what could be wrong -
I found the cause of Bluetooth issue and
Now all is needed is testing. Will release new images soonSent from the Island of Venus
got a question?
Are you using the latest image?Sent from the Island of Venus
Hi
Many thanks for latest build. I have an M8 box and updated from 8.0rc4 using the tar file but the remote no longer works, it worked ok on rc4. It is the small round cornered remote. Only other thing of note was the shutdown option in the power menu turned the box off fine but it then wouldn't allow you turn back on, only way was to turn the box off at wall / pull power lead. This was on rc4 not sure if it is the same on latest build with the remote not working
Any help much appreciated and many thanks again
