Would it be possible to get an RSS Feed plug-in added to the Transmission addon by default? I tried to add it after-the-fact, but I could not successfully implement the feature.
		Thoradia Add-ons
						thoradia
					November 28, 2016 at 11:56 PM
							Closed
 Would it be possible to get an RSS Feed plug-in added to the Transmission addon by default? I tried to add it after-the-fact, but I could not successfully implement the feature.Where are RSS Feed plug-ins for Transmission documented?
 Where are RSS Feed plug-ins for Transmission documented?My bad. I was thinking of the YaRSS plugin for Deluge.
			thoradia, could you please update deluge with this fix: Changeset cc69c9 – Deluge P.S. I've found optimized python file ([...]/deluge/core/torrent.pyo) and can't edit it directly.
 Is there way to apply this fix on local system? Can I replace .pyo file with .py (performance is no matter for now)?
			My bad. I was thinking of the YaRSS plugin for Deluge. Indeed, YaRSS2 does not enable. I'll see what I can do about it. Any help is appreciated
 thoradia, could you please update deluge with this fix: Changeset cc69c9 – DelugeP.S. I've found optimized python file ([...]/deluge/core/torrent.pyo) and can't edit it directly.
 Is there way to apply this fix on local system? Can I replace .pyo file with .py (performance is no matter for now)?I'll add that patch in the next iteration.
 In the meantime, you can indeed try to replace the .pyo wirh the .py and then restart deluge. Let us know if it fixes. If it does not, simply reinstall Deluge.
 For information, the code is here.
 In the meantime, you can indeed try to replace the .pyo wirh the .py and then restart deluge. Let us know if it fixes. If it does not, simply reinstall Deluge.I've renamed torrent.pyo to torrent.pyo.old and copy patched torrent.py. Seems to be worked as expected. Thanks!
			My bad. I was thinking of the YaRSS plugin for Deluge. I started deluge with -L info: the log looks good (see below) but the YaRSS2 plugin does not show up in the WebUI.
 Please report the issue to the YaRSS2 devs.
 Please report the issue to the YaRSS2 devs.Excellent. Thanks for checking.
			Hi, Excellent add-ons! Just seems that Sabnsbd is somehow showing wrong version. For exaample dognzb site does not allow to push send and showing error "... 0.3 version or better required". Also sonarr had a warning that every functionality might not work although it have been working so far. Dognzb push issue is however something I would like to use. Thank you in advance!
			Hi all,
 my friend have this stuff. LibreElec on RPi3, Zyxel NAS326 with activated SAMBA. He need make work CouchPotato, SickRage and Transmission addons with storage all stuff on NAS. Is it possible? Only Transmission has settings interface. CP neither SR has. Second, little off topic, is it possible setting SAMBA to view stuff on nas from CP and SR?Thanks. EDIT: I found working solution, so, my apologize
 Just seems that Sabnsbd is somehow showing wrong version. For exaample dognzb site does not allow to push send and showing error "... 0.3 version or better required". Also sonarr had a warning that every functionality might not work although it have been working so far.Thank you for the feedback, I will fix this in the next iteration.
 In the meantime, you can correct this issue yourself with the following commands:Coderm /storage/.kodi/addons/service.sabnzbd/SABnzbd/sabnzbd/version.pyo nano /storage/.kodi/addons/service.sabnzbd/SABnzbd/sabnzbd/version.py systemctl restart service.sabnzbd
 In nano set __version__ to 1.2.3 instead of develop
 In nano set __version__ to 1.2.3 instead of developHi, thank you for quick reply. I did those three steps, but now sabnzbd service won't start. Changed back to "develop", but same situation. Seems that i didn't like deleting version.pyo and havent build it again. Codeservice.sabnzbd.service - SABnzbd Loaded: loaded (/storage/.kodi/addons/service.sabnzbd/system.d/service.sabnzbd.service; enabled; vendor preset: disabled) Active: failed (Result: exit-code) since Thu 2017-03-30 08:31:37 EEST; 1min 53s ago Docs: https://sabnzbd.org/ Process: 1131 ExecStart=/bin/sh /storage/.kodi/addons/service.sabnzbd/bin/sabnzbd.start (code=exited, status=1/FAILURE) Main PID: 1131 (code=exited, status=1/FAILURE) Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Unit entered failed state.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Failed with result 'exit-code'.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Service hold-off time over, scheduling restart.Mar 30 08:31:37 LibreELEC systemd[1]: Stopped SABnzbd.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Start request repeated too quickly.Mar 30 08:31:37 LibreELEC systemd[1]: Failed to start SABnzbd.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Unit entered failed state.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Failed with result 'exit-code'.
			Hi, thank you for quick reply. I did those three steps, but now sabnzbd service won't start. Changed back to "develop", but same situation. Seems that i didn't like deleting version.pyo and havent build it again. Codeservice.sabnzbd.service - SABnzbd Loaded: loaded (/storage/.kodi/addons/service.sabnzbd/system.d/service.sabnzbd.service; enabled; vendor preset: disabled) Active: failed (Result: exit-code) since Thu 2017-03-30 08:31:37 EEST; 1min 53s ago Docs: https://sabnzbd.org/ Process: 1131 ExecStart=/bin/sh /storage/.kodi/addons/service.sabnzbd/bin/sabnzbd.start (code=exited, status=1/FAILURE) Main PID: 1131 (code=exited, status=1/FAILURE) Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Unit entered failed state.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Failed with result 'exit-code'.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Service hold-off time over, scheduling restart.Mar 30 08:31:37 LibreELEC systemd[1]: Stopped SABnzbd.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Start request repeated too quickly.Mar 30 08:31:37 LibreELEC systemd[1]: Failed to start SABnzbd.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Unit entered failed state.Mar 30 08:31:37 LibreELEC systemd[1]: service.sabnzbd.service: Failed with result 'exit-code'.Weird, it works here. To fix, simply reinstall the add-on.
 Have you tried DOGnzb with nzbget?
 Have you tried DOGnzb with nzbget?Hi, reinstall helped to get Sab up and running. Tried nzbget and everything worked. Im'm used to sab, but lets give nzbget a try.
 Hi,Excellent add-ons! Just seems that Sabnsbd is somehow showing wrong version. For exaample dognzb site does not allow to push send and showing error "... 0.3 version or better required". Also sonarr had a warning that every functionality might not work although it have been working so far. Dognzb push issue is however something I would like to use. Thank you in advance! This issue is fixed by revision 11 of the SABnzbd add-on
 [hr] thoradia, could you please update deluge with this fix: Changeset cc69c9 – Deluge thoradia, could you please update deluge with this fix: Changeset cc69c9 – DelugeP.S. I've found optimized python file ([...]/deluge/core/torrent.pyo) and can't edit it directly.
 Is there way to apply this fix on local system? Can I replace .pyo file with .py (performance is no matter for now)?This issue is fixed by revision 10 of the Deluge add-on
 Hi Thorada. First of all great work!I was very happy to get couchpotato running on a 905 (runs great) but now it seems that couchpotato itself is becoming almost impossible to be used for torrents. An alternative was recently started based on Sonarr: GitHub - Radarr/Radarr: A fork of Sonarr to work with movies à la Couchpotato. wich seems to work quite well already. Do you have any plans in including this? (I haven't really studied the sources yet, but as it is based on Sonarr, it should be possible I think) CouchPotato has been updated.
 Revision 11 of the CouchPotato add-on has been updated accordingly.
			Odd, now my transmission has gotten into a state where it segfaults upon loading a torrent again: hNgX It was working fine for a while, not sure what's going on here. Removing the torrent from resume/torrents data directory makes it start up fine again but adding a torrent results in the same.
 Odd, now my transmission has gotten into a state where it segfaults upon loading a torrent again: hNgXIt was working fine for a while, not sure what's going on here. Removing the torrent from resume/torrents data directory makes it start up fine again but adding a torrent results in the same. Thank you for the feedback.
 Transmission was last built against LibreELEC 7.95.1.
 I have started rebuilding it against LibreELEC 8.0.1.
 I will post the new build here, so you can test if it fixes.Edit: the build is now available from the repository.
			I recently upgraded to Libreelec 8.0.1 from 7.0.3. I can see that the system is very sluggish when running Sonarr, Transmission & CP on 8.0.1. This was never an issue on 7.0.3. Anybody else having similar issue. Edit: Which one is better? Using this (Sonarr, Transmission, CP) directly or by Docker?
