Thoradia Add-ons
  • Hello,
    Thank you for your work :) .
    I am constantly getting the following error in Lidarr:
    Quote
    fpcalc could not be found. Audio fingerprinting disabled.
    I already downloaded a fpcalc binary compiled for armh and put it on my LibreElec path, but it still doesn't find it. I ask here instead of creating an issue, because I don't know if this would belong to Lidarr, or to Thoradia...
    Thanks!
  • fpcalc is part of the libchromaprint-tools package, which is not included in libreelec.
    So audio recognition will not work until the executable is included in lidarr with a location fix.
    A workaround is to mount / as writable and create a link in /bin to where you placed the fpcalc executable.
    I am most surprised though that a Mono application is written to rely on a OS-specific package. How does Lidarr work in Windows then?
    I would just leave it off. It's pretty resource intensive and practically useless, except for audio verification (and you can probably verify if a song is the wrong one, anyway)
  • Thanks for your answer!
    Yeah, I don't need it, I just wanted the notifications (which I have connected for "healt_h issues" through Telegram) to stop.
    Regarding your Windows comment, according to the wiki:
    Quote
    Lidarr can use chromaprint audio fingerprinting to identify tracks. This depends on an external binary, which is distributed with Lidarr for Windows and macOS but must be provided independently on Linux.
    Alright, so... I actually made it work this way:
    In /storage/.kodi/addons/service.lidarr/bin/lidarr.ctl,
    add this line after the export that's aldready in there:
    export PATH="${ADDON_DIR}/bin:$PATH"
    I am not sure if this runs on every boot / service startup.
    But you can also add this to /storage/config/autostart.sh so that it executes on boot:
    export PATH="/storage/.kodi/addons/service.lidarr/bin:$PATH"
    so it should become like this:
    #!/bin/sh
    (sleep 3;
    # whatever other commands you might have in there
    Copy fpcalc (I got it for x86_64 from the Chromaprint package) to /storage/.kodi/addons/service.lidarr/bin and give it executable permissions.
    Start Lidarr.
    This works well for me.
    An alternative is to mount / as writable, copy fpcalc to /bin and that will work right away. BUT that may (will probably) be overwritten on system update.
    I have LibreElec 9.2.6 on RPi 4 (with 4GB RAM).
    I Installed all the addons (mono + tools).
    Radarr works perfectly but sonnerr is not.
    On RPi Boot I get a quick message:
    [FAILED] Failed to start sonarr
    See 'systemctl status service.sonarr.service' for details
    When I ran this commend in terminal i get empty response.
    Can you please help?
