Thoradia Add-ons
thoradia -
November 28, 2016 at 11:56 PM -
Closed -
I tested Transmision clean installation on every millhouse version and still only works on # 301
On clean 9.1 I can not even install the repository from the THORADIA file
GENERIC version -
GENERIC versionPlease be more descriptive
Why can you not even install the repository?
Could you provide me with a log, eg in a private conversation?
Transmission tested and working. However i have to install from the zip. Force the update not work for me.
Thanks for the work Thoradia.
Glad it works
I do not understand why Kodi does not pick up the updates
I will however not bump revision numbers for an unreleased system
I have updated Deluge to version 2.0.3
I have no hardware to test CoreELEC
Please provide the output of journalctl -u service.deluged, so that I can try to fix
To revert to Deluge version 1.3.15, manually install the add-on from here
Make sure to disable auto-updating the add-on to avoid installing Deluge version 2.0.3
Sorry for late reply, I've been away without Internet. Below is the output I get from executing the command.
Display More-- Logs begin at Fri 2018-06-22 13:11:49 CEST, end at Sun 2019-06-23 12:52:20 CEST. -- Jun 23 11:17:41 CoreELEC systemd[1]: Started Deluge daemon. Jun 23 12:51:26 CoreELEC systemd[1]: Stopping Deluge daemon... Jun 23 12:51:26 CoreELEC sh[3216]: Unhandled Error Jun 23 12:51:26 CoreELEC sh[3216]: Traceback (most recent call last): Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/deluge-2.0.3-py2.7.egg/deluge/core/daemon_entry.py", Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/deluge-2.0.3-py2.7.egg/deluge/core/daemon.py", line 1 Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: --- <exception caught here> --- Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: twisted.internet.error.ReactorNotRunning: Can't stop reactor that isn't running. Jun 23 12:51:26 CoreELEC sh[3216]: 12:51:26 [CRITICAL][twisted :154 ] Unhandled Error Jun 23 12:51:26 CoreELEC sh[3216]: Traceback (most recent call last): Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/deluge-2.0.3-py2.7.egg/deluge/core/daemon_entry.py", Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/deluge-2.0.3-py2.7.egg/deluge/core/daemon.py", line 1 Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: --- <exception caught here> --- Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: File "/home/thoradia/Projects/thoradia/coreelec-9.0/build.CoreELEC-Amlogic.arm-9.0-devel/deluge-2.0.3/.install_pkg/usr/lib/python2.7/site-packages/Twisted-19.2.1-py2.7-linux-x86_64.egg/twisted/interne Jun 23 12:51:26 CoreELEC sh[3216]: Jun 23 12:51:26 CoreELEC sh[3216]: twisted.internet.error.ReactorNotRunning: Can't stop reactor that isn't running. Jun 23 12:51:26 CoreELEC systemd[1]: Stopped Deluge daemon. Jun 23 12:51:28 CoreELEC systemd[1]: Started Deluge daemon.
Is the 2.0.3 Daemon compatible with the 1.3.15 client? I'm using Windows so I can't update to 2.0.3 for the client as far as I can tell.
Edit: Reverting back to the version you linked has fixed the issue for me. Thank you. -
Thoradia add-ons are available for LibreELEC 9.2 alpha 1 for Generic and RPi2
Add-ons for other systems (RPi, Rockchip and WeTek_Play) are building
- Official Post
No need to build WeTek stuff for LE 9.2 as it doesn't exist. LE 9.0 is the last release with Amlogic_Legacy support. We might go back and push LE 9.0.3 so that people have K18.3 .. not decided yet (and no time to think about it right now).
Thoradia add-ons are available for LibreELEC 9.2 alpha 1 for Generic, Rockchip, RPi, RPi2 and RPi4
Configure it with a OpenVPN configuration file, userid and password
This will create the the thoradia-vpn interface
You can check it is up with ifconfig or ip addr
To get the default public IP: curl -s https://ipinfo.io/ip
To get the public IP of thoradia-vpn: curl -s https://ipinfo.io/ip --interface thoradia-vpn
They should be different
To configure qBittorrent to use thoradia-vpn add Connection\Interface=thoradia-vpn in /storage.kodi/userdata/addon_data/service.qbittorrent/.config/qBittorrent/qBittorrent.conf
qBittorernt will work only if thoradia-vpn is up.
Is there a way to get the bind of IP addresses to persist after restart when using transmission?
I've modified the settings.json in .kodi/userdata/addon_data/service.transmission but after a restart the file seems to be reverted. -
I've modified the settings.json in .kodi/userdata/addon_data/service.transmission but after a restart the file seems to be reverted.This is a question for transmission support
It could be that transmission resets bind-address-ipv4 if the one specified does not exist
If this is the case, transmission should be started after transmission-vpn
Let me know
Let me know
Hey, thanks for your reply.
I found the issue but it led to another issue.
The INET address keeps changing after restart for the thoradia-vpn interface. it started as 100.63.0.1, then .2 then .3 so each restart causes transmission to try and bind with the incorrect IP.Any ideas how to keep the INET the same?
If you can, use qBittorrent, which supports an interface name and stops if the interface fails
Otherwise create an init.sh script to get the address of thoradia-vpn and set bind-address-ipv4 accordingly in settings.json
For a head start, google 'transmission bind-address-ipv4 vpn'
If you get something working, I will add it to the transmission add-on
thoradia
Can you add plex media server (native) to the repository? with others repositories does not work on my Raspberry Pi 4
Thanks for everything , you do a great job -
thoradia
Thanks for everything , you do a great jobThank you for thinking about me, but no, it is too much work for me
Ask for help at the PMS thread or at Plex
have a minor issue with the new deluge version, larg files are not been completed.
they come up to 100%, then i have to run a manual check before they are marked as compled.
minor files around 1-3gb are no problems.
wanted to check the version of libtorrent and other supporting files.
What is the version of the Deluge add-on?
On what system?
