Display MoreHiassofT thanks for an idea. The result = the same issue as LE10.0.1, no CLI after edit.
Steps to replicate:
- fresh 2021-05-07-raspios-buster-armhf-lite.zip installation
- CLI with login reached
- sudo update
- sudo full-upgrade
- sudo rpi-update
- reboot
- CLI and login reached
- card removed and config.txt modified from dtoverlay=vc4-fkms-v3d to dtoverlay=vc4-kms-v3d
- card inserted back, booting with 4 raspberries appeared, then it goes to black screen
- on TV selected HDMI1 and then HDMI3 back -> CLI and login reached
See the outputs in the attachment
EDIT: attachment fixed
Display MoreHiassofT:
It seems I have found the working way for my case
Hardware:
- old LG 42LK450-ZB (2012) - edid
- RPi 4B - original HDMI cable plugged to HDMI0 near to power supply
Software:
- fresh installed LibreELEC-RPi4.arm-10.0.1.img
Steps to replicate:
- after the first boot the blank screen only
- to reach the GUI select other HDMI source on TV via contoller and return back
- proceed the first LibreELEC setup and enable SSH
- connect to the RPi via SSH
- mount -o remount,rw /flash
- nano /flash/distroconfig.txt and just add (see PHASE 1 below):
- hdmi_group=1
- hdmi_mode=20
- nano /flash/cmdline.txt and just add video=HDMI-A-1:[email protected](see PHASE 2 below):
- reboot
PHASE 1: Rainbow cube and boot process:- The hdmi_group= and hdmi_mode= still affects the resolution and text size, which is hidden/not visible (black screen) in LibreELEC. The commands help to switch to PHASE 2 -> LibreELEC logo
The effect can be seen in RaspiOS (2021-10-30-raspios-bullseye-armhf-lite.zip), when e.g. hdmi_mode=1 is set.
Crossing from PHASE 1 to PHASE 2: black screen for 1s
PHASE 2: LibreELEC logo:
- The command video=HDMI-A-1:[email protected] or EDID (see the comment from Cris_) only affects the resolution for the screen resolution of the screen with LibreELEC logo and GUI.
Also in RaspiOS the PHASE 2 when it continues to CLI the text size is affected after PHASE 1
Please note that this is only an user description of the problem and temporary solution.
EDIT: fix typo
Thanks for this. I had issues on my v9 of LibreELEC and had similar issues on 10.0.0.2 when connecting to my TV and the device restarting or not showing a picture. I went through these steps and my Phase 2 screen wasnt showing the correct resolution after changing it here. It was still stuck on that screen and only worked when I changed my TV to a different HDMI port and then went back to it after it started.
To make this work for me I did everything you did but changed the following from 1 to 0 in "/flash/distroconfig.txt". This also fixed my sound issue where the flipping HDMI to get it to load up still didnt allow sound to come through.
And I used the following:
