  • PVR IPTV simple client does not recognize the group of channels in the playlist, i have only ALL CHANNELS :/
    Edit: Settings PVR & Live TV, enable synchronise channel groups with backend
    Edited once, last by Exp245 ().
  • Help needed.
    I have: ODroid-C2 + August DVB-T210 DVB-T2 stick (seems to be Geniatec 230?).
    I need: A working built with support for that hardware. Perferrable not an alpha built, but if it's necessary...
    As mentioned, 7.0.2 is enough for me.
  • I have: ODroid-C2 + August DVB-T210 DVB-T2 stick (seems to be Geniatec 230?).
    Why do you post in this thread? The Odroid C2 has no S805, it has a S905 SOC and is official supported.
    Gerald
  • It is possible to use one of the build on Minix NEO X6? As I see it's working on Amlogic S805 with 1 GB RAM.
    Thanks for your answers.
    Edited once, last by erbeka ().
  • erbeka Load it on SD card and try. Running from SD card is 100% safe as it doesn't modify firmware that is already installed.
  • OP updated with a new build that includes a major set of patches that improve playback considerably. All thanks to @Peak3d who developed the patches. The build has also all updates from LE master branch.
  • Thanks successfully updated MXQ box and manually copied over remote.conf afterwards
    Context menu button isn't working; there is a line in remote.conf 0x49 46 ;MENU
    I'm thinking this needs changing, any ideas?
    Cheers
  • People with remote control issues:
    • reboot your box
    • press the buttons that do not work (and note the order of pressing)
    • post result of the following: dmesg | paste and cat /tmp/remote.conf | paste
    I have checked my boxes and all factory remotes work fine, I really need the logs to debug this.
  • ok so the home key doesn't work aswell:
    [ [email protected]] remote_send_key
    [ [email protected]] press ircode = 0x53, scancode = 0x00ac, maptable = 0
    [ [email protected]] remote_send_key sleep:0
    [ [email protected]] repeat ircode = 0x53, scancode = 0x00ac, maptable = 0
    [ [email protected]] release ircode = 0x53, scancode = 0x00ac, maptable = 0
    The menu key is this:
    [ [email protected]] press ircode = 0x49, scancode = 0x002e, maptable = 0
    [ [email protected]] repeat ircode = 0x49, scancode = 0x002e, maptable = 0
    [ [email protected]] release ircode = 0x49, scancode = 0x002e, maptable = 0
    [ 326.24131[email protected]] remote_send_key sleep:0
    and the /tmp/remote.conf
    # Visson S82 / Beelink S82 remote
    factory_code = 0x7f800001
    work_mode = 0
    repeat_enable = 1
    release_delay = 121
    debug_enable = 1
    reg_control = 0xfbe40
    key_begin
    0x51 116 ;POWER
    0x4d 66 ;MUTE
    0x09 61 ;MEDIA
    0x11 60 ;MUSIC
    0x56 74 ;VOL-
    0xbd 51 ;MEDIA_PREVIOUS
    0xbb 52 ;MEDIA_NEXT
    0x4e 78 ;VOL+
    0x53 172 ;HOME
    0x1b 14 ;EXIT
    0x25 105 ;LEFT
    0x26 103 ;UP
    0x27 106 ;RIGHT
    0x28 108 ;DOWN
    0x0d 28 ;OK
    0x49 46 ;MENU
    0x31 2 ;NUM1
    0x32 3 ;NUM2
    0x33 4 ;NUM3
    0x34 5 ;NUM4
    0x35 6 ;NUM5
    0x36 7 ;NUM6
    0x37 8 ;NUM7
    0x38 9 ;NUM8
    0x39 10 ;NUM9
    0x30 11 ;NUM0
    0x44 111 ;DEL
    key_end
    Edited once, last by punter ().
  • I've installed 7.90 beta1 as an update to 7.0.3.1 (MXQ version) running from SD card. 7.0.3.1 also runs from NAND.
    The NAND version offers reboot and reboot from NAND when I select the power icon on the kodi main screen. The SD version only offers reboot.
    Is this what should happen? I'm sure that I remember both versions offering reboot from NAND when I've used dual boot before.
  • Did some testing of Beta1 on my wetek hub yesterday. I was surprised how well this version coped with my file collection and tv setup.
    • no problematic files found (hevc main and main10, h264 both 8 an 10 bit, mpeg4 in mkv and mp4 containers), chapter and manual skipping worked fine. Will continue testing with some of the older files (divx5, ogm and avi containers)
    • MPEG-Dash with the latest inputstream for raspberry pi2 from kodinerds.de works fine with the youtube plugin (1080p youtube, yay!)
    • twitch.tv plugin works fine, but I had one hiccup: when I selected a live stream that I played before, it offered to "continue at X:XX" (the duration of the last time I viewed it) and when I selected it, the box froze completely. Never saw this on Jarvis, but suspect the plugin as source of the problem. Sadly, it is not easily reproduced
    • PVR with the tvheadend plugin works flawlessly, tested SD mpeg2 (576i), HD (h264 720p and 1080i) and 4k DVB-S2 transmissions). Channel switching times are slightly more than the latest Jarvis version
    • all remote buttons worked
    Did not test audio passthrough yet.
    Sorry, wrong thread...
    Edited once, last by mmpp ().
