kszaq, maybe your building server is on now ? would be very nice to test your latest build with all changes/updates and included dvb tuner for play 2 .
Best regards
![](https://forum.libreelec.tv/core/images/avatars/ed/1274-edfc0e7cffead5eb4f1b961c6bc4768eefc6e22d.png)
kszaq -
October 28, 2016 at 10:45 PM -
Closed -
Any chance for adding mce remote in 17 ? Works in kodi 16.1
afl using your build on 1GB/8GB Mini MX I'm getting no sound and the output device is Bluetooth audio (PULSEAUDIO)?
Nevermind I just read its not compatible with the dtb.
Try to use dtb from 008. It works for me. -
afl1 pvr iptv simple doesn't work ?
thx -
Try to use dtb from 008. It works for me.Can confirm this as well. Audio works with .008 gxl_p212_2g.dtb on Mini M8S II 2GB/16GB.
OP updated with new build. A few improvements, including fixed PVR addons and smoother GUI.
WP2 build is available in subfolder - it's experimental because I don't have that box.
Thanks for the new build.
Are there any known changes to lirc? I'm using an external mce receiver which worked flawlessly with the 2016-11-09 build, getting correct output with irw. But since the 2016-12-01 build I have no irw output. In Kodi there are double and triple key presses and the OK button is broken.
All are clean installs with my lircd.conf at /storage/.config. When booting the 2016-11-09 build all is fine, booting 2016-12-01 or 2016-12-04 lirc is acting weird.
OP updated with new build. A few improvements, including fixed PVR addons and smoother GUI.kszaq Official ANT 1 Addon (Lambda) from Kodi REPO choosing Live from the menu is giving me some strange behaviour in that it opens the stream 1 out of 8 attempts. When it doesn't open there seems to be an issue that the stream has opened but the screen stays on the menu. There are no GUI sounds when using remote until i stop the stream.
I turned OFF accelerate H264 (never) and the streams open normally.
See screenshot of settings which work. It is the same with other addons in Lambdas greek addons for live.
I thought this may help identify what is going on using this addon.Test box MiniMX 1gb/8gb S905.
Sharp Aquos Quatron 70 inch tv
Box to HDMI simple set up. -
@kszaq it possible to disable x264 hw acceleration only in iptv ?
kszaq, thx for wp2 build. I will test it later
Regards -
I have not found the latest PVR DVBViewer client.
Can you help me?
Thanks in advance.
Sincerelly...
I have not found the latest PVR DVBViewer client.Can you help me?
Thanks in advance.
Sincerelly...
If it's not in the repo (libreelec repo) it's in the list kszaq posted a page or so back.
Thanks, I found it.
But HDMI-Cec does not work.
Sincerelly...
kszaq Can you please add Spotify addon from Spotify for Kodi to Index of /addons/8.1/S905/arm/ ?
Current repository from marcelveldt won't work on s905 -
kszaq i tried your first 32bit userspace build.
Great improvement on memory management.
Definately the right track as far as i am concerned!What i do notice regarding live-tv is, that Kodi will occasionally freeze/crash after switching channels.
This is with hardware acc. disabled as hw acceleration for mpeg-2 with the new videoplayer is a WIP too, i guessThanks for the 7.9 releases, they are getting better and better!
kszaq, I installed now your latest build for Play2 and there is no TV adapters in tvheadend configuration
