  • Will the H6 get RGB LCD support ?
    While in theory should be easy to add, there is no plan to do that. Mostly because no LE developer has such HW. Doing any kind of development without HW is hard and wastes a lot of time.
  • jernej !
    I have a problem with my Orange pi 3 and Pine H64. All my 1080P contents (movies and episodes) are jerky (not smooth). The only workaround I found is to put devices to 2160p and whitelist only 2160p resolution. That way all my contents play well.
    Do you have this problem on your side ? This problem doesn't exist on my raspberry pi 4, orange pi PC and Orange pi PC2.
    Libreelec : Raspberry 4, Orange pi lite2, Orange pi PC(and +), Pine H64, Rock64, RockPro64, soon Orange Pi 3 and PC2
    Divers : NVidia Shield Pro, NVidia Shield Tube, N2 and C4
    Edited once, last by mike2002 ().
  • Hi everyone!I have tanix tx6 4/32 dual wifi,i install official 9.95.2,but i don't see any wifi connection,on android all works.Can somebody help me?
    p.s. sorry for my bad English
  • Hi jernej !
    I played with my Orange pc2 and I can confirm that my PC2 work as well as my Orange pi PC.
    I found a way to help my Orange pi PC2 and my Orange pi PC to stop freezing because of low memory, I enable the swap file, I set the swap file to 512MB and that help. No more freeze at all, some slowing down when the device access the swap file but overall that help a lot.
    It's sad that we can't enable Zswap, it's a lot better dans the swapfile. I use Zswap that on other devices at home and that work really great. For device with 1 GB memory Zswap can do a huge difference.
    Zswap is a battle that I can't win, other people tried before witout success. Anyway, in my case I play with these devices only for fun of testing.
  • jernej !
    Yup, playing content at native 24/25/30 Hz is still broken on Kodi+H6, very jerky.
    I even bothered to compile and test in mpv, using same drmprime path on H6, play silky smooth there.
    Playback is also OK on H3 board, using both Kodi and mpv.
    Its somehow related to the combination of Kodi stopping rendering GUI/OSD during playback and panfrost on H6.
    Workaround is to force Kodi to render GUI even when hidden, set algorithmdirtyregions to 0 in advancedsettings.xml. Of course power consumption/temperature rises a bit.
  • Can you test if using performance governor helps? That's only conceivable difference between H3 and H6 that could make a difference.
    No, wifi is not supported. See first post for reason.
  • offbeat , thank you for the trick "set algorithmdirtyregions to 0" it works well.
  • mike2002 please test performance governor, that's something I would accept as a workaround (by popular vote), but not "set algorithmdirtyregions to 0"
  • jernej can you remind me the "echo" command to set to performance ?
    I try this :
    echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    But it doesn't work
    -sh: can't create /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor: nonexistent directory
    Actually performance governor instead of schedutil makes it even more visible and easy to repeat, at least for 30FPS content on 30Hz.
    I've made a short clip of how it looks on display, will send PM.
  • Hi guys!
    I cant open menu Libreelec Configuration.
    LOG:
    locale output:
    How to fix it ?
    Board: Orange PI 3 H6 Quad-core 64-bit 1.8GHZ ARM Cortex-A53
    TV: TELEFUNKEN TF-LED65S75T2SU
  • Dear friends, as I tried the nightly omage for my Pi Plus 2E Chinese board, it gives this via debug TTL line:
    And it stucks after that, i.e. hangs. What am I doing wrong?
  • offbeat your samples plays fine with my two monitors, one full hd and another 4k. It stalls only once at the beginning but after that it plays normally. Tested on PineH64 model B.
    Hmm, did you have "Adjust display refresh rate = on" set?
    Playing everything at default 60 FPS most displays have in EDID is fine, jerkyness only appers when Kodi switches output HZ to match content FPS.
  • Auto refresh rate switching is one of the major selling points of LibreElec, could even be enabled by default IMHO.
    Many of Android TV boxes can't do that, since there was no such API until recently.
    It gives user ability to play 24/25/30Hz content on TV without forced convertion to 60Hz. As well as ability to use TV provided motion interpolation, some hate it, some love it, but its a big deal anyway.
