Hi bables150, MXIII Plus on 4-14 having trouble pairing with Bluetooth remote. I don't recall this being an issue with 3-22 build however it looks like you deleted that build folder?
Any chance you still have that build saved so I can confirm? Thank you
balbes150 -
September 6, 2016 at 8:21 AM -
I have a MXIII 4k S802 2G/8G box with the ap6234 WiFi chipset my wifi is not working any idea if this is supported
- Official Post
Version 20170418. Changes in the structure of the dtb data in the images MXIII_Plus , LAN1000 , M8S
I test the test image on my m8s, but it not work also with the dtb file.
Can someone help me?I have a ott m8s
Describe in detail what steps You did and what the result of these steps.
Display More
Dear balbes150!
I have MXIII-G (2/8G) first version and I used the installation LibreELEC-S812.LAN1000.arm-8.0.2.img.gz and LibreELEC-S812.MXIII_Plus.arm-8.0.2.img, both firmware work fine all peripherals (Lan, WIFI), the only problem at the start, I see attach. photo and not logo libreelec, then appears Kodi.
It's alright?
I have tried boot loader for Android 4.4 KK and 5.1LP the same result
Thanks for the info, I apologize for my English
Huge thanks for the effort, balbes150!If You mean that the screen with the strata run-line with the text of the boot - that's normal.
Try the latest versions of the images (LAN1000 MXIII_Plus M8S). I have limited space, so I don't keep backups.
I have a MXIII 4k S802 2G/8G box with the ap6234 WiFi chipset my wifi is not working any idea if this is supportedSorry, but I have no such equipment, so I won't be able to help You.
Try the latest versions of the images (LAN1000 MXIII_Plus M8S). I have limited space, so I don't keep backups.Sorry, but I have no such equipment, so I won't be able to help You.
The steps are: download de test img en put it on a sd card with imges progam, and put the dtb file on the card (dtb.img)With dtb file i get black screen em without also. No working i guss:)
Verstuurd vanaf mijn SM-G925F met Tapatalk
Hi bables150, Thanks for the answer, my TV was not able to switch to the native resolution probably . I see listing text unreadable static logo or picture would look better. Nothing it is just detail
For information
I installed on my box MXIII-G 2/8 update 20170418 completely disappeared Wifi drivers on both versions (LAN1000,MXIII_Plus) -
Hi bables150 - I loaded LibreELEC-S812.MXIII_Plus.arm-8.0.2.img.gz (18.02.2017) with Rufus on SD card and replaced dtb with MXIII_Plus.dtb and thus far all working on MXIII Plus. Thank you
- Official Post
I uploaded the new version of the test image TEST_DTB for direct work with a separate dtb. Try it. In the DTB section on the website updated files for the different models.
For information
I installed on my box MXIII-G 2/8 update 20170418 completely disappeared Wifi drivers on both versions (LAN1000,MXIII_Plus)Try the version M8S . If that doesn't work, you can try a test version TEST_DTB with a separate dtb file (NOT use the version TESD_DTB for installation in memory).
I have a mxq s812 m10 ms8 v1.0 20150729 would this be the right forum for the firmware
ok I have tried each of your img files for my s812 n200 with no luck at all how do I activate the multiboot I'm so confused. I have did my mxq pro 4k with no issues but this is complicated
Thank you
My 1 year old , MX111 S812 2gb ram 8gb rom , which i had previously installed tronsmart's recovery on to
i had to factory reset in recovery after installing your image originally,
upgraded from LE7 to your file for MX111 plus to 8.02 with krypton
apart from txt at start up no issues
The updated image. A number of changes to the load scripts. Added reboot into Recovery. Note that when using the system with external SD card before selecting reboot into Recovery, you need to remove the script aml_autoscript SD card from FAT partition. Otherwise, when the script aml_autoscript and select reboot into Recovery, the looping start. If this happens, turn off TV box and remove the script. After that, you can continue to use this SD card.
hi I have tried several files on my mxq s812 m10 m8s and I cant seem to enable multi boot if my life depended on it. I have tried using s805 auto_script and it errors right off the bat. I do what you say and update inside of android and nothing always error even with the universal. also yesterday I had got it to flash using usb tool but its a different rom (m8s) and its a (mxq) also I cant find any device tree files. its using n200 so I'm lost haha I'm sorry -
I have a LeeBox MS9 812 TV Box. When I use the tooth pick method with any of the newer images it just boots to the LeeBox Image screen, then to a black screen, I see a "reboot" message flash in the bottom left of the screen and it will continue the cycle over and over again. Any suggestions?
boot into recovery and factory reset
Anyone got Wi-Fi working yet on the Minix X8-H Plus?
I'm sorry but I can't follow you... I downloaded the image for my minix x8-h plus and try to boot. Impossible. Well, I changed one file named s805_autoscript with another downloaded from your directory. Also I changed the name for aml_autoscript. Boot again and now, minix said that can't mount flash...
Now I read I must downloaded boot.src? Excuse me but at this point I need, please, somebody makes clear information about the method to use libreelec with minix x8-h. ThanksEnviado desde mi ASUS_Z012D mediante Tapatalk
I downloaded another image, and without touching anything, this is what I see :Enviado desde mi ASUS_Z012D mediante Tapatalk
I got a M8S (10/100Mbps ethernet, AP6330 2.4/5Ghz WiFi and Bluetooth, 2GB/8GB)
I installed your build 20170418 as perfect works except wifi and bluetooth. How can I use it?
And can I disable HDMI-CEC? Thank you for your works I respect youPS:My MAC address changed!
Bugreport (MX3Plus):
4k resolution is still not functional -
