Can anyone upload config to mecool m8s pro+ ?
LE9.0 remote configs ir-keytable Amlogic devices
kostaman -
February 15, 2018 at 6:48 AM -
If you use 98-eventlircd.rules as HiassofT said before than it recognize remote as keyboard and you can use keyboard maps
For me it works
Just to make sure: do i still need to set up my remote in rc_keymaps with assigned letters to my buttons (KEY_A, KEY_B etc.) ?
0x7076b KEY_C
See my example in post LE9.0 remote configs ir-keytable Amlogic devicesLircmap.xml and keymaps.xml are optional and can be configured only for incorrect buttons or for you desires(in my example this buttons marked as new). See also example in post LE9.0 remote configs ir-keytable Amlogic devices
Here are the config files for the following three devices:
Sunvell T95X:sunvell.txt
Thank you tavoc, used the T95X on a T95V Pro remote. Works after Unix EOL conversion in Notepad++.
Throwing this out there - not really a LE concern, but Many of my remote codes for my LE box also are used for the Roku (TCL) TV I have. ie, vol down in LE/kodi is mute on the TV, etc. Any ideas on how to solve this? sure i can move the LE keys around, but they still hit Kodi/TV when i hit those impacted keys (the vol down Kodi and mute on TV is a real pain). Thanks
Mecool M8S Pro+ is remote config is included on this build (as stated on the first post). I've only added a rule to run 'ir-ctl -t 30000' at boot to have better response from rapid keypresses (someone gave the instructions some posts before this one).
can someone please share their T95Z Plus or T95U Pro for me 9.0 .... ? I have tried to make it so please don't tell me to read the first post ... I just want someone to share theirs
Also I use ir-keytable -D 525 -P 135 for delays, you can test your own delays
And ir-ctl -t 45000 for release button delay
Everything saved in autostart.sh file so after reboot all settings are used
Sorry for a rather basic question. I like to go through pages pretty quick, and use time skip often (repeat right arrow) during viewing. But with the setting above, when i click the arrows fast (ie, 4x) some are missed (ie 3x are recognized). what variable and which direction would i go to help resolve this? I have also lowered each of the above, and still has the behavior. Thank you.
Hi. Sorry but I am not expert from this. You need to test other values and find good for You
ir-ctl timeout is important, but if you use a NEC protocol remote presses quicker than 4 times a second (250ms) won't be recognized as distinct repeats - NEC protocol doesn't have a toggle bit like rc-5 or rc-6/MCE protocols. Use an rc-5 or rc-6/MCE remote if you want better response to quickly repeated button presses.
Ok, thanks for the education. using remote.conf was smooth in this regard. I do use NEC so will tinker more with settings, or just have to chill out a bit on the clicker.
For 8.90.2 you need to use old dtb and old remote.conf
The whole remote setup changed between those two versions. What worked for 8.90.2 will not work for 8.90.4 - Guaranteed. The change is well documented in the introduction post to 8.90.4
Stephen
beelink minimx files: 858036337
Stephen
Thank you, Stephen!
But now this already not actual for me, because 8.90.2 seems also not stable enought... So, i'm going deeper and deeper back to find more stable release... Up to now all recent Amlogic Kodi releases have one common bug with WebServer (it works bad if remote HTTP-control connection used during long time). Maybe problem in linux core, i dont know.
Is included in which build, in this [8.90.5] LibreELEC 9.0 Alpha for S905/S912 devices ?
Yes, included since 8.90.4. On earlier builds also worked by default, as they were using the Amlogic remote.conf method.
If anyone interested here are the files to get T95U/T95Z/T95k ETC working """" T95U_Remote-Libreelec.rar """ just download extract and copy files to configfiles using samba ..... then using ssh use the commands on first page to load it ... thats it ... enjoy
