LE9.0 remote configs ir-keytable Amlogic devices
  • These are the keymap files for M9Cmax remote:
    UPDATE: the new package attached here includes also a XML file that lets Kodi to recognize correctly the backspace button in its virtual keyboard!
    Please read INSTALL.txt for instructions about the installation ;)
  • redsquirrel87, didn't see you posted earlier regarding the M9C.
    I started this morning to get the M9C max remote working. This is the keymaps.xml I'm using.
    Am testing right now, seems to work.
    By the way: I also recommend using Notepad++. Make sure you have only LF (line Feeds) between each command, there should be no CR (Carriage Returns). One can also fix this using the "replace" option and play with /n and /r.
    M9C:
    # table M9C type: NEC
    0x40404d KEY_POWER
    0x404043 KEY_MUTE
    0x404017 KEY_VOLUMEDOWN
    0x404018 KEY_VOLUMEUP
    0x40400b KEY_UP
    0x404010 KEY_LEFT
    0x40400d KEY_ENTER
    0x404011 KEY_RIGHT
    0x40400e KEY_DOWN
    0x40401a KEY_HOME
    0x404045 KEY_MENU
    0x404042 KEY_BACK
    0x404047 KEY_CONTEXT_MENU
    0x40400c KEY_BACKSPACE
    0x404000 KEY_0
    0x404001 KEY_1
    0x404002 KEY_2
    0x404003 KEY_3
    0x404004 KEY_4
    0x404005 KEY_5
    0x404006 KEY_6
    0x404007 KEY_7
    0x404008 KEY_8
    0x404009 KEY_9
    rc_maps.cfg
    # Keymaps table
    # This table creates an association between a keycode file and a kernel
    # driver. It can be used to automatically override a keycode definition.
    # Format:
    # driver - name of the driver provided via uevent - use * for any driver
    # table - RC keymap table, provided via uevent - use * for any table
    # file - file name. If directory is not specified, it is first looked up
    # in /storage/.config/rc_keymaps, then /usr/lib/udev/rc_keymaps
    # For example:
    # driver table file
    # gpio-rc-recv rc-streamzap streamzap
    # gpio-rc-recv * justboom
    # * rc-rc6-mce rc6_mce_new
    # * * hauppauge_new
    # table tanix, type: NEC
    meson-ir * M9C
    Edited 2 times, last by hansje ().
  • Thank you, I already posted the files in a previous post but it is waiting for moderation, so it is not visible for now xD
    However since you have the same tvbox, could I ask you a couple of questions? First of all, the backspace button works for you in the kodi virtual keyboard? Because for me if I map it to KEY_BACKSPACE it got the same function of the KEY_BACK button (so it closes the virtual keyboard instead of deleting the last character typed). Is the same for you?
    And about the 0-9 buttons, on previous versions they simply wrote the corresponding number in the virtual keyboard (I mean, I pressed 2 and in the keyboard appeared "2"), now they give a "old cellphone" keyboard function (for example if I press 2 in the keyboard appears "a", with another click it changes into "b" etc...), is the same for you too?
    Thx
  • Thank you for the confirmations, I spent hours to test all the available KEY values to find one that could reproduce the "real" backspace function but none worked :( At the end as I wrote in the (for now invisible) post above I chose to map it to KEY_DELETE value, so that at least you can re-map it to the real backspace function by using the Keymap Editor addon (since if you use the KEY_BACK/BACKSPACE value then it can not be used in the addon to remap any function). Same thing about the 0-9 buttons (I could not find any way to reproduce the old behaviour), but for them well, it's not a big issue since even the new function is not so pointless at the end xD
  • Interestingly, I also tested the KEY_DELETE earlier, but that didn't do anything here either :(
    The other issue I have right now is that the KEY_HOME and/or KEY_HOMEPAGE don't do anything (tried both).
    Shouldn't this bring you back to the Kodi home menu regardless of where you are?
    I'm not an expert, and still very much learning... Thank you for the tip with the Keymap editor, will check that out!
  • Has anybody got the remote working for the Nexbox A95X yet? I've tried what was mentioned earlier (on page 2) and it didn't work. No response whatsoever. I'm getting super frustrated with this by now :(
    If any of you got it working for your A95X, could you please zip all the relevant files up and help me out a bit? I'd be very grateful
  • redsquirrel87 , hansje ,
    you can check my post LE9.0 remote configs ir-keytable Amlogic devices for deeper configuration. I manually assign the keys. there are 2 examples, OLD is without longpress buttons and x92_keyboard with longpress(configured as keyboard)
    And backspace work as backspace for text and as back in other cases.
    Thank you very much, I edited my post with a new package that now includes also the XML keymap file. In this way now the backspace button works like it should xD
  • mini_m8sII:
    # table mini_m8sii, type: nec
    0x8030 KEY_NUMERIC_0
    0x8031 KEY_NUMERIC_1
    0x8032 KEY_NUMERIC_2
    0x8033 KEY_NUMERIC_3
    0x8034 KEY_NUMERIC_4
    0x8035 KEY_NUMERIC_5
    0x8036 KEY_NUMERIC_6
    0x8037 KEY_NUMERIC_7
    0x8038 KEY_NUMERIC_8
    0x8039 KEY_NUMERIC_9
    0x8051 KEY_POWER
    0x804d KEY_MUTE
    0x8053 KEY_HOME
    0x804e KEY_VOLUMEUP
    0x8056 KEY_VOLUMEDOWN
    0x80bb KEY_FASTFORWARD
    0x80bd KEY_REWIND
    0x8058 KEY_STOP # 1/a button on remote
    0x8026 KEY_UP
    0x8028 KEY_DOWN
    0x8025 KEY_LEFT
    0x8027 KEY_RIGHT
    0x800d KEY_OK
    0x8044 KEY_BACKSPACE
    0x8009 KEY_RED
    0x8011 KEY_GREEN
    0x8054 KEY_YELLOW
    0x804f KEY_BLUE
    0x8049 KEY_MENU
    0x801b KEY_BACK
    Edited 2 times, last by korcsi ().
  • Have a user the egoiggo s95x Remote Config?
    The Remote is this: LE9.0 remote configs ir-keytable Amlogic devices
    When i enter : ir-keytable -t
    then, returned "No devices found"
    Edited 4 times, last by TheMexx ().
  • X96:
    # table X96, type: nec
    0x101 KEY_NUMERIC_0
    0x14e KEY_NUMERIC_1
    0x10d KEY_NUMERIC_2
    0x10c KEY_NUMERIC_3
    0x14a KEY_NUMERIC_4
    0x109 KEY_NUMERIC_5
    0x108 KEY_NUMERIC_6
    0x146 KEY_NUMERIC_7
    0x105 KEY_NUMERIC_8
    0x104 KEY_NUMERIC_9
    0x140 KEY_POWER
    0x141 KEY_MUTE
    0x111 KEY_HOME
    0x1f5 KEY_VOLUMEUP
    0x1f4 KEY_VOLUMEDOWN
    0x116 KEY_UP
    0x11a KEY_DOWN
    0x151 KEY_LEFT
    0x150 KEY_RIGHT
    0x113 KEY_OK
    0x142 KEY_BACKSPACE
    0x143 KEY_RED
    0x10f KEY_GREEN
    0x110 KEY_YELLOW
    0x118 KEY_BLUE
    0x14c KEY_MENU
    0x119 KEY_BACK
    0x1f2 KEY_CONFIG
    Edited once, last by korcsi ().
    You need to update your DTB Index of /releases/dtb
  • @CtrlAltDelEnter Why do you copy the files with Filezilla over SSH and not just copy them on samba shared folders?
  • excuse me
    I did not understand you
    I do not quite understand in English
    if it is not hard for you tell me where to get remote config for kIII pro s912?
    I have a remot.config that works on 8.90.11a, but it does not work on 8.90.4
    Thank you
