wrxtasy -
September 2, 2017 at 4:34 AM -
Closed -
Then share with us your impressions of Netflix + Widevine "hack".
33 quid. Isn't this extremely cheap
Read #1
Posting
- One topic per thread
- Posts should be written in English
- Be as descriptive and detailed as possible. We are not mind readers!
- Do not cross-post or double-post
- Do not post or promote external URL links to products, a name description is enough
H96 PRO Plus KODI 17.3 Android 7.1 Amlogic S912 TV BOX 4K 3GB/32GB 802.11AC WIFI 1000M LAN
33 quid. Isn't this extremely cheap for the H96 Pro+ ? 32 GB and 3 GB ram. Geekbuying charges $60 or so. Is this for real? And have anyone tried to install the H96 Pro Plus to internal? I can't use SD.MOD EDIT: Product Link deleted. Please read forum Rules Above
That offers ended, usually about £65, so I would say very cheap at £33
Hi. Are there any other boxes support HDMI_CEC apart from Odroid-C2?
All boxes support CEC in some level. There are bugs but most of them usable more or less.
I had this box come for someone lately and I was really impressed with the performance, this was a totally debloated android 6.0.
wrxtasy Hello i've just received a mecool m8s pro+ (last stock with kingstone eMMC and no reset button) in which i've install both LibreELEC with SD boot and Android TV rom.
Just for my Knowledge: what is missing in "stock" Rom that avoid netflix to get 1080p (and maybe) 720p that is added in Android tv rom?
How did you miss Link #130
Using corporate logos as an avatar must have taken some thought ?
Hi,
Does anyone have information about new Mini M8S III (3) model? Is it compatible with kszaq LE?
Appeared recently on Chinese sites, and price is good for the model 2/16GB.They claim it is Amlogic S905X.
There are any issues with MINIX Neo U1 and LibreElec 8.2? Do Wi-fi and IPTV work? Thanks!
Hi all, this is my box now, a Z69 with 3/32 gig and a S905X chip.
You can find it on the familiar Chinese sites, I wont post the link
Box is running fine with LE, latest 8.1.10 build, running from internal memory.
CEC works fine.
WIFI not tested, using wired.No Giga ethernet unfortunately.
In the Odroid C2 under LE, I like how the in built IR receiver just works with a MCE remote. Do any of the boxes mentioned in this thread have a similar inbuilt IR receiver?
Also, theres a big price difference between, say, a Beelink for $42 and a Minix U1 for $110. Is there something in between with quality components?
Partially.
Using CEC my TV remote is working fine
How much CEC is reliable on your Beelink MiniMXIII II S905X box? Does it support standby/wake-up? I am looking for a 4k 10bit HDR capable box to replace my old HTPC.
I have been using only CEC hence the support is mandatory. Maybe my existing Pulse-eight USB CEC adapter can be used with any S905 box?
I don´t use standby/wakeup - my Beelink is up 24/7
I see. Is it working fine otherwise or have you observed any deficiency in CEC operation on your box?
CEC is working for me - play/stop/pause etc.
Don´t need much special key like others
